I am able to mount an S3-compatible object store bucket as external storage, and I can read/write files and folders there as expected. What I would like to do is mount a subpath within the bucket instead of the bucket root. While I understand that S3 buckets are actually flat hierarchies with no real folder structure, the commonly supported convention of effective hierarchy is what I need here. This would allow me, for example, to create a new external storage mount for each user, all from a single bucket, where each user could only see the objects under their own subpath.
Is this possible?
Nextcloud version: 27.0.2
