Collabora with Apache2 backend and Nginx Reverse Proxy?
Some more error debugging:
https://cloud.techandme.se/lool works
https://cloud.techandme.se/loleaflet doesn’t exist??
https://cloud.techandme.se/hosting/discovery works
Same result if I run it locally with the portnumber…
I need your help guys
this is my nginx
server {
listen 443 ssl;
server_name hbloffie;
ssl_certificate /etc/nginx/ssl/hbloffice.crt;
ssl_certificate_key /etc/nginx/ssl/hbloffice.key;
# static files
location ^~ /loleaflet {
    proxy_pass https://127.0.0.1:9980;
proxy_redirect off;
proxy_set_header Host $http_host;
# WOPI discovery URL
location ^~ /hosting/discovery {
# websockets, download, presentation and image upload
location ^~ /lool {
    proxy_set_header Connection "upgrade";
i only see nginx index no redirect to collabora thx for the help
Anyone that have solved this yet?
Okay, so with the new Collabora app it just says ā€œAccess forbiddenā€. Like this:
cc @LukasReschke (at least this is not the IRC channel :wink: )
What should I do, does Collabora support this configuration?
In my case it was that docker was no longer starting on boot. Once I started it, the Access Forbidden went away.
Docker or the container? Cause the --restart always in the guide should take care of the container.
Docker. When I’ve gotten that message in the past, it’s usually been because Docker either shut down for whatever reason and never started after a reboot.
Ok, progress…
I added 192.168.4.111 office.techandme.se to /etc/hosts and now I don’t get ā€œAccess Deniedā€ anymore. Though it stalls when trying to connect.
Also running a tcpdump looks like this:
22:43:03.142260 IP 192.168.4.201.50424 > 172.17.0.2.9980: Flags [S], seq 2710338342, win 29200, options [mss 1460,sackOK,TS val 219377322 ecr 0,nop,wscale 7], length 0
22:43:03.142308 IP 172.17.0.2.9980 > 192.168.4.201.50424: Flags [S.], seq 2180839642, ack 2710338343, win 28960, options [mss 1460,sackOK,TS val 49643 ecr 219377322,nop,wscale 7], length 0
22:43:03.142378 IP 192.168.4.201.50424 > 172.17.0.2.9980: Flags [.], ack 1, win 229, options [nop,nop,TS val 219377322 ecr 49643], length 0
22:43:03.142439 IP 192.168.4.201.50424 > 172.17.0.2.9980: Flags [P.], seq 1:306, ack 1, win 229, options [nop,nop,TS val 219377322 ecr 49643], length 305
22:43:03.142454 IP 172.17.0.2.9980 > 192.168.4.201.50424: Flags [.], ack 306, win 235, options [nop,nop,TS val 49643 ecr 219377322], length 0
22:43:03.144566 IP 172.17.0.2.9980 > 192.168.4.201.50424: Flags [P.], seq 1:2190, ack 306, win 235, options [nop,nop,TS val 49644 ecr 219377322], length 2189
22:43:03.144645 IP 192.168.4.201.50424 > 172.17.0.2.9980: Flags [.], ack 1449, win 251, options [nop,nop,TS val 219377322 ecr 49644], length 0
Where does 172.17.0.2 come from, and do I need to add it somewhere in the Server block in Nginx?
Theese are my current configs:
APACHE
<VirtualHost 192.168.4.111:443>
  ServerName office.techandme.se
  # SSL configuration, you may want to take the easy route instead and use Lets Encrypt!
  SSLEngine on
  SSLCertificateFile /etc/ssl/techandme/techandme_wild.pem
  SSLCertificateKeyFile /etc/ssl/techandme/techandme_wild.key
  SSLProtocol             all
  SSLCipherSuite ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
  SSLHonorCipherOrder     on
  # Encoded slashes need to be allowed
  AllowEncodedSlashes On
  # Container uses a unique non-signed certificate
  SSLProxyEngine On
  SSLProxyVerify None
  SSLProxyCheckPeerCN Off
  SSLProxyCheckPeerName Off
  # keep the host
  ProxyPreserveHost On
  # static html, js, images, etc. served from loolwsd
  # loleaflet is the client part of LibreOffice Online
  ProxyPass           /loleaflet https://192.168.4.111:9980/loleaflet retry=0
  ProxyPassReverse    /loleaflet https://192.168.4.111:9980/loleaflet
  ProxyPass           /hosting/discovery https://192.168.4.111:9980/hosting/discovery retry=0
  ProxyPassReverse    /hosting/discovery https://192.168.4.111:9980/hosting/discovery
  # Main websocket
  ProxyPassMatch "/lool/(.*)/ws$" wss://192.168.4.111:9980/lool/$1/ws
  # Admin Console websocket
  ProxyPass   /lool/adminws wss://192.168.4.111:9980/lool/adminws
  # Download as, Fullscreen presentation and Image upload operations
  ProxyPass           /lool https://192.168.4.111:9980/lool
  ProxyPassReverse    /lool https://192.168.4.111:9980/lool
</VirtualHost>
NGINX
server {
	error_page 404 500 502 503 504 /office-error.html;
        location = /office-error.html {
                root /usr/share/nginx/html;
                internal;
	real_ip_header     X-Forwarded-For;
        real_ip_recursive  on;
        listen 192.168.4.201:443 ssl http2;
        ssl on;
        ssl_certificate /etc/nginx/ssl/techandme/techandme_wild.pem;
        ssl_certificate_key /etc/nginx/ssl/techandme/techandme_wild.key;
#        ssl_certificate /etc/letsencrypt/live/office.techandme.se/fullchain.pem;
#        ssl_certificate_key /etc/letsencrypt/live/office.techandme.se/privkey.pem;
	ssl_dhparam /etc/nginx/sites-available/cloudflare_ip/office.techandme/office-dhparams.pem;
        ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
        ssl_session_timeout 1d;
        ssl_session_cache shared:SSL:10m;
        ssl_stapling on;
        ssl_stapling_verify on;
        # Only use safe chiphers
	ssl_ciphers 'ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA';
	ssl_prefer_server_ciphers on;
        server_name office.techandme.se;
        set $upstream 192.168.4.111;
## Collabora ##
                proxy_pass https://$upstream:9980;
		proxy_buffering off;
        location ^~ /lool {
server {
  listen 192.168.4.201:80;
  return 301 https://office.techandme.se$request_uri;
NGINX main domain
server {
        # Cloudflare IP that is masked by mod_real_ip
	error_page 404 500 502 503 504 /cloud-error.html;
        location = /cloud-error.html {
                internal;
     	set_real_ip_from 103.21.244.0/22;
     	set_real_ip_from 103.22.200.0/22;
     	set_real_ip_from 103.31.4.0/22;
     	set_real_ip_from 104.16.0.0/12;
     	set_real_ip_from 108.162.192.0/18;
     	set_real_ip_from 131.0.72.0/22;
     	set_real_ip_from 141.101.64.0/18;
     	set_real_ip_from 162.158.0.0/15;
     	set_real_ip_from 172.64.0.0/13;
     	set_real_ip_from 173.245.48.0/20;
     	set_real_ip_from 188.114.96.0/20;
     	set_real_ip_from 190.93.240.0/20;
     	set_real_ip_from 197.234.240.0/22;
     	set_real_ip_from 198.41.128.0/17;
     	set_real_ip_from 199.27.128.0/21;
        ssl on;
#        ssl_certificate /etc/letsencrypt/live/cloud.techandme.se/fullchain.pem;
#        ssl_certificate_key /etc/letsencrypt/live/cloud.techandme.se/privkey.pem;
	ssl_dhparam /etc/nginx/sites-available/cloudflare_ip/cloud.techandme/cloud-dhparams.pem;
        ssl_stapling on;
        server_name cloud.techandme.se;
## Spreed ME ##
       location /webrtc/ws {
                proxy_pass https://$upstream;
                proxy_http_version 1.1;
		proxy_buffering             on;
		proxy_ignore_client_abort   off;
		proxy_redirect              off;
		proxy_connect_timeout       90;
		proxy_send_timeout          90;
		proxy_read_timeout          90;
		proxy_buffer_size           4k;
		proxy_buffers               4 32k;
		proxy_busy_buffers_size     64k;
		proxy_temp_file_write_size  64k;
## Nextcloud ##
        location / {
                proxy_pass_header Authorization;
                proxy_set_header Host $host;
                proxy_set_header Connection "";
                proxy_request_buffering off;
		client_max_body_size 0;
                proxy_read_timeout  36000s;
                proxy_redirect off;
                proxy_ssl_session_reuse off;
server {
  return 301 https://cloud.techandme.se$request_uri;
APACHE main domain
    Header always set Strict-Transport-Security "max-age=63072000; includeSubDomains; preload"
    SSLEngine on
### YOUR SERVER ADDRESS ###
    ServerAdmin daniel@techandme.se
    ServerName cloud.techandme.se
    ServerAlias 192.168.4.111
### SETTINGS ###
    DocumentRoot /var/www/nextcloud
    <Directory /var/www/nextcloud>
    Options Indexes FollowSymLinks
    AllowOverride All
    Require all granted
    Satisfy Any
    </Directory>
    <IfModule mod_dav.c>
    Dav off
    </IfModule>
    <Directory "/var/ncdata">
    # just in case if .htaccess gets disabled
    Require all denied
    </Directory>
### SSL CONFIG ###
#    SSLCertificateChainFile /etc/ssl/techandme/certificate/certificate.ca.crt
</VirtualHost>
ISSUE SOLVED!
It was my firewall that blocked traffic on port 443 between Collabora and my Nextcloud.
Finally!
Hi
(First post so not used to the Markdown yet)
Solved it another way.
To make the docker take care of the incoming connection on the port bind it to 0.0.0.0 with this
docker -d -p 9980:9980 -e ā€˜domain=sub\.domain\.tld’ --restart always --cap-add MKNOD collabora/code
Then add the locations in the Nginx proxy and pass it to the NC host on the docker port using the defined upstream
proxy_pass https://:9980$upstream;
Hello i almost donde but now i have this error https://gyazo.com/fb26d63ab19987a15b0a4c58aebf2f60
WebSocket connection to 'wss://10.6.109.65/lool/https%3A%2F%2Fhblbox%2Fapps%2Frichdocuments%2Fwopi%2…i7Q6qlguGdmrlZiufva5waEu7RbK%26access_token_ttl%3D0%26permission%3Dedit/ws' failed: Error during WebSocket handshake: Unexpected response code: 400
im using Nginx i can enter to admin sonsole of collabora but i can create or view document any ideas
I’m using Nginx Reverse Proxy to an Apache backend. Do you do the same?
It could be a firewall setting, I’m not 100% sure, but that solved it for me at least.
No im using only nginx conf
Then use the config files in this post. They should work out of the box.
i know but i have that error in the browser ,
this is my nginx conf
server {
listen 443 ssl;
server_name 10.6.109.65;
ssl_certificate  /etc/nginx/ssl/10.6.109.65.crt;
ssl_certificate_key  /etc/nginx/ssl/10.6.109.65.key;
# static files
    proxy_pass https://localhost:9980;
# Main websocket
location ~ /lool/(.*)/ws$ {
    proxy_set_header Connection "Upgrade";
    proxy_read_timeout 86400s;
location ^~ /lool/adminws {
WOPI discovery URL
# Main websocket
# download, presentation and image upload
location ^~ /lool {
Hi :
@enoch85 @SirNolaan
can we delpoy Collabora Online Server in Local Area Network Environment
I don’t have public IP, here domain must be access in WAN?
No, it’s not possible afaik.
A virtual machine of CODE bundled with a demo ownCloud server: CODE VM (706 MB) (torrent file) and Setup Instructions.
but this CODE ļ¼¶ļ¼­ can open doc on web in LAN , new Edition can’t support?
I don’t think that old release would be very efficient.
You could setup a CODE VPS online and use your internet connection for users to access the CODE app.
Never the less, CODE has a hard limit of 10 open documents and 20 connections per container and also you’ll be limited on upload and download speed, since documents would have to transfer over the internet connection.
Could you share with us what is the motivation for using web applications on a LAN environment, instead of standalone LibreOffice installations?
wwe: close old topics
