hello and kudos to the ncp dev team, i have ran in to a particularily hindering problem that i do not understand,
i have setup everything to the dot except my samba share due to not understanding the cfg file to configure it as the webui creates its own default cfg outlook which even fiddling around with only got me to the share on a windows machine but not to write anything on to it, i followed this guide https://ownyourbits.com/2017/04/16/share-your-files-in-your-lan-with-samba/ and even removed the part
force group = www-data
create mask = 0770
directory mask = 0771
force create mode = 0660
force directory mode = 0770
as the guide states that makes it sync with nextcloud and i dont need nor want that, i have mapped the path to an external drive that i dedicate to the nas, i am trying to share permissions between a mint linux laptop and a windows 7 but to no avail, i can read into the drives directory but cannot create files or folders on to it
could someone give me a working smb configuration for offline use with the nextcloudpi i can fill in all the necessary info trough pm or logs aslong as someone points me to the right direction
