I have migrated from Owncloud 10 to Nextcloud 24.
Previosly I have used/configured Onlyoffice and worked well.
With Nextcloud I want to use built in CODE but it does not open any document.
âDocument loading failed
Failed to load Nextcloud Office - please try again later-â
I didât see any error in logs.
Config:
Apache
Php 8.1
Nextcloud 24.0.5
richdocumentscode 22.5.1301 installed
I have checked the browser communication:
- https://xxx/server/remote.php/dav/files/admin/mydoc.odt - got http200
- https://xxx/server/apps-external/richdocumentscode/proxy.php?status - got http200
- https://xxx/server/index.php/apps/richdocuments/index?fileId=199407&requesttoken=REMOVEDxyztoken=&path=/mydoc.odt - got http200
but it returns some interesting content:
<!DOCTYPE html>
<html class="ng-csp" data-placeholder-focus="false" lang="en" data-locale="en" >
<head
var oc_userconfig={"avatar":{"version":0,"generated":true}};
</script>
<link rel="stylesheet" href="/server/index.php/css/icons/icons-vars.css?v=1681908911"/><link rel="stylesheet" href="/server/index.php/apps/theming/styles?v=0"/><meta name="robots" content="noindex, nofollow"/> </head>
<body id="body-login">
<noscript>
<div id="nojavascript">
<div>
This application requires JavaScript for correct operation. Please <a href="https://www.enable-javascript.com/" target="_blank" rel="noreferrer noopener">enable JavaScript</a> and reload the page. </div>
</div>
</noscript>
<input type="hidden" id="initial-state-core-config" value="removed">
<input type="hidden" id="initial-state-core-capabilities" value="removed>
<input type="hidden" id="initial-state-theming-data" value="removed==">
<input type="hidden" id="initial-state-accessibility-data" value="removed==">
<input type="hidden" id="initial-state-comments-maxAutoCompleteResults" value="MTA=">
<div class="wrapper">
<div class="v-align">
<header role="banner">
<div id="header">
<div class="logo">
<h1 class="hidden-visually">
Nextcloud </h1>
</div>
</div>
</header>
<main>
<div class="error">
<h2>Error</h2>
<ul>
<li>
<p>Failed to open the requested file.</p>
</li>
</ul>
</div> </main>
I have compared with fresh new installtion and not migrated one(witch) works well and it should be like that:
cript nonce="removed=" defer src="/server/apps/firstrunwizard/js/about.js?v=39957389-0"></script>
<script nonce="removed=" defer src="/server/apps/theming/js/theming.js?v=39957389-0"></script>
<script nonce="removed=" defer src="/server/apps-external/richdocuments/js/richdocuments-document.js?v=39957389-0"></script>
<script nonce="removed=">
var _oc_debug=false;
var _oc_isadmin=true;
var backendAllowsPasswordConfirmation=true;
var oc_dataURL=false;
var _oc_webroot="/server";
var _oc_appswebroots={"accessibility":"/server/apps/accessibility","activity":"/server/apps/activity","bruteforcesettings":"/server/apps-external/bruteforcesettings..
var datepickerFormatDate="M\/d\/yy";
var nc_lastLogin=1681911538;
var nc_pageLoad=1681916336;
var dayNames=["Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday"];
var dayNamesShort=["Sun.","Mon.","Tue.","Wed.","Thu.","Fri.","Sat."];
var dayNamesMin=["Su","Mo","Tu","We","Th","Fr","Sa"];
var monthNames=["January","February","March","April","May","June","July","August","September","October","November","December"];
var monthNamesShort=["Jan.","Feb.","Mar.","Apr.","May.","Jun.","Jul.","Aug.","Sep.","Oct.","Nov.","Dec."];
var firstDay=0;
var _oc_config={"session_lifetime":1440,"session_keepalive":true,"auto_logout":false,"version":"24.0.5.1"..
var oc_appconfig={"core":{"defaultExpireDateEnabled":false,"defaultExpireDate":null,..
var _theme={"entity":"Nextcloud","name":"Nextcloud","productName":"Nextcloud",..
</script>
according to
apps-external/richdocuments/templates/documents.php
Could you help me what have I missed during upgrade? I think somewhere it remembers to the old Onlyoffice settings.
config.php is same in both version
