Collabora external and internal not reachable
After the upgrade to 25 Autumn I am having trouble with Collabora.
I ran it as an external container (posted earlier about how I solved this before, because by default AIO blocks this, disabling NEXTCLOUD_KEEP_DISABLED_APPS=true rolls back to the internal functionality).
For the diagnosis of this problem I switched back to the internal. In both cases the page tries to load calc or writer, but times out, so it seems.
The external version was reachable using the hosting/discovery page, the internal is not: using settings/admin/richdocuments shows the following, so 0.0.0.0/0 is not possible to add.
GET https://nc.domain.nl/custom_apps/richdocumentscode/proxy.php?req=/hosting/discovery resulted in a 400 Bad Request response: Socket proxy error Error: no_glibc ’
Containers are running as expected.
I am using Traefik, no changes have been applied to Traefik when 25 Autumn was installed, later for troubleshooting I tried changing things, but was also able to roll back my backups.
In an earlier topic @szaimen asked to gather input from the Nextcloud container, here it is (domain name rewritten as good as possible), I can’t find any errors, but maybe something else is shown in this long extract:
10:43:39.312791 [0-x] == Info: [READ] client_reset, clear readers 10:43:39.316131 [0-0] == Info: Host nc.domain.nl:443 was resolved. 10:43:39.316539 [0-0] == Info: IPv6: (none) 10:43:39.316898 [0-0] == Info: IPv4: 192.168.0.5 10:43:39.317405 [0-0] == Info: [HTTPS-CONNECT] adding wanted h2 10:43:39.317970 [0-0] == Info: [HTTPS-CONNECT] added 10:43:39.318430 [0-0] == Info: [HTTPS-CONNECT] connect, init 10:43:39.319013 [0-0] == Info: Trying 192.168.0.5:443... 10:43:39.319638 [0-0] == Info: [HTTPS-CONNECT] connect -> 0, done=0 10:43:39.320029 [0-0] == Info: [HTTPS-CONNECT] Curl_conn_connect(block=0) -> 0, done=0 10:43:39.320784 [0-0] == Info: [HTTPS-CONNECT] adjust_pollset -> 1 socks 10:43:39.321240 [0-0] == Info: [SSL] cf_connect() 10:43:39.321633 [0-0] == Info: [SSL] ossl_connect, step1 10:43:39.331185 [0-0] == Info: ALPN: curl offers h2,http/1.1 10:43:39.331471 [0-0] == Info: [SSL] ossl_connect, step2 10:43:39.332990 [0-0] => Send SSL data, 5 bytes (0x5) 0000: ..... 10:43:39.333255 [0-0] == Info: TLSv1.3 (OUT), TLS handshake, Client hello (1): 10:43:39.333668 [0-0] => Send SSL data, 1562 bytes (0x61a) 0000: .......X.Dr...4..][..p.2..C.Z.n.8S+.. .C…JdBv..I…QQ..-…$.
0040: …<…,.0…+./…$.(.k.#.‘.g…9…3…=.
0080: <.5./…nc.domain.nl…
00c0: …h2.http/1.1…1…6.4…
0100: …+…-…3…u.6..
0140: V0.(bI…90…0..Xh.,#…<N.V..J.(i…@…$..N.0J…9…
0180: …M…BF..t.p.^..3..L"…%..i..X…k+.G…).adYoP..<..F.~
01c0: …{..y…tM.r…dQ.B..V.y.[P…mj…Jb6.~7D.
0200: d…\u..;%..&.2..6…4.;..n8…c..1)“…).Hv.e6…+&..
0240: ubE…~...... .t.N.....&.. …w2FZ…D..V%d|l..$…
0280: …I..W.T-…1.p^.Et..M..G…p6..Xp.4.'…s…p…+
02c0: ..L.<%.@..Y.X_..L[c%n…w[.r@..@V..."....8}m..D.,c!..d+..^..T.. 0300: .....3g:........<.L..#PZ... >.Z..=.YIs.$..l+'.=..5.nx.......bu.; 0340: ..Y.....k.."…(M…d..e.]…<…Z.. …C…@..w_..]G
0380: Y.1.,.YZw…L..8…Bp..p@v…a:.A.S’..!..,..Op6..R
03c0: .h.g.D7…$..N…W1z…8. .i.#..K..3|..o…i.zc.%…
0400: O <.7..z.hy……z^…o..Y.WN…?L…j.eDW..9..@]..DX…
0440: 5.-…&.o.e…
.L..$..mqw.l.C.q…v’Gk.@…XQ5..4..[.X.1
0480: m.. :,.2.Wi…-..*Y.h5..[…y.2…K..r..ja5…x(.V..T.xLE+q
04c0: .a…}.‘=…(l.{..6…+.2…MJ..’…5.z4..N4<..
0500: 5…L{.Y..$2…2.5.1..'O.?.S.U..m6..FO.JR…A5..1…d…7..rw.
0540: ..Ei.y.c…I..NS…q..3Wm…s&.c.O.U…i..R…C.io…Oh.. .
0580: …...H.Ix:....I.......e.........%......r.q\.4.XB|.!Z.....>J(.Q 05c0: ....5...[.X.O7..#.../....$.i..........p5K#!....}.....b... ..<.J. 0600: [....+0r.L.<L.#...fO.....[ 10:43:39.345333 [0-0] == Info: [SSL] ossl_bio_cf_out_write(len=1567) -> 1567, err=0 10:43:39.345928 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) -> -1, err=81 10:43:39.346435 [0-0] == Info: [SSL] ossl_populate_x509_store, path=/etc/ssl/cert.pem, blob=0 10:43:39.360866 [0-0] == Info: CAfile: /etc/ssl/cert.pem 10:43:39.360953 [0-0] == Info: CApath: /etc/ssl/certs 10:43:39.361041 [0-0] == Info: [SSL] SSL_connect() -> err=-1, detail=2 10:43:39.361135 [0-0] == Info: [SSL] SSL_connect() -> want recv 10:43:39.361342 [0-0] == Info: [SSL] cf_connect() -> 0, done=0 10:43:39.361407 [0-0] == Info: [HTTPS-CONNECT] connect -> 0, done=0 10:43:39.361528 [0-0] == Info: [HTTPS-CONNECT] Curl_conn_connect(block=0) -> 0, done=0 10:43:39.361649 [0-0] == Info: [SSL] adjust_pollset, POLLIN fd=4 10:43:39.361717 [0-0] == Info: [HTTPS-CONNECT] adjust_pollset -> 1 socks 10:43:39.363739 [0-0] == Info: [SSL] cf_connect() 10:43:39.363803 [0-0] == Info: [SSL] ossl_connect, step2 10:43:39.363894 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) -> 5, err=0 10:43:39.364018 [0-0] <= Recv SSL data, 5 bytes (0x5) 0000: ..... 10:43:39.364117 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=1210) -> 1210, err=0 10:43:39.364288 [0-0] == Info: TLSv1.3 (IN), TLS handshake, Server hello (2): 10:43:39.364384 [0-0] <= Recv SSL data, 1210 bytes (0x4ba) 0000: ......o;.e..o.X.v.3.?-…3..K.f…# .C…JdBv..I…QQ..-…$.
0040: …n.+…3.d…l@..A.1.l... 9f.....I.....3.:y.k…
0080: …=D.7?..F…
…QZ…QIqb..r..[..]&^..e…H.%OVo.9…
00c0: >n.8.2&6E…q.I……Y.M..F…r..4.c.).p!..[A^…}g…yJ
0100: ….CM!‘…:.’:..f…zm…tI..b{..n.ib..^…x…P
0140: ,$Q…s6tt=..9w.+…C.r…}".1.B…0…cve…a!.2…$…^..J.
0180: <7.o…
…wm.(…UT.8..R..Y..!3..M…W.R…D.1.9.”.%f..6…
01c0: ..k..-g..k6..c…z..7Z=.>..A)…NW…X…R~…&…#7…
0200: …!.._H..)..U.XFv..5QF$..3.“i…o…k.3;…”..6.e}I..!
0240: …Q…N..S…2u…Y5.uC…“Y?G.X.j…Y…v.dR@…y..U
0280: qK…d.J.?.V.a..M.e.NY…C…n.B..HI5:.x…{d.2…!.#D
02c0: ..#i.t…Vb|R0…V8...o.z./9..JL".2|[.M,.....*.y..[q^L..p...^. 0300: ..B0......IH.C.......QP(.......c(.........e...dsMY.A..1>.S.$.... 0340: .h*........B"Y..J..X#..T.&...............0o.....7....Wm.A@.....| 0380: .....c...K8X.3..MR..j.aQV..\].'*..x....O.3.<*}@.Y..!.3j.w."O.z.# 03c0: .........N...u....B5Q..=…sl.>…/…!..M.a..m…E;.
0400: K…w. B……C…8..8_LlT4..%.>z..0…1…;.Wn#]Z>|H./h…
0440: …<..wp.5..)..6..4…^.c..W.>.2p.%….}(..’…t..:k
0480: . .'.-.w..P…=.8…JC..T.-.7..h.X…e.+.xx…R…)
10:43:39.366970 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=0
10:43:39.367056 [0-0] <= Recv SSL data, 5 bytes (0x5)
0000: …
10:43:39.367123 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=1) → 1, err=0
10:43:39.367192 [0-0] == Info: TLSv1.3 (IN), TLS change cipher, Change cipher spec (1):
10:43:39.367274 [0-0] <= Recv SSL data, 1 bytes (0x1)
0000: .
10:43:39.367387 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=0
10:43:39.367496 [0-0] <= Recv SSL data, 5 bytes (0x5)
0000: …
10:43:39.367597 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=32) → 32, err=0
10:43:39.367683 [0-0] <= Recv SSL data, 1 bytes (0x1)
0000: .
10:43:39.367788 [0-0] == Info: TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
10:43:39.368000 [0-0] <= Recv SSL data, 15 bytes (0xf)
0000: …h2
10:43:39.368119 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=0
10:43:39.368222 [0-0] <= Recv SSL data, 5 bytes (0x5)
0000: …-
10:43:39.368319 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=2861) → 2861, err=0
10:43:39.368420 [0-0] <= Recv SSL data, 1 bytes (0x1)
0000: .
10:43:39.368487 [0-0] == Info: TLSv1.3 (IN), TLS handshake, Certificate (11):
10:43:39.368592 [0-0] <= Recv SSL data, 2844 bytes (0xb1c)
0000: …0…0…}%.e…A<0….H…031.0
0040: …U…US1.0…U…Let’s Encrypt1.0…U…R120…251130171725
0080: Z..260228171724Z0.1.0…U…nc.domain.nl0.."0…
.H…
00c0: …0…H…D…F..n.w…“…@…0…,..S#
0100: …t..'58…%.xu.I.UUK…3E..+.C#.N.]…;……v…
0140: ‘>..0…L.zS…]..-M..J.@.;…fazI…):.L…y.kR{S…c.
0180: .dHDT.cd…”…“-I.b6.M..2.j..-N…Lz.~l…,..;…z.&.|.%T
01c0: ,..w.C…2[…w.>.“g…<N.?.F…:..{..S…‘g…
0200: $..+.|(…j…2US…bK|W…h.^D…2.
#O*…I4..)…
0240: k.s…c..D…(.|.s..l[…E…-.z_…&N.%=..e..W.’/.’…z.”.
0280: ..l..k%a..U..Q.”…#..x..S.IO.)…xB-:a4?.9%,D.1I……)..1.koa
02c0: ..2…D]c.U… 0…0…U…0…U.%..0…+…
0300: ..+…0…U…0.0…U…-.i.\ v…o..(B..60…U.#..
0340: 0…).-.o1..L.x>…03..+…‘0%0#..+…0…http://r12
0380: .i.lencr.org/0…U…0…nc.domain.nl0…U. ..0.0…g…0
03c0: …U…‘0%0#.!..http://r12.c.lencr.org/61.crl0…+…y…
0400: …u.d..l…O(…5’…}…F0D. …J
0440: …a3u…n?Uy:…e… F..b.K…G..0.’+.0..].<..{.w
0480: ..W…>3.,…=q2%.!.%.a.N!..H0F.!..5..J…-..
04c0: .L.M…. .......<...!..Sar..u.N1R....v...i...8.BB..9!<0...*.H.. 0500: ...........9…L…O..‘s…i}~…y..P…Z..X].r.b.v…68.g
0540: ..E..4=…pI/..)..h…o.Y…6y..…{O…ok}…F..o.1..6..Y
0580: 0E=…N…e…$..5..m…H.gZ.F.Q%..5.R.?w.$..F…z…@…
05c0: …!..“…D…4-…V..K…M..a.?..[m…|…’…h.
0600: ..Q…0…0…2Kp…q.@…&<0….H…0
0640: O1.0…U…US1)0’..U… Internet Security Research Group1.0…U
0680: …ISRG Root X10…240313000000Z..270312235959Z031.0…U…US1
06c0: .0…U…Let’s Encrypt1.0…U…R120..“0….H…0..
0700: …(t…;…Ku.,…2~6…1…Q=L.(n.U1..”]r.-..M
0740: @<..#.x7..e24..q…[…s.m…Ea.5=…j…..
0780: …q.;t.<...ZKN...*s\.ae...<..No....F...M*c..f...p.Peo;t.H...X 07c0: ]-#.^..........M..z.'....-........79...,A.....!.Y...:|.\..b..(.. 0800: .<............0..0...U...........0...U.%..0...+.........+....... 0840: 0...U.......0.......0...U........).-.o1..L.x>......0...U.#..0... 0880: y.Y.{....s.....X...n02..+........&0$0"..+.....0...``http://x1.i.le`` 08c0: ``ncr.org/0...U``. ..0.0...g.....0'..U... 0.0.......``http://x1.c.lenc`` 0900: ``r.org/0``...*.H..............u...jvHe2...D..v......v.....n..V...K. 0940: ...xH.u...F{.+ …E.j.R….mF.RP.@…}..X…c.f..w;
0980: …&..@…W.\qA.0 …KP(…~t@..Z.O.…Y..yn#M
09c0: …)j…B…Nd {..1..h.G…x..NJ.i$K7{Q.k:?R…XN…o.1IH
0a00: ..?.. =…8#.q.@…F4.jN…c
.i.G..”.KH..uT…S.{.6M…
0a40: .J.3<.i….T.M…Z..z6.$..XR..5.^-.t.b&…1)…b.h.w…
0a80: ..Y..fK.P…M.KaO. ..H.1......w.......F...K.......6i?.hKt.. 0ac0: .P.jz...H..}]a...f.u..^...c.#.P....u7>u...%(.!N..:......_.Q.F... 0b00: ....W.........n....N..|.v;.. 10:43:39.373847 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) -> 5, err=0 10:43:39.373983 [0-0] <= Recv SSL data, 5 bytes (0x5) 0000: ..... 10:43:39.374076 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=537) -> 537, err=0 10:43:39.374181 [0-0] <= Recv SSL data, 1 bytes (0x1) 0000: . 10:43:39.374258 [0-0] == Info: TLSv1.3 (IN), TLS handshake, CERT verify (15): 10:43:39.374359 [0-0] <= Recv SSL data, 520 bytes (0x208) 0000: ........F.j.......N......q...Yr.g.z.p...E.j+...J...#..eN.%.zWS.k 0040: .H/X..2.......w.&...N.…l.6.^..”.BVC#.d..“2…3/.1…E
0080: .;UE…0.Y..z…>..E.B4^..R.e..i.34…g.)n..L:\o..
00c0: .+…j..y…Be…svi.L.A.b…]-.|.0…E... .....e..x../R6$ 0100: .......I......$.+z..r..47+.<&.. .a...S*.......b.w..0.........$\. 0140: =-....G.....4x....&..w.].,....?.@F.....Z.O..K.,.h...,.n..K.....) 0180: H......[<l.....&.....q.%&...m..#.._Aa...]6.J…%…m…x.?
01c0: …7m8…FM..L/…n..sj.2.8.=&.”..-c
…s.“…l….=
0200: l…(h..
10:43:39.375423 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=0
10:43:39.375510 [0-0] <= Recv SSL data, 5 bytes (0x5)
0000: …5
10:43:39.375558 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=53) → 53, err=0
10:43:39.375641 [0-0] <= Recv SSL data, 1 bytes (0x1)
0000: .
10:43:39.375781 [0-0] == Info: TLSv1.3 (IN), TLS handshake, Finished (20):
10:43:39.375890 [0-0] <= Recv SSL data, 36 bytes (0x24)
0000: … .g..*.,.{(}.(”..fn…)tr…%*
10:43:39.376076 [0-0] => Send SSL data, 5 bytes (0x5)
0000: …
10:43:39.376165 [0-0] == Info: TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
10:43:39.376286 [0-0] => Send SSL data, 1 bytes (0x1)
0000: .
10:43:39.376381 [0-0] => Send SSL data, 5 bytes (0x5)
0000: …5
10:43:39.376458 [0-0] => Send SSL data, 1 bytes (0x1)
0000: .
10:43:39.376551 [0-0] == Info: TLSv1.3 (OUT), TLS handshake, Finished (20):
10:43:39.376654 [0-0] => Send SSL data, 36 bytes (0x24)
0000: … .N’Y. d.uC7…/..O…^(..5$n..
10:43:39.376814 [0-0] == Info: [SSL] ossl_bio_cf_out_write(len=64) → 64, err=0
10:43:39.376979 [0-0] == Info: SSL connection using TLSv1.3 / TLS_AES_128_GCM_SHA256 / X25519MLKEM768 / RSASSA-PSS
10:43:39.377156 [0-0] == Info: ALPN: server accepted h2
10:43:39.377227 [0-0] == Info: [SSL] ossl_connect, step3
10:43:39.377303 [0-0] == Info: Server certificate:
10:43:39.377367 [0-0] == Info: subject: CN=nc.domain.nl
10:43:39.377464 [0-0] == Info: start date: Nov 30 17:17:25 2025 GMT
10:43:39.377541 [0-0] == Info: expire date: Feb 28 17:17:24 2026 GMT
10:43:39.377657 [0-0] == Info: subjectAltName: host “nc.domain.nl” matched cert’s “nc.domain.nl”
10:43:39.377781 [0-0] == Info: issuer: C=US; O=Let’s Encrypt; CN=R12
10:43:39.377859 [0-0] == Info: SSL certificate verify ok.
10:43:39.377910 [0-0] == Info: Certificate level 0: Public key type RSA (4096/152 Bits/secBits), signed using sha256WithRSAEncryption
10:43:39.378003 [0-0] == Info: Certificate level 1: Public key type RSA (2048/112 Bits/secBits), signed using sha256WithRSAEncryption
10:43:39.378097 [0-0] == Info: Certificate level 2: Public key type RSA (4096/152 Bits/secBits), signed using sha256WithRSAEncryption
10:43:39.378216 [0-0] == Info: [SSL] ossl_connect, done
10:43:39.378283 [0-0] == Info: [SSL] cf_connect() → 0, done=1
10:43:39.378335 [0-0] == Info: [HTTPS-CONNECT] connect+handshake h2: 59ms, 1st data: 44ms
10:43:39.378452 [0-0] == Info: [HTTP/2] [0] created h2 session
10:43:39.378549 [0-0] == Info: [HTTP/2] [0] → FRAME[SETTINGS, len=18]
10:43:39.378631 [0-0] == Info: [HTTP/2] [0] → FRAME[WINDOW_UPDATE, incr=1048510465]
10:43:39.378724 [0-0] == Info: [HTTP/2] cf_connect() → 0, 1,
10:43:39.378800 [0-0] == Info: [HTTPS-CONNECT] connect → 0, done=1
10:43:39.378892 [0-0] == Info: [HTTPS-CONNECT] Curl_conn_connect(block=0) → 0, done=1
10:43:39.378994 [0-0] == Info: Connected to nc.domain.nl (192.168.0.5) port 443
10:43:39.379082 [0-0] == Info: using HTTP/2
10:43:39.379144 [0-0] == Info: [HTTP/2] [1] OPENED stream for https://nc.domain.nl:443/hosting/discovery
10:43:39.379264 [0-0] == Info: [HTTP/2] [1] [:method: GET]
10:43:39.379347 [0-0] == Info: [HTTP/2] [1] [:scheme: https]
10:43:39.379409 [0-0] == Info: [HTTP/2] [1] [:authority: nc.domain.nl]
10:43:39.379492 [0-0] == Info: [HTTP/2] [1] [:path: /hosting/discovery]
10:43:39.379573 [0-0] == Info: [HTTP/2] [1] [user-agent: curl/8.14.1]
10:43:39.379690 [0-0] == Info: [HTTP/2] [1] [accept: /]
10:43:39.379769 [0-0] == Info: [HTTP/2] [1] submit → 95, 0
10:43:39.379874 [0-0] == Info: [HTTP/2] [1] → FRAME[HEADERS, len=46, hend=1, eos=1]
10:43:39.380010 [0-0] => Send SSL data, 5 bytes (0x5)
0000: …
10:43:39.380107 [0-0] => Send SSL data, 1 bytes (0x1)
0000: .
10:43:39.380217 [0-0] == Info: [SSL] ossl_bio_cf_out_write(len=141) → 141, err=0
10:43:39.380327 [0-0] == Info: [HTTP/2] [0] egress: wrote 119 bytes
10:43:39.380428 [0-0] == Info: [HTTP/2] [1] cf_send(len=95) → 95, 0, eos=1, h2 windows 65535-65535 (stream-conn), buffers 0-0 (stream-conn)
10:43:39.380590 [0-0] => Send header, 95 bytes (0x5f)
0000: GET /hosting/discovery HTTP/2
001f: Host: nc.domain.nl
0037: User-Agent: curl/8.14.1
0050: Accept: /
005d:
10:43:39.380870 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=0
10:43:39.380976 [0-0] <= Recv SSL data, 5 bytes (0x5)
0000: …
10:43:39.381085 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=139) → 139, err=0
10:43:39.381262 [0-0] <= Recv SSL data, 1 bytes (0x1)
0000: .
10:43:39.381408 [0-0] == Info: TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
10:43:39.381541 [0-0] <= Recv SSL data, 122 bytes (0x7a)
0000: …v..:.L9…iX#.m…}.=…o.<.we!;..Qw%`.?K.AeZ..EB…
0040: …u..g>3{.U…I…u…>.a..y..lX…a.eB…
10:43:39.381929 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=0
10:43:39.382053 [0-0] <= Recv SSL data, 5 bytes (0x5)
0000: …8
10:43:39.382151 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=56) → 56, err=0
10:43:39.382274 [0-0] <= Recv SSL data, 1 bytes (0x1)
0000: .
10:43:39.382370 [0-0] == Info: [SSL] cf_recv(len=16384) → 39, 0
10:43:39.382483 [0-0] == Info: [HTTP/2] [0] ingress: read 39 bytes
10:43:39.382589 [0-0] == Info: [HTTP/2] [0] ← FRAME[SETTINGS, len=30]
10:43:39.382675 [0-0] == Info: [HTTP/2] [0] MAX_CONCURRENT_STREAMS: 250
10:43:39.382722 [0-0] == Info: [HTTP/2] [0] ENABLE_PUSH: TRUE
10:43:39.382803 [0-0] == Info: [HTTP/2] [0] notify MAX_CONCURRENT_STREAMS: 250
10:43:39.382918 [0-0] == Info: [HTTP/2] [1] DRAIN select_bits=1
10:43:39.382989 [0-0] == Info: [HTTP/2] [0] progress ingress: inbufg=0
10:43:39.383100 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=0
10:43:39.383182 [0-0] <= Recv SSL data, 5 bytes (0x5)
0000: …
10:43:39.383281 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=30) → 30, err=0
10:43:39.383369 [0-0] <= Recv SSL data, 1 bytes (0x1)
0000: .
10:43:39.383435 [0-0] == Info: [SSL] cf_recv(len=16384) → 13, 0
10:43:39.383513 [0-0] == Info: [HTTP/2] [0] ingress: read 13 bytes
10:43:39.383606 [0-0] == Info: [HTTP/2] [0] ← FRAME[WINDOW_UPDATE, incr=983041]
10:43:39.383711 [0-0] == Info: [HTTP/2] [0] progress ingress: inbufg=0
10:43:39.383815 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=0
10:43:39.383907 [0-0] <= Recv SSL data, 5 bytes (0x5)
0000: …
10:43:39.384011 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=26) → 26, err=0
10:43:39.384100 [0-0] <= Recv SSL data, 1 bytes (0x1)
0000: .
10:43:39.384165 [0-0] == Info: [SSL] cf_recv(len=16384) → 9, 0
10:43:39.384252 [0-0] == Info: [HTTP/2] [0] ingress: read 9 bytes
10:43:39.384319 [0-0] == Info: [HTTP/2] [0] ← FRAME[SETTINGS, ack=1]
10:43:39.384390 [0-0] == Info: [HTTP/2] [0] progress ingress: inbufg=0
10:43:39.384450 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=0
10:43:39.384541 [0-0] <= Recv SSL data, 5 bytes (0x5)
0000: …
10:43:39.384627 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=138) → 138, err=0
10:43:39.384728 [0-0] <= Recv SSL data, 1 bytes (0x1)
0000: .
10:43:39.384781 [0-0] == Info: [SSL] cf_recv(len=16384) → 121, 0
10:43:39.384851 [0-0] == Info: [HTTP/2] [0] ingress: read 121 bytes
10:43:39.384933 [0-0] <= Recv header, 13 bytes (0xd)
0000: HTTP/2 200
10:43:39.385005 [0-0] == Info: [WRITE] [OUT] wrote 13 header bytes → 13
10:43:39.385080 [0-0] == Info: [WRITE] [PAUSE] writing 13/13 bytes of type c → 0
10:43:39.385160 [0-0] == Info: [WRITE] download_write header(type=c, blen=13) → 0
10:43:39.385272 [0-0] == Info: [WRITE] client_write(type=c, len=13) → 0
10:43:39.385359 [0-0] == Info: [HTTP/2] [1] local window update by 10420224
10:43:39.385454 [0-0] == Info: [HTTP/2] [1] status: HTTP/2 200
10:43:39.385536 [0-0] <= Recv header, 24 bytes (0x18)
0000: content-type: text/xml
10:43:39.385633 [0-0] == Info: [WRITE] header_collect pushed(type=1, len=24) → 0
10:43:39.385738 [0-0] == Info: [WRITE] [OUT] wrote 24 header bytes → 24
10:43:39.385853 [0-0] == Info: [WRITE] [PAUSE] writing 24/24 bytes of type 4 → 0
10:43:39.385940 [0-0] == Info: [WRITE] download_write header(type=4, blen=24) → 0
10:43:39.386038 [0-0] == Info: [WRITE] client_write(type=4, len=24) → 0
10:43:39.386107 [0-0] == Info: [HTTP/2] [1] header: content-type: text/xml
10:43:39.386189 [0-0] <= Recv header, 33 bytes (0x21)
0000: date: Sun, 14 Dec 2025 09:43:39
10:43:39.386280 [0-0] == Info: [WRITE] header_collect pushed(type=1, len=33) → 0
10:43:39.386365 [0-0] == Info: [WRITE] [OUT] wrote 33 header bytes → 33
10:43:39.386424 [0-0] == Info: [WRITE] [PAUSE] writing 33/33 bytes of type 4 → 0
10:43:39.386517 [0-0] == Info: [WRITE] download_write header(type=4, blen=33) → 0
10:43:39.386602 [0-0] == Info: [WRITE] client_write(type=4, len=33) → 0
10:43:39.386677 [0-0] == Info: [HTTP/2] [1] header: date: Sun, 14 Dec 2025 09:43:39
10:43:39.386807 [0-0] <= Recv header, 42 bytes (0x2a)
0000: last-modified: Sun, 14 Dec 2025 09:43:39
10:43:39.386958 [0-0] == Info: [WRITE] header_collect pushed(type=1, len=42) → 0
10:43:39.387065 [0-0] == Info: [WRITE] [OUT] wrote 42 header bytes → 42
10:43:39.387155 [0-0] == Info: [WRITE] [PAUSE] writing 42/42 bytes of type 4 → 0
10:43:39.387286 [0-0] == Info: [WRITE] download_write header(type=4, blen=42) → 0
10:43:39.387369 [0-0] == Info: [WRITE] client_write(type=4, len=42) → 0
10:43:39.387437 [0-0] == Info: [HTTP/2] [1] header: last-modified: Sun, 14 Dec 2025 09:43:39
10:43:39.387549 [0-0] <= Recv header, 30 bytes (0x1e)
0000: referrer-policy: same-origin
10:43:39.387637 [0-0] == Info: [WRITE] header_collect pushed(type=1, len=30) → 0
10:43:39.387715 [0-0] == Info: [WRITE] [OUT] wrote 30 header bytes → 30
10:43:39.387798 [0-0] == Info: [WRITE] [PAUSE] writing 30/30 bytes of type 4 → 0
10:43:39.387879 [0-0] == Info: [WRITE] download_write header(type=4, blen=30) → 0
10:43:39.387977 [0-0] == Info: [WRITE] client_write(type=4, len=30) → 0
10:43:39.388508 [0-0] == Info: [HTTP/2] [1] header: referrer-policy: same-origin
10:43:39.388602 [0-0] <= Recv header, 16 bytes (0x10)
0000: via: 1.1 Caddy
10:43:39.388730 [0-0] == Info: [WRITE] header_collect pushed(type=1, len=16) → 0
10:43:39.388819 [0-0] == Info: [WRITE] [OUT] wrote 16 header bytes → 16
10:43:39.388903 [0-0] == Info: [WRITE] [PAUSE] writing 16/16 bytes of type 4 → 0
10:43:39.389038 [0-0] == Info: [WRITE] download_write header(type=4, blen=16) → 0
10:43:39.389146 [0-0] == Info: [WRITE] client_write(type=4, len=16) → 0
10:43:39.389250 [0-0] == Info: [HTTP/2] [1] header: via: 1.1 Caddy
10:43:39.389336 [0-0] <= Recv header, 33 bytes (0x21)
0000: x-content-type-options: nosniff
10:43:39.389452 [0-0] == Info: [WRITE] header_collect pushed(type=1, len=33) → 0
10:43:39.389542 [0-0] == Info: [WRITE] [OUT] wrote 33 header bytes → 33
10:43:39.389624 [0-0] == Info: [WRITE] [PAUSE] writing 33/33 bytes of type 4 → 0
10:43:39.389709 [0-0] == Info: [WRITE] download_write header(type=4, blen=33) → 0
10:43:39.389810 [0-0] == Info: [WRITE] client_write(type=4, len=33) → 0
10:43:39.389909 [0-0] == Info: [HTTP/2] [1] header: x-content-type-options: nosniff
10:43:39.390005 [0-0] <= Recv header, 23 bytes (0x17)
0000: content-length: 31524
10:43:39.390131 [0-0] == Info: [WRITE] header_collect pushed(type=1, len=23) → 0
10:43:39.390247 [0-0] == Info: [WRITE] [OUT] wrote 23 header bytes → 23
10:43:39.390363 [0-0] == Info: [WRITE] [PAUSE] writing 23/23 bytes of type 4 → 0
10:43:39.390490 [0-0] == Info: [WRITE] download_write header(type=4, blen=23) → 0
10:43:39.390616 [0-0] == Info: [WRITE] client_write(type=4, len=23) → 0
10:43:39.390727 [0-0] == Info: [HTTP/2] [1] header: content-length: 31524
10:43:39.390831 [0-0] == Info: [HTTP/2] [1] ← FRAME[HEADERS, len=112, hend=1, eos=0]
10:43:39.390959 [0-0] <= Recv header, 2 bytes (0x2)
0000:
10:43:39.391043 [0-0] == Info: [WRITE] header_collect pushed(type=1, len=2) → 0
10:43:39.391172 [0-0] == Info: [WRITE] [OUT] wrote 2 header bytes → 2
10:43:39.391279 [0-0] == Info: [WRITE] [PAUSE] writing 2/2 bytes of type 4 → 0
10:43:39.391400 [0-0] == Info: [WRITE] download_write header(type=4, blen=2) → 0
10:43:39.391504 [0-0] == Info: [WRITE] client_write(type=4, len=2) → 0
10:43:39.391613 [0-0] == Info: [HTTP/2] [0] progress ingress: inbufg=0
10:43:39.391702 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=0
10:43:39.391798 [0-0] <= Recv SSL data, 5 bytes (0x5)
0000: …;
10:43:39.391889 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5947) → 5947, err=0
10:43:39.391974 [0-0] <= Recv SSL data, 1 bytes (0x1)
0000: .
10:43:39.392033 [0-0] == Info: [SSL] cf_recv(len=16384) → 5930, 0
10:43:39.392089 [0-0] == Info: [HTTP/2] [0] ingress: read 5930 bytes
10:43:39.392207 [0-0] <= Recv data, 5921 bytes (0x1721)
0000: . .. <!
0040: – Writer documents -->. <app favIconUrl=“https://nc.
0080: domain.nl/browser/a0576a3364/images/x-office-document.svg” name=
00c0: “writer”>. . <action default=“true” ext=“odt” name=“edit” ur
0180: lsrc=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
01c0: <action default=“true” ext=“fodt” name=“edit” urlsrc
0200: =“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
0240: . <action def
0280: ault=“true” ext=“stw” name=“view” urlsrc=“https://nc.domain.
02c0: nl/browser/a0576a3364/cool.html?”/>. <action default=
0300: “true” ext=“ott” name=“view” urlsrc=“https://nc.domain.nl/br
0340: owser/a0576a3364/cool.html?”/>. .
0380: .
0400: . <!
0480: – OOXML wordprocessing -->. <action default=“true” e
04c0: xt=“docx” name=“edit” urlsrc=“https://nc.domain.nl/browser/a
0500: 0576a3364/cool.html?”/>. . . <action default=“true” ext=“dotm” na
0640: me=“view” urlsrc=“https://nc.domain.nl/browser/a0576a3364/co
0680: ol.html?”/>. . <action defa
06c0: ult=“true” ext=“wpd” name=“view” urlsrc=“https://nc.domain.n
0700: l/browser/a0576a3364/cool.html?”/>. . <action default=“true”
07c0: ext=“hwp” name=“view” urlsrc=“https://nc.domain.nl/browser/
0800: a0576a3364/cool.html?”/>. <action default=“true” ext=
0840: “wps” name=“view” urlsrc=“https://nc.domain.nl/browser/a0576
0880: a3364/cool.html?”/>. <action default=“true” ext=“wri”
08c0: name=“view” urlsrc=“https://nc.domain.nl/browser/a0576a3364
0900: /cool.html?”/>. <action default=“true” ext=“lrf” name
0940: =“view” urlsrc=“https://nc.domain.nl/browser/a0576a3364/cool
0980: .html?”/>. . <action default=“true” ext=“rtf” name=“edit” url
0a40: src=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
0a80: .
0b00: .
0b80: . <act
0c00: ion default=“true” ext=“pages” name=“view” urlsrc=“https://nc.
0c40: domain.nl/browser/a0576a3364/cool.html?”/>. <action
0c80: default=“true” ext=“abw” name=“view” urlsrc=“https://nc.dom
0cc0: ain.nl/browser/a0576a3364/cool.html?”/>. <action defa
0d00: ult=“true” ext=“602” name=“view” urlsrc=“https://nc.domain.n
0d40: l/browser/a0576a3364/cool.html?”/>. .. <app
0d80: name=“writer-global”>.
0dc0: . <action default=“true” ext=“sxg” name=“view” urlsrc
0e00: =“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
0e40: .
0ec0: . <action
0f00: default=“true” ext=“otm” name=“view” urlsrc=“https://nc.dom
0f40: ain.nl/browser/a0576a3364/cool.html?”/>. ..
0f80: . . .. <!-- Calc documents -
1040: ->. .
10c0: . <ac
1140: tion default=“true” ext=“ods” name=“edit” urlsrc=“https://nc.n
1180: domain.nl/browser/a0576a3364/cool.html?”/>. <action
11c0: default=“true” ext=“fods” name=“edit” urlsrc=“https://nc.dom
1200: ain.nl/browser/a0576a3364/cool.html?”/>. . <action default=“true” e
1280: xt=“stc” name=“view” urlsrc=“https://nc.domain.nl/browser/a0
12c0: 576a3364/cool.html?”/>. . . <act
1380: ion default=“true” ext=“xls” name=“edit” urlsrc=“https://nc.
13c0: domain.nl/browser/a0576a3364/cool.html?”/>. <action d
1400: efault=“true” ext=“xla” name=“edit” urlsrc=“https://nc.domai
1440: n.nl/browser/a0576a3364/cool.html?”/>. . <action default=“true” ext=“xltx” name=
14c0: “view” urlsrc=“https://nc.domain.nl/browser/a0576a3364/cool.
1500: html?”/>. . <action default=“true” ext=“xlsx” name=“edit” u
15c0: rlsrc=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>
1600: . <action default=“true” ext=“xlsb” name=“edit” urlsr
1640: c=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
1680: .
1700: .
    <!-- Writer documents -->
    <app favIconUrl="https://nc.domain.nl/browser/a0576a3364/images/x-office-document.svg" name="writer">
        <action default="true" ext="sxw" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="odt" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="fodt" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- Text template documents -->
        <action default="true" ext="stw" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="ott" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- MS Word -->
        <action default="true" ext="doc" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="dot" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- OOXML wordprocessing -->
        <action default="true" ext="docx" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="docm" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="dotx" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="dotm" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- Others -->
        <action default="true" ext="wpd" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="pdb" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="hwp" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="wps" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="wri" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="lrf" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="mw" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="rtf" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="txt" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="fb2" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="cwk" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="pages" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="abw" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="602" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
    </app>
    <app name="writer-global">
        <!-- Text master documents -->
        <action default="true" ext="sxg" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="odm" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- Writer master document templates -->
        <action default="true" ext="otm" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
    </app>
    <app name="writer-web">
        <action default="true" ext="oth" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
    </app>
    <!-- Calc documents -->
    <app favIconUrl="https://nc.domain.nl/browser/a0576a3364/images/x-office-spreadsheet.svg" name="calc">
        <action default="true" ext="sxc" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="ods" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="fods" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- Spreadsheet template documents -->
        <action default="true" ext="stc" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="ots" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- MS Excel -->
        <action default="true" ext="xls" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="xla" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- OOXML spreadsheet -->
        <action default="true" ext="xltx" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="xltm" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="xlsx" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="xlsb" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="xlsm" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- Others -->
        10:43:39.400876 [0-0] == Info: [WRITE] [OUT] wrote 5921 body bytes -> 5921
10:43:39.400991 [0-0] == Info: [WRITE] [PAUSE] writing 5921/5921 bytes of type 1 → 0
10:43:39.401125 [0-0] == Info: [WRITE] download_write body(type=1, blen=5921) → 0
10:43:39.401240 [0-0] == Info: [WRITE] client_write(type=1, len=5921) → 0
10:43:39.401341 [0-0] == Info: [WRITE] xfer_write_resp(len=5921, eos=0) → 0
10:43:39.401437 [0-0] == Info: [HTTP/2] [0] progress ingress: inbufg=0
10:43:39.401530 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=0
10:43:39.401602 [0-0] <= Recv SSL data, 5 bytes (0x5)
0000: …
10:43:39.401685 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=7133) → 7133, err=0
10:43:39.401806 [0-0] <= Recv SSL data, 1 bytes (0x1)
0000: .
10:43:39.401938 [0-0] == Info: [SSL] cf_recv(len=16384) → 7116, 0
10:43:39.402034 [0-0] == Info: [HTTP/2] [0] ingress: read 7116 bytes
10:43:39.402113 [0-0] <= Recv data, 7116 bytes (0x1bcc)
0000: . <acti
0080: on default=“true” ext=“slk” name=“edit” urlsrc=“https://nc.d
00c0: omain.nl/browser/a0576a3364/cool.html?”/>. <action de
0100: fault=“true” ext=“csv” name=“edit” urlsrc=“https://nc.domain
0140: .nl/browser/a0576a3364/cool.html?”/>. <action default
0180: =“true” ext=“tsv” name=“edit” urlsrc=“https://nc.domain.nl/b
01c0: rowser/a0576a3364/cool.html?”/>. . <action default=“true” ex
0280: t=“wk1” name=“view” urlsrc=“https://nc.domain.nl/browser/a05
02c0: 76a3364/cool.html?”/>. . <action default=“true” ext=“xlr” na
0380: me=“view” urlsrc=“https://nc.domain.nl/browser/a0576a3364/co
03c0: ol.html?”/>. . <action default=“true” ext=“qpw” name=“view”
0480: urlsrc=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/
04c0: >. <action default=“true” ext=“wb1” name=“view” urlsr
0500: c=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
0540: .
05c0: . <
0640: action default=“true” ext=“gnumeric” name=“view” urlsrc=“https:/
0680: /nc.domain.nl/browser/a0576a3364/cool.html?”/>. <
06c0: action default=“true” ext=“numbers” name=“view” urlsrc=“https://
0700: nc.domain.nl/browser/a0576a3364/cool.html?”/>.
0740: .. . . <action default=“true” e
0800: xt=“sxi” name=“view” urlsrc=“https://nc.domain.nl/browser/a0
0840: 576a3364/cool.html?”/>. . <action default=“true” ext=“fodp”
0900: name=“edit” urlsrc=“https://nc.domain.nl/browser/a0576a3364/
0940: cool.html?”/>. <!-- Presentation template documents -
0980: ->. <action default=“true” ext=“sti” name=“view” urls
09c0: rc=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
0a00: .
0a80: . <action default=“true” e
0ac0: xt=“ppt” name=“edit” urlsrc=“https://nc.domain.nl/browser/a0
0b00: 576a3364/cool.html?”/>. . .
0bc0: .
0c40: . <a
0cc0: ction default=“true” ext=“potx” name=“view” urlsrc=“https://nc
0d00: .domain.nl/browser/a0576a3364/cool.html?”/>. <actio
0d40: n default=“true” ext=“potm” name=“view” urlsrc=“https://nc.d
0d80: omain.nl/browser/a0576a3364/cool.html?”/>. <action de
0dc0: fault=“true” ext=“ppsx” name=“edit” urlsrc=“https://nc.domai
0e00: n.nl/browser/a0576a3364/cool.html?”/>. <!-- Others –
0e40: >. <action default=“true” ext=“cgm” name=“view” urlsr
0e80: c=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
0ec0: .
0f40: .. . <app name=“draw”
0f80: >. <action default=“true” ext=“sxd” name=“view” urlsr
0fc0: c=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
1000: .
1080: .
1100: . <action default=
1140: “true” ext=“std” name=“view” urlsrc=“https://nc.domain.nl/br
1180: owser/a0576a3364/cool.html?”/>. . .
1240: . . <action default=“true”
1340: ext=“emf” name=“view” urlsrc=“https://nc.domain.nl/browser/a
1380: 0576a3364/cool.html?”/>. . <action default=“true” ext=“cdr”
1440: name=“view” urlsrc=“https://nc.domain.nl/browser/a0576a3364/
1480: cool.html?”/>. <action default=“true” ext=“vsd” name=
1500: html?”/>. . <action default=“true” ext=“vss” name=“view” ur
15c0: lsrc=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
1600: <action default=“true” ext=“pub” name=“view” urlsrc=
1640: “https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
1680: .
1700: . <ac
1780: tion default=“true” ext=“fh” name=“view” urlsrc=“https://nc.
17c0: domain.nl/browser/a0576a3364/cool.html?”/>. <action e
1800: xt=“bmp” name=“view” urlsrc=“https://nc.domain.nl/browser/a0
1840: 576a3364/cool.html?”/>. <action ext=“png” name=“view”
1880: urlsrc=“https://nc.domain.nl/browser/a0576a3364/cool.html?”
18c0: />. . <acti
1940: on ext=“tiff” name=“view” urlsrc=“https://nc.domain.nl/brows
1980: er/a0576a3364/cool.html?”/>. . .
1a80: . ..
1b00: . <!-- In fact Math documents are
1b40: not supported at all.. See: https://bugs.documentfo
1b80: undation.org/show_bug.cgi?id=97006. .
1bc0: <ac
    <!-- Impress documents -->
    <app favIconUrl="https://nc.domain.nl/browser/a0576a3364/images/x-office-presentation.svg" name="impress">
        <action default="true" ext="sxi" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="odp" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="fodp" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- Presentation template documents -->
        <action default="true" ext="sti" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="otp" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- MS PowerPoint -->
        <action default="true" ext="ppt" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="pot" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- OOXML presentation -->
        <action default="true" ext="pptx" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="pptm" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="potx" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="potm" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="ppsx" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- Others -->
        <action default="true" ext="cgm" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="key" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
    </app>
    <!-- Draw documents -->
    <app name="draw">
        <action default="true" ext="sxd" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="odg" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="fodg" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- Drawing template documents -->
        <action default="true" ext="std" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="otg" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <!-- Others -->
        <action ext="svg" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="dxf" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="emf" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="wmf" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="cdr" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="vsd" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="vsdx" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="vss" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="pub" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="p65" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="wpg" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action default="true" ext="fh" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action ext="bmp" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action ext="png" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action ext="gif" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action ext="tiff" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action ext="jpg" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action ext="jpeg" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
        <action ext="pdf" name="view_comment" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
    </app>
    <!-- Math documents -->
    <!-- In fact Math documents are not supported at all.
         See: https://bugs.documentfoundation.org/show_bug.cgi?id=97006
    <app name="math">
        <ac10:43:39.412235 [0-0] == Info: [WRITE] [OUT] wrote 7116 body bytes -> 7116
10:43:39.412309 [0-0] == Info: [WRITE] [PAUSE] writing 7116/7116 bytes of type 1 → 0
10:43:39.412435 [0-0] == Info: [WRITE] download_write body(type=1, blen=7116) → 0
10:43:39.412524 [0-0] == Info: [WRITE] client_write(type=1, len=7116) → 0
10:43:39.412628 [0-0] == Info: [WRITE] xfer_write_resp(len=7116, eos=0) → 0
10:43:39.412745 [0-0] == Info: [HTTP/2] [0] progress ingress: inbufg=0
10:43:39.412867 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=0
10:43:39.412958 [0-0] <= Recv SSL data, 5 bytes (0x5)
0000: …$
10:43:39.413025 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=3364) → 3364, err=0
10:43:39.413134 [0-0] <= Recv SSL data, 1 bytes (0x1)
0000: .
10:43:39.413206 [0-0] == Info: [SSL] cf_recv(len=16384) → 3347, 0
10:43:39.413269 [0-0] == Info: [HTTP/2] [0] ingress: read 3347 bytes
10:43:39.413349 [0-0] <= Recv data, 3347 bytes (0xd13)
0000: tion name=“view” default=“true” ext=“sxm”/>. <action
0040: name=“edit” default=“true” ext=“odf”/>. . –
0080: >.. ..
00c0: . <action ext=“” name
0100: =“view” urlsrc=“https://nc.domain.nl/browser/a0576a3364/cool
0140: .html?”/>. . . . .
0240: . .
02c0: .. . . . . . . . . <act
04c0: ion default=“true” ext=“” name=“edit” urlsrc=“https://nc.dom
0500: ain.nl/browser/a0576a3364/cool.html?”/>. ..
0540: . . <action default=“true” ext=“” name=“view”
05c0: urlsrc=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/
0600: >. . . <action default=“true” ext=“” n
0680: ame=“edit” urlsrc=“https://nc.domain.nl/browser/a0576a3364/c
06c0: ool.html?”/>. . . <action def
0740: ault=“true” ext=“” name=“edit” urlsrc=“https://nc.domain.nl/
0780: browser/a0576a3364/cool.html?”/>. .. . . <action default=“true” ext=“” name=“view” u
0840: rlsrc=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>
0880: . . . <action default=“true” ext=“” n
0900: ame=“edit” urlsrc=“https://nc.domain.nl/browser/a0576a3364/c
0940: ool.html?”/>. . . <action de
09c0: fault=“true” ext=“” name=“edit” urlsrc=“https://nc.domain.nl
0a00: /browser/a0576a3364/cool.html?”/>. .. . . <action default=“true” ext=“” name=“edit” urlsrc
0ac0: =“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
0b00: . . . . . <action default=“true”
0c40: ext=“” name=“edit” urlsrc=“https://nc.domain.nl/browser/a057
0c80: 6a3364/cool.html?”/>. .. . .
    <!-- Legacy MIME-type actions (compatibility) -->
    <app name="image/svg+xml">
        <action ext="" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
    </app>
    <app name="application/vnd.ms-powerpoint">
        <action default="true" ext="" name="edit" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
    </app>
    <app name="application/vnd.ms-excel">
    </app>
    <app name="application/vnd.sun.xml.writer">
        <action default="true" ext="" name="view" urlsrc="https://nc.domain.nl/browser/a0576a3364/cool.html?"/>
    </app>
    <app name="application/vnd.oasis.opendocument.text">
    </app>
    <app name="application/vnd.oasis.opendocument.text-flat-xml">
    </app>
    <app name="application/vnd.sun.xml.calc">
    </app>
    <app name="application/vnd.oasis.opendocument.spreadsheet">
    </app>
    <app name="application/vnd.oasis.opendocument.spreadsheet-flat-xml">
    </app>
    <app name="application/vnd.sun.xml.impress">
    </app>
    <app name="application/vnd.oasis.opendocument.presentation">
    </app>
    <app name="application/vnd.oasis.opendocument.presentation-flat-xml">
    </app>
    <app name="application/vnd.sun.xml.draw">
    </app>
    <app name="application/vnd.oasis.opendocument.graphics">
    </app>
    <app name="application/vnd.oasis.opendocument.graphics-flat-xml">
    </app>
    <!-- Chart documents -->
    <app name="application/vnd.oasis.opendocument.chart">
        <ac10:43:39.418346 [0-0] == Info: [WRITE] [OUT] wrote 3347 body bytes -> 3347
10:43:39.418443 [0-0] == Info: [WRITE] [PAUSE] writing 3347/3347 bytes of type 1 → 0
10:43:39.418566 [0-0] == Info: [WRITE] download_write body(type=1, blen=3347) → 0
10:43:39.418686 [0-0] == Info: [WRITE] client_write(type=1, len=3347) → 0
10:43:39.418753 [0-0] == Info: [WRITE] xfer_write_resp(len=3347, eos=0) → 0
10:43:39.418831 [0-0] == Info: [HTTP/2] [1] ← FRAME[DATA, len=16384, eos=0, padlen=0]
10:43:39.418993 [0-0] == Info: [HTTP/2] [1] DATA, window=16384/20905984
10:43:39.419077 [0-0] == Info: [HTTP/2] [0] progress ingress: inbufg=0
10:43:39.419183 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=0
10:43:39.419251 [0-0] <= Recv SSL data, 5 bytes (0x5)
0000: …%!
10:43:39.419314 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=9505) → 9505, err=0
10:43:39.419389 [0-0] <= Recv SSL data, 1 bytes (0x1)
0000: .
10:43:39.419469 [0-0] == Info: [SSL] cf_recv(len=16384) → 9488, 0
10:43:39.419559 [0-0] == Info: [HTTP/2] [0] ingress: read 9488 bytes
10:43:39.419638 [0-0] <= Recv data, 9479 bytes (0x2507)
0000: tion default=“true” ext=“” name=“edit” urlsrc=“https://nc.do
0040: main.nl/browser/a0576a3364/cool.html?”/>. ..
0080: . . <action default=“true” ex
0100: t=“” name=“view” urlsrc=“https://nc.domain.nl/browser/a0576a
0140: 3364/cool.html?”/>. . . <action defaul
01c0: t=“true” ext=“” name=“edit” urlsrc=“https://nc.domain.nl/bro
0200: wser/a0576a3364/cool.html?”/>. .. . . . . <action default=“true” ext=“” name=“view”
04c0: >. . . <action default=“true” ext=“”
0540: name=“view” urlsrc=“https://nc.domain.nl/browser/a0576a3364
0580: /cool.html?”/>. .. . . <action default=“true”
0640: ext=“” name=“view” urlsrc=“https://nc.domain.nl/browser/a05
0680: 76a3364/cool.html?”/>. .. . . <action default=“true” ext=“” name=
0740: “view” urlsrc=“https://nc.domain.nl/browser/a0576a3364/cool.
0780: html?”/>. . . <action default
0800: =“true” ext=“” name=“view” urlsrc=“https://nc.domain.nl/brow
0840: ser/a0576a3364/cool.html?”/>. .. . . <action default=“true” e
0900: xt=“” name=“view” urlsrc=“https://nc.domain.nl/browser/a0576
0940: a3364/cool.html?”/>. . . <ac
09c0: tion default=“true” ext=“” name=“view” urlsrc=“https://nc.do
0a00: main.nl/browser/a0576a3364/cool.html?”/>. ..
0a40: . . . . . <ac
0b80: tion default=“true” ext=“” name=“view” urlsrc=“https://nc.do
0bc0: main.nl/browser/a0576a3364/cool.html?”/>. ..
0c00: . .
0c40: .
0cc0: . . <action def
0d00: ault=“true” ext=“” name=“edit” urlsrc=“https://nc.domain.nl/
0d40: browser/a0576a3364/cool.html?”/>. .. . .
0dc0: . .
0e40: . . . <action default=“true” ext=“” nam
0ec0: e=“edit” urlsrc=“https://nc.domain.nl/browser/a0576a3364/coo
0f00: l.html?”/>. ..
0f40: . . <action default=“true”
0fc0: ext=“” name=“edit” urlsrc=“https://nc.domain.nl/browser/a05
1000: 76a3364/cool.html?”/>. . . <action d
1080: efault=“true” ext=“” name=“edit” urlsrc=“https://nc.domain.n
10c0: l/browser/a0576a3364/cool.html?”/>. . <app n
1100: ame=“application/vnd.openxmlformats-officedocument.wordprocessin
1140: gml.template”>. . . . <action default=“true” e
1240: xt=“” name=“view” urlsrc=“https://nc.domain.nl/browser/a0576
1280: a3364/cool.html?”/>. .. . . . . . <acti
1400: on default=“true” ext=“” name=“view” urlsrc=“https://nc.doma
1440: in.nl/browser/a0576a3364/cool.html?”/>. . <a
1480: pp name=“application/vnd.openxmlformats-officedocument.spreadshe
14c0: etml.sheet”>. . . . . . . <action de
1680: fault=“true” ext=“” name=“edit” urlsrc=“https://nc.domain.nl
16c0: /browser/a0576a3364/cool.html?”/>. .. . .
1780: . .
1800: . . . . <actio
1940: n default=“true” ext=“” name=“view” urlsrc=“https://nc.domai
1980: n.nl/browser/a0576a3364/cool.html?”/>. . <ap
19c0: p name=“application/vnd.ms-powerpoint.template.macroEnabled.12”>
1a00: . .
1a80: .. . . <action default=“true” ext=“” name
1b00: =“view” urlsrc=“https://nc.domain.nl/browser/a0576a3364/cool
1b40: .html?”/>. . . <action default=“true” ext=“” name=“view” url
1bc0: src=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
1c00: . .
1c40: . .
1cc0: . <action de
1d00: fault=“true” ext=“” name=“view” urlsrc=“https://nc.domain.nl
1d40: /browser/a0576a3364/cool.html?”/>. . <app na
1d80: me=“application/vnd.ms-office”>. . . . <action default=“true” ext=“” name
1e80: =“view” urlsrc=“https://nc.domain.nl/browser/a0576a3364/cool
1ec0: .html?”/>. . . <action default=“true” ext=“” name=“edit” u
1f40: rlsrc=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>
1f80: . . .
1fc0: . .
2040: . <action default=“true” ex
2080: t=“” name=“edit” urlsrc=“https://nc.domain.nl/browser/a0576a
20c0: 3364/cool.html?”/>. . . <action default=“true” ext=“” name=“edit”
2140: urlsrc=“https://nc.domain.nl/browser/a0576a3364/cool.html?”
2180: />. . . <action default=“true” ext=“” name=“view” urlsrc=
2200: “https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.
2240: . . <action def
2280: ault=“true” ext=“” name=“view” urlsrc=“https://nc.domain.nl/
22c0: browser/a0576a3364/cool.html?”/>. . <app nam
2300: e=“image/vnd.dxf”>. <action default=“true” ext=“” nam
2340: e=“view” urlsrc=“https://nc.domain.nl/browser/a0576a3364/coo
2380: l.html?”/>. . .
23c0: . </app
2440: >. . . . <app name=“app
2500: licatio
tion default=“true” ext=”" name=“edit” urlsrc=“https://nc.domain.nl/browser/a0576a3364/cool.html?”/>
    <app name="application/vnd.sun.xml.writer.global">
    </app>
    <app name="application/vnd.oasis.opendocument.text-master">
    </app>
    <app name="application/vnd.sun.xml.math">
        <action name="view" default="true" ext=""/>
    </app>
    <app name="application/vnd.oasis.opendocument.formula">
        <action name="edit" default="true" ext=""/>
    </app>
    <app name="application/vnd.sun.xml.writer.template">
    </app>
    <app name="application/vnd.oasis.opendocument.text-template">
    </app>
    <app name="application/vnd.oasis.opendocument.text-master-template">
    </app>
    <app name="application/vnd.sun.xml.calc.template">
    </app>
    <app name="application/vnd.oasis.opendocument.spreadsheet-template">
    </app>
    <app name="application/vnd.sun.xml.impress.template">
    </app>
    <app name="application/vnd.oasis.opendocument.presentation-template">
    </app>
    <app name="application/vnd.sun.xml.draw.template">
    </app>
    <app name="application/vnd.oasis.opendocument.graphics-template">
    </app>
    <!-- MS Word -->
    <app name="application/msword">
    </app>
    </app>
    <!-- MS Excel -->
    </app>
    </app>
    <app name="application/vnd.openxmlformats-officedocument.wordprocessingml.document">
    </app>
    <app name="application/vnd.ms-word.document.macroEnabled.12">
    </app>
    <app name="application/vnd.openxmlformats-officedocument.wordprocessingml.template">
    </app>
    <app name="application/vnd.ms-word.template.macroEnabled.12">
    </app>
    <app name="application/vnd.openxmlformats-officedocument.spreadsheetml.template">
    </app>
    <app name="application/vnd.ms-excel.template.macroEnabled.12">
    </app>
    <app name="application/vnd.openxmlformats-officedocument.spreadsheetml.sheet">
    </app>
    <app name="application/vnd.ms-excel.sheet.binary.macroEnabled.12">
    </app>
    <app name="application/vnd.ms-excel.sheet.macroEnabled.12">
    </app>
    <app name="application/vnd.openxmlformats-officedocument.presentationml.presentation">
    </app>
    <app name="application/vnd.ms-powerpoint.presentation.macroEnabled.12">
    </app>
    <app name="application/vnd.openxmlformats-officedocument.presentationml.template">
    </app>
    <app name="application/vnd.ms-powerpoint.template.macroEnabled.12">
    </app>
    <!-- Others -->
    <app name="application/vnd.wordperfect">
    </app>
    <app name="application/x-aportisdoc">
    </app>
    <app name="application/x-hwp">
    </app>
    <app name="application/vnd.ms-works">
    </app>
    <app name="application/vnd.ms-office">
    </app>
    <app name="application/x-mswrite">
    </app>
    <app name="application/x-dif-document">
    </app>
    <app name="text/spreadsheet">
    </app>
    <app name="text/csv">
>>> continued in next post
browser/a0576a3364/cool.html?“/>
. . . . .0140: . .0180: . .0200: . <0240: action default=“true” ext=“” name=“view” urlsrc=“https://nc.0280: domain.nl/browser/a0576a3364/cool.html?”/>. .02c0: . <action def0300: ault=“true” ext=“” name=“view” urlsrc=“https://nc.domain.nl/0340: browser/a0576a3364/cool.html?”/>. . . <action default=“true”03c0: ext=“” name=“view” urlsrc=“https://nc.domain.nl/browser/a0570400: 6a3364/cool.html?”/>. . . . . . <action default=“true” ext=“” name=“view” urlsrc=0540: “https://nc.domain.nl/browser/a0576a3364/cool.html?”/>.0580: . . .0640: . . . . . .07c0: . . <action defau0800: lt=“true” ext=“” name=“edit” urlsrc=“https://nc.domain.nl/br0840: owser/a0576a3364/cool.html?”/>. . <app name=0880: “text/plain”>. . . . .09c0: . .0a00: . </ap0a80: p>. . <action default=0ac0: “true” ext=“” name=“view” urlsrc=“https://nc.domain.nl/brows0b00: er/a0576a3364/cool.html?”/>. . . . . . .0cc0: . . .0d80: . .0dc0: . .0e40: . <action default=0e80: “true” ext=“” name=“view” urlsrc=“https://nc.domain.nl/brows0ec0: er/a0576a3364/cool.html?”/>. . . <action default=“true”0f40: ext=“” name=“view” urlsrc=“https://nc.domain.nl/browser/a050f80: 76a3364/cool.html?”/>. . . . . . <1080: action ext=“” name=“view” urlsrc=“https://nc.domain.nl/brows10c0: er/a0576a3364/cool.html?”/>. . . . </app1180: >. . <action ext=“” name11c0: =“view” urlsrc=“https://nc.domain.nl/browser/a0576a3364/cool1200: .html?”/>. . .1240: . . . .1340: . . <action ext=1380: “” name=“view” urlsrc=“https://nc.domain.nl/browser/a0576a3313c0: 64/cool.html?”/>. . . . </1480: app>.. ..14c0: . <action ext=“” name=“iframe” u1500: rlsrc=“https://nc.domain.nl/browser/a0576a3364/admin/adminIn1540: tegratorSettings.html”/>. . . . .1600: .n/coreldraw”>
<!-- End of legacy MIME-type actions -->
<app name="Settings">
    <action ext="" name="iframe" urlsrc="https://nc.domain.nl/browser/a0576a3364/admin/adminIntegratorSettings.html"/>
</app>
<app name="Capabilities">
    <action ext="" name="getinfo" urlsrc="https://nc.domain.nl/hosting/capabilities"/>
</app>
10:43:39.442721 [0-0] == Info: [WRITE] [OUT] wrote 5661 body bytes → 566110:43:39.442798 [0-0] == Info: [WRITE] [PAUSE] writing 5661/5661 bytes of type 1 → 010:43:39.442886 [0-0] == Info: [WRITE] download_write body(type=1, blen=5661) → 010:43:39.442962 [0-0] == Info: [WRITE] client_write(type=1, len=5661) → 010:43:39.443031 [0-0] == Info: [WRITE] xfer_write_resp(len=5661, eos=0) → 010:43:39.443101 [0-0] == Info: [HTTP/2] [1] ← FRAME[DATA, len=15140, eos=0, padlen=0]10:43:39.443213 [0-0] == Info: [HTTP/2] [1] DATA, window=31524/2090598410:43:39.443337 [0-0] == Info: [HTTP/2] [0] progress ingress: inbufg=010:43:39.443426 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=5) → 5, err=010:43:39.443551 [0-0] <= Recv SSL data, 5 bytes (0x5)0000: …10:43:39.443668 [0-0] == Info: [SSL] ossl_bio_cf_in_read(len=26) → 26, err=010:43:39.443813 [0-0] <= Recv SSL data, 1 bytes (0x1)0000: .10:43:39.443925 [0-0] == Info: [SSL] cf_recv(len=16384) → 9, 010:43:39.444034 [0-0] == Info: [HTTP/2] [0] ingress: read 9 bytes10:43:39.444144 [0-0] == Info: [HTTP/2] [1] ← FRAME[DATA, len=0, eos=1, padlen=0]10:43:39.444291 [0-0] == Info: [HTTP/2] [1] DATA, window=31524/2090598410:43:39.444425 [0-0] == Info: [HTTP/2] [1] CLOSED10:43:39.444508 [0-0] == Info: [HTTP/2] [1] DRAIN select_bits=110:43:39.444618 [0-0] == Info: [HTTP/2] [0] progress ingress: inbufg=010:43:39.444754 [0-0] == Info: [HTTP/2] [1] DRAIN select_bits=110:43:39.444864 [0-0] == Info: [HTTP/2] [0] progress ingress: done10:43:39.444988 [0-0] == Info: [HTTP/2] [1] returning CLOSE10:43:39.445095 [0-0] == Info: [HTTP/2] handle_stream_close → 0, 010:43:39.445208 [0-0] == Info: [HTTP/2] [0] → FRAME[SETTINGS, ack=1]10:43:39.445337 [0-0] => Send SSL data, 5 bytes (0x5)0000: …10:43:39.445453 [0-0] => Send SSL data, 1 bytes (0x1)0000: .10:43:39.445587 [0-0] == Info: [SSL] ossl_bio_cf_out_write(len=31) → 31, err=010:43:39.445733 [0-0] == Info: [HTTP/2] [0] egress: wrote 9 bytes10:43:39.445812 [0-0] == Info: [HTTP/2] [1] cf_recv(len=102400) → 0 0, window=-1/-1, connection 1048544476/104857600010:43:39.445967 [0-0] == Info: abort upload10:43:39.446033 [0-0] <= Recv data, 0 bytes (0x0)10:43:39.446082 [0-0] == Info: [WRITE] [PAUSE] writing 0/0 bytes of type 81 → 010:43:39.446191 [0-0] == Info: [WRITE] download_write body(type=81, blen=0) → 010:43:39.446296 [0-0] == Info: [WRITE] client_write(type=81, len=0) → 010:43:39.446384 [0-0] == Info: [WRITE] xfer_write_resp(len=0, eos=1) → 010:43:39.446490 [0-0] == Info: [WRITE] [OUT] done10:43:39.446544 [0-0] == Info: [READ] client_reset, clear readers10:43:39.446614 [0-0] == Info: Connection #0 to host nc.domain.nl left intact`
So how can I troubleshoot this, I don’t know where to look anymore…Thanks!
You put me on a trail.
Nextcloud server is 32.0.3.
In indeed have Traefik 3.6.4 and implemented your suggested code, allthough I am working with docker compose:
    - "--entrypoints.websecure.http.encodedCharacters.allowEncodedSlash=true"
    - "--entrypoints.websecure.http.encodedCharacters.allowEncodedBackSlash=True"
    - "--entrypoints.websecure.http.encodedCharacters.allowEncodedNullCharacter=False"
    - "--entrypoints.websecure.http.encodedCharacters.allowEncodedSemicolon=True"
    - "--entrypoints.websecure.http.encodedCharacters.allowEncodedPercent=True"
    - "--entrypoints.websecure.http.encodedCharacters.allowEncodedQuestionMark=True"
    - "--entrypoints.websecure.http.encodedCharacters.allowEncodedHash=False"
But… Allthough it was a tough job getting the syntax right (Traefik is soo complicated), it still does not work. I found something like this:
providers:
  docker:
    endpoint: "tcp://dockersocket:2375"
and needed to translate this into:
    - "--providers.docker.endpoint=tcp://dockersocket:2375"
But this did not work.
So one hour more coding without results, I think I need to ditch Traefik, this change they made is too much for me…
So…
I did a rollback to Traefik 3.0 temporarily and still wasn’t able to get Collabora reached.
So I know now it is not Traefik and Collabora is reachable, so what might it then be?
Thanks
Preventing the autoclose
Anyone experienced this?
I installed Nginx Proxy manager, phased out Traefik. Funny that most users go the other way around and I get it now.
It is nice NPM has a web interface, but… it misses the real settings.
So I tried again a lot, and I am sure now the problem lies not in the proxies…
Maybe I can setup a parallel Nextcloud setup with the non AIO version, but that takes a lot of work. Pity it misses some tools in this case to analyse the problem.
OnlyOfffice works, how about that…
It is not the solution, but with OnlyOffice I have some sort of a solution for the moment…
Merry Christmas!
