I run collabora code in container under podman. I can’t help it spamming the logs, I wonder if someone could spot my errror. I launch it with this environment extra options:
-e "extra_params=--o:ssl.enable=false --o:server_name=hidden.here --o:ssl.termination=true --o:logging.level=4" -e "dictionaries=en_US fi_FI"
First I tried with logging.level=warning, but it won’t reduce them either. I see all debug and trace and info levels, which is a lot.
This is what the coolwsd.xml says about logging option:
<logging>
<color type="bool">true</color>
<level type="string" desc="Can be 0-8 (with the lowest numbers being the least verbose), or none (turns off logging), fatal, critical, error, warning, notice, information, debug, trace" default="warning">warning</level>
So it should be even warning by default, but no, it spams a lot. I haven’t yet given up and mounted the xml file into container.
