Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 20.0.5): 27.1.1
Operating system and version (eg, Ubuntu 20.04): Debian 12
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.57
PHP version (eg, 7.4): 8.2
I’m looking for advise on the best way to add external storage.
I’ve setup a data folder under /opt/data as part of the install. I now want to add a chunk of storage from a synology NAS which will be used for ‘group shares’ storage.
I’m assuming I need to use the ‘external folders’ app? Is there any other options?
If I’m using the external storage app, which is the better option
- Mount the storage as NFS on the host and use the local option for the external folders
- Use SMB/CIFS
- Install WebDAV server on the NAS and connect via that
For each of the group shares, I will have one or two users who I only want to give read access and I’d rather not have to duplicate users across both the nextcloud and NAS to allow fine grained access control
Thanks in advance
