I’ve pulled a bunch of logs from, in this case, Proxmox Backup Server for my client for security reasons. And some of the files just won’t sync via the Desktop Client, as they keep resulting in “Connection Closed”.
I checked the file size, and they’re Kilbytes in size, but I think it’s something to do with the file name (and no, I’m not renaming them, these files need to be immutable and not modified for security reasons).
An example file is:
“UPID:pbs:000004F6:000001CA:00000002:63CF81F4:backup:REDACTED\x3avm-117:root@pam:”
Naturally I redacted the sensitive parts, but you get the idea. And yes that slash is part of the filename.
These files were pulled off of Proxmox Backup Server, and for those unfamiliar with it, it’s a Linux ecosystem. So these are generally Unix-compliant-ish filenames.
Anyways, I’m not sure what to do about this, but I need my Desktop Client to be able to sync these files now and in the future. So I need to figure out a solution for this. Any ideas? Keen thoughts? Thanks!
