Nextcloud version (eg, 20.0.5): 21
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04 + Docker
Apache or nginx version (eg, Apache 2.4.25): Docker Apache Image (latest)
`I have been attempting to login into the Talk app, but the ‘Grant access’ Screen loads endlessly and some users are reporting problems logging in with nextcloud behind a reverse proxy. I have come across this article: Reverse proxy — Nextcloud latest Administration Manual latest documentation
However I am a bit confused on how to actually set it up with my workflow.
Here is how things work for me:
Dockerised Nextcloud Instance (docker-compose.yml)
Docker-Compose File
version: '2'
services:
db:
image: mariadb
restart: always
volumes:
- ./database:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=HIDDEN
- MYSQL_PASSWORD=HIDDEN
- MYSQL_DATABASE=HIDDEN
- MYSQL_USER=HIDDEN
networks:
- default
app:
image: nextcloud
restart: always
links:
- db
volumes:
- ./html:/var/www/html
environment:
- MYSQL_HOST=db
networks:
- web
- default
depends_on:
- db
- redis
redis:
image: redis:alpine
restart: always
networks:
- default
cron:
image: nextcloud:fpm-alpine
restart: always
volumes:
entrypoint: /cron.sh
depends_on:
- db
- redis
networks:
- default
networks:
web:
default:
I then have a Nginx Reverse Proxy Setup in front (NGINX Reverse Proxy Manager). Everything works for now but the only thing I can’t get working is logging in to the Talk app, so I want to properly configure Nextcloud to know it is behind a reverse proxy. How can I accomplish it with my setup:?
'trusted_proxies' => ['nginx-proxy_app_1'],, #What would go here? The reverse proxy hostname docker?
'overwritehost' => 'localhost', # The container's hostname? Localhost?
'overwriteprotocol' => 'https', #
'overwritewebroot' => '/nextcloud.example.com', #I assume this is my reverse proxy?
'overwritecondaddr' => '^10\.0\.0\.1$', #And this one baffles me
