I always gets this error. I wanted to migrate from OwnCloud to NextCloud.
Here the code:
root@BANANAS ~www/nextcloud # sudo -u www-data php occ upgrade
Nextcloud is not installed - only a limited number of commands are available
[Symfony\Component\Console\Exception\CommandNotFoundException]
Command “upgrade” is not defined.
Who can help me fast? I need my calender.
tflidd
2
Please check if you installed all required modules:
https://docs.nextcloud.com/server/9/admin_manual/installation/source_installation.html#prerequisites
The ownCloud setup is running on your machine (then normally the php config should be quite ok)? Between which version are you updating?
system
Closed
3
