Good day to all.
I am having a trouble connecting nextcloud and collabora - would appreciate a hint on configuration.
I have a nextcloud and collabora installation in docker-compose (using the latest versions of both from docker hub - just installed last week - nextcoud - 18.0.3 and collabora/code - ) - here’s the compose file:
Thanks.
I have tried changing the domain to domain=chorus-domain.com - no effect.
Also added ssl.enable=false and ssl.termination=true - this results in an error when accessing https://chorus-domain.com:9980 - it no longer gives OK but nginx error.
Docker logs -f collabora_1 shows no errors - seems like it nextcloud can not reach it.
you don’t need to do the ports in collabora since it goes outside via reverse proxy and inside docker networks all ports are visible to all containers.
So the problem is not there since I can access the root of collabora and I get an OK response and I can access the admin gui with https://chorus-domain.com:9980/loleaflet/dist/admin/admin.html
Ok @chorus12 – my setup is a little bit different than you but I understand what you are telling me – also based on my experience with working with other docker containers in general.
Can you post a nextcloud log file section – or portion of the log file that is generated when you try to open a document? Could you also check the collabora docker logs to see if anything is generated?
This is the log of nginx when opening an odt file:
The conference does not allow me to post nginx log since it contains more then 4 links - so I post the log here - http://code.re/nw6
And here is the log of collabora from the startup and after a startup it is not changing much:
I am not bound to my setup - I am willing to implement any working setup as well but have not found any configuration that really works. If you could give a clue how to change the setup to make it working - that would be fine as well.
The trickies part is reverse proxy setup - locations.
For instance the root of collabora was not working until I added the following into config of nginx:
location / {
proxy_pass http://collabora:9980;
proxy_set_header Host $http_host;
But that was not in any of how-tos.
@chorus - Yea I’m struggling with adding headers as well since that part is definitely tricky. I’ve found values of $host, $proxy_host, $http_host or simply just putting the name of the host you are proxying to. I’m not sure the effect of any of them, however they will change what shows up in the browser URL.
So I’m asking a question about your setup. You have the following containers:
mariadb (known as db)
nextcloud (known as app)
nginx (known as web)
collabora (known as collabora)
Nginx is binding ports 443 of the host and also host port 9980. (I’m assuming the 9980 port bind is for testing since in actuality you could probably go through your reverse proxy to reach collabora).
Within nginx you have two server domains however server_name is defined only in one block (what’s server_name for the nextcloud server block).
So I’m no reverse proxy pro - but why do you have the nginx collabora server block listening on port 9980? Shouldn’t both the nginx server blocks be listening on ports 443? I see the way you set things up you are connecting at chorus-domain.com:9980 whereas I would think if you had a listen on port 443, I think you could use https://chorus-domain.com.
Anyway the chorus-domain.com server block is going to proxy_pass via to the collabora:9980 port using reverse proxy.
Right now your reverse proxy seems to be working for the OK test page or location / and the admin interface but not the document server interface.
The logs files you posted are not exactly helpful – I think you posted the nginx access log rather than error log?? and the nextcloud log isn’t really all that helpful either.
What URL are you using within the Nextcloud->Settings->Collabora Code page?
Hello @kevdog
The problem is in nginx reverse proxy as I suppose.
Here’s why I think it is the case. I have made all working removing the nginx from collabora and just running CODE with ssl.
Here is my new docker-compose.yml
version: '3'
services:
db:
image: mariadb
restart: always
volumes:
- /data/ncloud/mysql:/var/lib/mysql
environment:
# use .env file do specify values for these vars
- MYSQL_DATABASE=${MYSQL_DATABASE}
- MYSQL_PASSWORD=${MYSQL_PASSWORD}
- MYSQL_ROOT_PASSWORD=${MYSQL_ROOT_PASSWORD}
- MYSQL_USER=${MYSQL_USER}
# ports:
# - 3306:3306
app:
image: nextcloud:stable-fpm
restart: always
volumes:
- /data/ncloud/data:/var/www/html
environment:
- MYSQL_HOST=db
environment:
depends_on:
- db
web:
image: nginx:latest
restart: always
ports:
- 443:443
volumes:
- /data/ncloud/data:/var/www/html:ro
- ./webshare:/webshare
- ./web/nginx.conf:/etc/nginx/nginx.conf
- ./certs:/certs
depends_on:
- app
collabora:
image: collabora/code
restart: always
cap_add:
- MKNOD
ports:
- 9980:9980
environment:
- domain=chorus-domain.com
# please put the below two variables into .env file
# like CLBR_ADMIN=admin
# CLBR_PASSWORD=your password
- username=${CLBR_ADMIN}
- password=${CLBR_PASSWORD}
- DONT_GEN_SSL_CERT=true
volumes:
- ./certs/fullchain1.pem:/etc/loolwsd/ca-chain.cert.pem
- ./certs/privkey1.pem:/etc/loolwsd/key.pem
- ./certs/fullchain1.pem:/etc/loolwsd/cert.pem
In case anyone would want to reproduce the config please pay attention for the .env file that must be present in the root folder from where you run docker-compose.
All sensitive env variables are there - just read the comments inside the docker-compose.yml
Many thanks for supporting me in this affair.
Partial credits also go to this site
If anyone will find out the proper nginx reverse proxy config - will be glad to adapt that.
I’ll try to help you however I don’t have your exact setup. I’m running CODE in docker, but my nginx reverse proxy runs on the docker host, and my nextcloud installation runs on yet a totally different VM.
What does your nginx.conf file look like right now?
I think I need just the location parts for CODE and server.
Mine nginx.conf is below - it is only for ncloud:
user www-data;
worker_processes 1;
error_log /var/log/nginx/error.log warn;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
include /etc/nginx/mime.types;
default_type application/octet-stream;
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
sendfile on;
#tcp_nopush on;
keepalive_timeout 65;
upstream php-handler {
server app:9000;
server {
listen 443 ssl;
ssl_certificate /certs/cert1.pem;
ssl_certificate_key /certs/privkey1.pem;
ssl_session_timeout 1d;
ssl_session_cache shared:SSL:50m;
ssl_session_tickets off;
# Diffie-Hellman parameter for DHE ciphersuites, recommended 2048 bits
# Generate with:
# `openssl dhparam -out dhparam.pem 2048`
ssl_dhparam /certs/dhparam.pem;
# modern configuration. tweak to your needs.
ssl_protocols TLSv1.1 TLSv1.2;
ssl_ciphers 'ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!3DES:!MD5:!PSK';
ssl_prefer_server_ciphers on;
# HSTS (ngx_http_headers_module is required) (15768000 seconds = 6 months)
add_header Strict-Transport-Security max-age=15768000;
# OCSP Stapling ---
# fetch OCSP records from URL in ssl_certificate and cache them
ssl_stapling off;
# ssl_stapling_verify on;
## verify chain of trust of OCSP response using Root CA and Intermediate certs
ssl_trusted_certificate /certs/fullchain1.pem;
# Before enabling Strict-Transport-Security headers please read into this
# topic first.
# add_header Strict-Transport-Security "max-age=15768000;
# includeSubDomains; preload;";
# could take several months.
add_header X-Robots-Tag none;
root /var/www/html;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json
# last;
# set max upload size
client_max_body_size 1G;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
#pagespeed off;
location / {
rewrite ^ /index.php$uri;
deny all;
deny all;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+)\.php(?:$|/) {
fastcgi_split_path_info ^(.+\.php)(/.*)$;
include fastcgi_params;
# fastcgi_param HTTPS on;
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
location ~ \.(?:css|js|woff|svg|gif)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=15778463";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
# this topic first.
access_log off;
location ~ \.(?:png|html|ttf|ico|jpg|jpeg)$ {
# Optional: Don't log access to other assets
access_log off;
Ok cool. I always hesitate to give advice without a test system similar to the person answering the question… but… let’s just try some things.
So far your nginx stuff is pretty boring vanilla nextcloud.
So I’m going to make a few design assumption, since its possible to run a few different way.
Right now you probably access code through the nextcloud CODE settings at https://chorus-domain.com:9980. I’m assuming you want to access CODE at https://chorus-domain.com and then proxy_pass via http so the backend CODE container.
Within nginx, you’ll need likely another virtual domain or server block that looks something like the following:
server {
listen [::]:443 ssl http2;
listen 443 ssl http2;
server_name chorus-domain.com;
#log_format main '$remote_addr - $remote_user [$time_local] "$request" '
# '$status $body_bytes_sent "$http_referer" '
# '"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/chorus-domain.com.access.log main buffer=32k;
error_log /var/log/nginx/chorus-domain.com.error.log;
#These two include files contain the path to the certs and various cert parameters as borrowed from mozilla (intermediate configuration)
include snippets/chorus-domain.com.cert.conf;
include snippets/ssl-params.conf;
# Allow large attachments
client_max_body_size 128M;
index index.html index.htm index.php /index.php;
#Optional block for testing to receive OK from server
location / {
proxy_pass http://collabora:9980/;
# static files
location ^~ /loleaflet {
# WOPI discovery URL
location ^~ /hosting/discovery {
# Capabilities
location ^~ /hosting/capabilities {
proxy_pass http://collabor:9980;
# main websocket
location ~ ^/lool/(.*)/ws$ {
proxy_set_header Connection "Upgrade";
proxy_read_timeout 36000s;
# download, presentation and image upload
location ~ ^/lool {
# Admin Console websocket
location ^~ /lool/adminws {
with your docker compose file for collabora, can you structure it similar to this:
I don’t use nginx, so I’m not sure I can offer much there, however one thing that stuck out to me was you mentioned you couldn’t connect to CODE from NC. What I do in my setup is have them both connect to each other through the reverse proxy on the host, where they are both presented valid certs by the proxy. And I used the docker-compose extra_hosts directive to make sure they both resolve the names to the LAN IP of the host.
