Snowest
September 28, 2020, 7:51pm
#1
I can’t connect with clients on my selfhosted NC 19.0.2 runing on docker.
I tried with the mac client I get bad request as feedback and the wrong url. Instead of https I get http://mydomain . even if I typed the https url.
And on my Android it keeps spining after pressing the loginbutton. So no feedback…
Connecting with Client from inside my Network with IP - Work
Connecting with Browser from inside my Network with IP - Work
Connecting with Browser from Outside my Network with DNS - Works
Connecting with Client from Outside my Network with DNS - do not work
I can imagine, that is a bad redirect regading http and https, mybe with htaccess.
If anyone could help me, thanks
Snowest
September 29, 2020, 5:26am
#2
Why is it possible to reach my server from outside using my dns https://mydomain.com
But with a client it is not possible. On my desktop i get the wrong url with http (even if I set the url correctly with https).
Thats my I assume an error with redirect or something like this. My server has letsencryp and only acept secure connection.
if you think that might be the case why do you spare any further information from us? We don’t know almost nothing about your problematic server, setups, logfiles, environment… etc
Snowest
September 29, 2020, 8:04am
#4
Because I don’t know what to change in the htaccess file.
Here is my htaccess file
<IfModule mod_headers.c>
<IfModule mod_setenvif.c>
<IfModule mod_fcgid.c>
SetEnvIfNoCase ^Authorization$ "(.+)" XAUTHORIZATION=$1
RequestHeader set XAuthorization %{XAUTHORIZATION}e env=XAUTHORIZATION
</IfModule>
<IfModule mod_proxy_fcgi.c>
SetEnvIfNoCase Authorization "(.+)" HTTP_AUTHORIZATION=$1
</IfModule>
</IfModule>
<IfModule mod_env.c>
# Add security and privacy related headers
# Avoid doubled headers by unsetting headers in "onsuccess" table,
# then add headers to "always" table: https://github.com/nextcloud/server/pull/19002
Header onsuccess unset Referrer-Policy
Header always set Referrer-Policy "no-referrer"
Header onsuccess unset X-Content-Type-Options
Header always set X-Content-Type-Options "nosniff"
Header onsuccess unset X-Download-Options
Header always set X-Download-Options "noopen"
Header onsuccess unset X-Frame-Options
Header always set X-Frame-Options "SAMEORIGIN"
Header onsuccess unset X-Permitted-Cross-Domain-Policies
Header always set X-Permitted-Cross-Domain-Policies "none"
Header onsuccess unset X-Robots-Tag
Header always set X-Robots-Tag "none"
Header onsuccess unset X-XSS-Protection
Header always set X-XSS-Protection "1; mode=block"
SetEnv modHeadersAvailable true
</IfModule>
# Add cache control for static resources
<FilesMatch "\.(css|js|svg|gif)$">
Header set Cache-Control "max-age=15778463"
</FilesMatch>
# Let browsers cache WOFF files for a week
<FilesMatch "\.woff2?$">
Header set Cache-Control "max-age=604800"
</FilesMatch>
</IfModule>
<IfModule mod_php7.c>
php_value mbstring.func_overload 0
php_value default_charset 'UTF-8'
php_value output_buffering 0
SetEnv htaccessWorking true
</IfModule>
</IfModule>
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteCond %{HTTP_USER_AGENT} DavClnt
RewriteRule ^$ /remote.php/webdav/ [L,R=302]
RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^\.well-known/host-meta /nextcloud/public.php?service=host-meta [QSA,L]
RewriteRule ^\.well-known/host-meta\.json /nextcloud/public.php?service=host-meta-json [QSA,L]
RewriteRule ^\.well-known/webfinger /nextcloud/public.php?service=webfinger [QSA,L]
RewriteRule ^\.well-known/nodeinfo /nextcloud/public.php?service=nodeinfo [QSA,L]
RewriteRule ^\.well-known/carddav https://MYDOMAIN:PORT/remote.php/dav/ [R=301,L]
RewriteRule ^\.well-known/caldav https://MYDOMAIN:PORT/remote.php/dav/ [R=301,L]
RewriteRule ^remote/(.*) remote.php [QSA,L]
RewriteRule ^(?:build|tests|config|lib|3rdparty|templates)/.* - [R=404,L]
RewriteCond %{REQUEST_URI} !^/\.well-known/(acme-challenge|pki-validation)/.*
RewriteRule ^(?:\.|autotest|occ|issue|indie|db_|console).* - [R=404,L]
</IfModule>
<IfModule mod_mime.c>
AddType image/svg+xml svg svgz
AddEncoding gzip svgz
</IfModule>
<IfModule mod_dir.c>
DirectoryIndex index.php index.html
</IfModule>
AddDefaultCharset utf-8
Options -Indexes
<IfModule pagespeed_module>
ModPagespeed Off
</IfModule>
#### DO NOT CHANGE ANYTHING ABOVE THIS LINE ####
ErrorDocument 403 //
ErrorDocument 404 //
Options -MultiViews
RewriteEngine on
RewriteRule ^\.well-known/carddav /nextcloud/remote.php/dav/ [R=301,L]
RewriteRule ^\.well-known/caldav /nextcloud/remote.php/dav/ [R=301,L]
RewriteCond %{REQUEST_FILENAME} !\.(css|js|svg|gif|png|html|ttf|woff2?|ico|jpg|jpeg|map|webm|mp4)$
RewriteCond %{REQUEST_FILENAME} !core/img/favicon.ico$
RewriteCond %{REQUEST_FILENAME} !core/img/manifest.json$
RewriteCond %{REQUEST_FILENAME} !/remote.php
RewriteCond %{REQUEST_FILENAME} !/public.php
RewriteCond %{REQUEST_FILENAME} !/cron.php
RewriteCond %{REQUEST_FILENAME} !/core/ajax/update.php
RewriteCond %{REQUEST_FILENAME} !/status.php
RewriteCond %{REQUEST_FILENAME} !/ocs/v1.php
RewriteCond %{REQUEST_FILENAME} !/ocs/v2.php
RewriteCond %{REQUEST_FILENAME} !/robots.txt
RewriteCond %{REQUEST_FILENAME} !/updater/
RewriteCond %{REQUEST_FILENAME} !/ocs-provider/
RewriteCond %{REQUEST_FILENAME} !/ocm-provider/
RewriteCond %{REQUEST_FILENAME} !/richdocumentscode/proxy.php$
RewriteRule . index.php [PT,E=PATH_INFO:$1]
RewriteBase /
SetEnv front_controller_active true
DirectorySlash off
</IfModule>
</IfModule>
</IfModule>
I made some screenshot of my login procedure with my desktop clinet on my mac.
The red error is http, even if I wrote https. this is the only hint I get why it would be a http to https issue. but I’m not sure.
Snowest
September 29, 2020, 8:51am
#5
Nextcloud is configured as revers proxy on my synology. I don’t know if this is important for my issue
Snowest
September 29, 2020, 5:08pm
#6
I managed to log me in with my android using the token entry way.
Thanks verymuch for the help!
JimmyKater
split this topic
October 6, 2020, 6:42am
#7
