Nextcloud version (eg, 29.0.5): 29.0.2
Operating system and version (eg, Ubuntu 29.04): Debian 11.9
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.59
PHP version (eg, 8.3): 8.1
Documents under Collabora Online (BuiltIN) are not opened
- Open a word document from the directory
{"reqId":"#","level":3,"time":"#","remoteAddr":"#","user":"--","app":"index","method":"GET","url":"/apps/files/api/v1/views","message":"The requested uri(/apps/files/api/v1/views) cannot be processed by the script '/cloud/index.
php')","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:127.0) Gecko/20100101 Firefox/127.0","version":"29.0.2.2","exception":{"Exception":"Exception","Message":"The requested uri(/apps/files/api/v1/views) cannot be processed by the script '/cloud/index.php')","Code":0,"Trac
e":[{"file":"/var/www/html/cloud/lib/base.php","line":1003,"function":"getRawPathInfo","class":"OC\\AppFramework\\Http\\Request","type":"->"},{"file":"/var/www/html/cloud/index.php","line":49,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/html/cloud/lib/privat
e/AppFramework/Http/Request.php","Line":743,"message":"The requested uri(/apps/files/api/v1/views) cannot be processed by the script '/cloud/index.php')","exception":{},"CustomMessage":"The requested uri(/apps/files/api/v1/views) cannot be processed by the script '/cloud/index.php')"
AH00128: File does not exist: /var/www/html/apps/files/api/v1/views
the path displayed in the Apache log is actually incorrect, it should actually read as follows
/var/www/html/cloud/apps/files/api/v1/views
Nextcloud is running in directory:
