I try to connect my Outlook 2010 (64bit) calendar with NC 10 calendar using Outlook Internetcalendar function.
After inserting a link like
https://www.domain.tld/nextcloud/remote.php/dav/calendars/Username/personal
Outlook ask for a few things, like foldername and sync options.
After this procedure i get a prompt to enter username/password.
Few Minutes later a calendar entry of the named calendar is shown. But, it’s empty.
After clicking in the calendar, it prompt with a message:
Changing the content of a writeprotected folder is not possible.
Any solution for this problem?
