Hi all,
after my last question (seperate nextcloud and nginx/php docker) I wanted to test the Nextcloud AIO docker package, but I’m facing some problems.
Situation:
I want to use Nextcloud AIO only in my local network on my rpi4, no access from Internet. And no NGinx Proxy manager or similar.
Only the AIO package.
I’ve taken the example docker-compose and adjusted it on my setup (or what I think it could be right).
But it’s not working and I don’t know what is wrong.
Sometimes I could start the install, but nextcloud itself was not reachable. Also the certificate seems to be wrong created (everytime detected as not safe certificate)
Before I start the next try. It is possible that somechecks my configs, if there are any mistakes? Or what could be improved?
compose.yaml
services:
nextcloud:
init: true
restart: always
volumes:
ports:
- 8080:8080
environment:
- APACHE_PORT=11000
- APACHE_IP_BINDING=127.0.0.1
- NEXTCLOUD_DATADIR=/home/pi/docker/nextcloud/nextcloud-data
- SKIP_DOMAIN_VALIDATION=true
caddy:
image: caddy:alpine
container_name: caddy
restart: always
ports:
- 80:80
- 443:443
volumes:
- /home/pi/docker/nextcloud/caddy-files/caddy:/usr/bin/caddy
- /home/pi/docker/nextcloud/caddy-certs:/certs
- /home/pi/docker/nextcloud/caddy-config:/config
- /home/pi/docker/nextcloud/caddy-data:/data
- /home/pi/docker/nextcloud/caddy-certs:/srv
- /home/pi/docker/nextcloud/caddy-files/Caddyfile:/etc/caddy/Caddyfile
environment:
DOMAIN: "xxx.duckdns.org"
EMAIL: "xxx@googlemail.com"
DUCKDNS_TOKEN: "xx-xx-xx-xx-xx"
LOG_FILE: "/data/access.log"
volumes:
Caddyfile:
xxx.duckdns.org:443 {
tls {
dns duckdns xx-xx-xx-xx-xx
reverse_proxy localhost:11000
The caddy file was downloaded from the caddy homepage and should work (executing is possible).
Shouldn’t be a problem, that I created another certificate at a duckdns-subdomain with my email-address?
Thanks for your support ![]()
Best regards,
Dominik
