Hello Community,
i’d love some advise how to setup Collabora on my Rpi3 running NextCloudPi instance.
There are some instructions i found here and elsewhere, but i still at a loss, 'cause i’m not sure about some basic prerequisites and concepts like
- do i need to install Docker-Stuff when i m running NCPi? Or is it solved there other way? Or is Docker already installed? - i’m bit worried if it’s not too little resources on Rpi3 for anaddition of Docker. Never used it yet either.
- Do i need subdomain? What if i won’t get it on my current DNS-Referal-Service (https://www.spdyn.de)? Can i use any other domain or a deep link?
- Do I need another Let’s encrypt certificat, even if it’s subdomain?
Maybe there are more, but that would be great, if someone could share his/her knowledge
Cheers!
