Collabora briefly works on AIO restart, then fails due to socket errors.
    • 31.0.8.1
    • Fedora Server 42
    • Apache 2.4.65
    • Caddy v2.8.4
    • 8.3.24
    • Yes
    • Upon fresh install of Nextcloud AIO
    • AIO - Docker compose derived from the commands and example file
    • Cloudflare as registrar, no tunneling or proxying services etc
Started a fresh install of the Nextcloud AIO compose file. Adjust to allow for reverse proxying. Caddy exists on host #1, nextcloud AIO is running on host #2. All went well during install, all services work as expected except Collabora (which is green per AIO readout). When doing a fresh restart, an example ODT file will load as intended and can be modified. If I attempt to open a document afterwards, it will not load and results in the socket connection error / proxy misconfig.
Caddy config is as follows (also previously noted port and traffic type https like the example, but removed them during testing).
cloud.mydomain.com {
    reverse_proxy 192.168.1.12:11000
I have redacted my domain name and it will appear as example.com in most places, I do have a valid domain in place with records correctly set.
I did go through the Collabora / Talk troubleshooting thread and was not successful. I did whitelist caddy host (192.168.1.4) and 0.0.0.0/0 (all addresses) and this made no change in the behavior. With or without, a document will load only once after a restart, and subsequent attempts result in the socket / proxy misconfiguration error.
I do have COLLABORA_SECCOMP_DISABLED: true set in my compose environment flags, but the issue persisted before and after.
  1. Restart containers. docker compose down && docker compose up -d
  2. Login and open any .odt document.
  3. Document will load and can be modified as expected.
  4. Close document, attempt to reopen same or any other document. Proxy / socket error appears.
Loaded WOPI Token: https://paste.sh/phJ9RhoE#6SZNMVyQ00VI2RbkHEaeRuXv
No App In Context (this error shows in debug mode, is present a lot): https://paste.sh/GkyWIQ6S#xZ8Dth0eTFoN_eV03CzUIMYs
Create new document log (appears when attempting to open document that already exists):
{"reqId":"NAQIFJBfEoXadpMs44jl","level":1,"time":"2025-08-29T19:02:03+00:00","remoteAddr":"192.168.1.4","user":"admin","app":"text","method":"PUT","url":"/apps/text/session/55/create","message":"Create new document of 55","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/138.0.0.0 Safari/537.36","version":"31.0.8.1","data":{"app":"text"},"id":"68b1f93a09a26"}
Caddy throws no errors.
Server configuration detail
Operating system: Linux 6.14.0-63.fc42.x86_64 #1 SMP PREEMPT_DYNAMIC Mon Mar 24 19:53:37 UTC 2025 x86_64
Webserver: Apache/2.4.65 (Unix) (fpm-fcgi)
Database: pgsql PostgreSQL 17.5 on x86_64-pc-linux-musl, compiled by gcc (Alpine 14.2.0) 14.2.0, 64-bit
PHP version: 8.3.24
Modules loaded: Core, date, libxml, openssl, pcre, sqlite3, zlib, ctype, curl, dom, fileinfo, filter, hash, iconv, json, mbstring, SPL, session, PDO, pdo_sqlite, bz2, posix, random, readline, Reflection, standard, SimpleXML, tokenizer, xml, xmlreader, xmlwriter, mysqlnd, cgi-fcgi, apcu, bcmath, Phar, exif, ftp, gd, gmp, igbinary, imagick, imap, intl, ldap, memcached, pcntl, pdo_pgsql, pgsql, redis, smbclient, sodium, sysvsem, zip, libsmbclient, Zend OPcache
Nextcloud version: 31.0.8 - 31.0.8.1
Updated from an older Nextcloud/ownCloud or fresh install:
Where did you install Nextcloud from: unknown
Signing status
List of activated apps
 - activity: 4.0.0
 - admin_audit: 1.21.0
 - bruteforcesettings: 4.0.0
 - calendar: 5.5.1
 - circles: 31.0.0
 - comments: 1.21.0
 - contacts: 7.2.6
 - contactsinteraction: 1.12.0
 - dashboard: 7.11.0
 - deck: 1.15.2
 - federation: 1.21.0
 - files_antivirus: 6.0.4
 - files_downloadlimit: 4.0.0
 - files_fulltextsearch: 31.0.0
 - files_pdfviewer: 4.0.0
 - files_reminders: 1.4.0
 - files_sharing: 1.23.1
 - files_trashbin: 1.21.0
 - files_versions: 1.24.0
 - firstrunwizard: 4.0.0
 - fulltextsearch: 31.0.0
 - fulltextsearch_elasticsearch: 31.0.0
 - logreader: 4.0.0
 - nextcloud-aio: 0.8.0
 - notes: 4.12.3
 - notifications: 4.0.0
 - notify_push: 1.2.0
 - password_policy: 3.0.0
 - photos: 4.0.0
 - privacy: 3.0.0
 - recommendations: 4.0.0
 - related_resources: 2.0.0
 - richdocuments: 8.7.4
 - serverinfo: 3.0.0
 - sharebymail: 1.21.0
 - spreed: 21.1.4
 - support: 3.0.0
 - survey_client: 3.0.0
 - systemtags: 1.21.1
 - tasks: 0.16.1
 - text: 5.0.0
 - updatenotification: 1.21.0
 - user_status: 1.11.0
 - weather_status: 1.11.0
 - webhook_listeners: 1.2.0
 - whiteboard: 1.1.3
 - app_api: 5.0.2
 - encryption
 - files_external
 - suspicious_login
 - twofactor_nextcloud_notification
 - user_ldap
Configuration (config/config.php)
    "one-click-instance": true,
    "apps_paths": [
            "url": "\/apps",
            "writable": false
            "url": "\/custom_apps",
            "writable": true
    "redis": {
        "port": 6379
    "overwritehost": "cloud.example.com",
    "overwriteprotocol": "https",
        "localhost",
        "cloud.example.com"
    "dbtype": "pgsql",
    "version": "31.0.8.1",
    "overwrite.cli.url": "https:\/\/cloud.example.com\/",
    "dbport": "",
    "updatechecker": false,
    "loglevel": 1,
    "log_type": "file",
    "log_rotate_size": 10485760,
    "log.condition": {
        "apps": [
            "admin_audit"
    "preview_max_x": 2048,
    "preview_max_y": 2048,
    "jpeg_quality": 60,
    "enabledPreviewProviders": {
        "1": "OC\\Preview\\Image",
        "2": "OC\\Preview\\MarkDown",
        "3": "OC\\Preview\\MP3",
        "4": "OC\\Preview\\TXT",
        "6": "OC\\Preview\\Movie",
        "7": "OC\\Preview\\Krita",
    "enable_previews": true,
    "upgrade.disable-web": true,
    "mail_smtpmode": "smtp",
    "activity_expire_days": 30,
    "share_folder": "\/Shared",
    "htaccess.RewriteBase": "\/",
    "dbpersistent": false,
    "DOMAIN": "cloud.example.com"
Cron Configuration:
Mode: cron
Last: 2025-08-29T18:04:19+00:00 (285 seconds ago)
External storages: files_external is disabled
Encryption: no
User-backends:
  • OC\User\Database
Subscription:
  • No valid subscription key set
Browser: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/138.0.0.0 Safari/537.36
Setup checks
system
  • Errors in the log: 3 errors in the logs since August 22, 2025, 11:09:04 AM
  • Mimetype migrations available: One or more mimetype migrations are available. Occasionally new mimetypes are added to better handle certain file types. Migrating the mimetypes take a long time on larger instances so this is not done automatically during upgrades. Use the command occ maintenance:repair --include-expensive to perform the migrations.
config
  • Default phone region: Your installation has no default phone region set. This is required to validate phone numbers in the profile settings without a country code. To allow numbers without a country code, please add “default_phone_region” with the respective ISO 3166-1 code of the region to your config file.
  • Email test: You have not set or verified your email server configuration, yet. Please head over to the “Basic settings” in order to set them. Afterwards, use the “Send email” button below the form to verify your settings.
talk
  • SIP configuration: No SIP backend configured
Talk
Talk configuration:
STUN servers
TURN servers
  • turn:cloud.example.com:3478 - udp,tcp
Signaling servers (mode: default):
Recording servers:
I believe this is resolved. I think two issues were at play.
I think the initial change that fixed the initial socket / proxy configuration error is as follows -
  • If you host your Nextcloud AIO container on Fedora 42 or another system not making use of SECCOMP and use a reverse proxy, try enabling the environment var to disable SECCOMP for Collabora. COLLABORA_SECCOMP_DISABLED: true is set inside of my compose.yml.
The change that likely made further issues was unsetting 127.0.0.1 localhost from the /etc/hosts of my nextcloud host OS (Fedora 42). I don’t remember why or when this was unset, but I know it was a suggested edit here in a forum post. I assume after I unset it, it made it impossible to locally resolve the address.
I will report back if there are any further issues.
