After update to 13.0.4 (from 13.0.2) there is a info “Bei der Code Integritätsprüfung sind Probleme aufgetreten”
Technical information
The following list covers which files have failed the integrity check. Please read
the previous linked documentation to learn more about the errors and how to fix
them.
Results
- twofactor_rcdevsopenotp
- FILE_MISSING
- l10n/.tx/config
- FILE_MISSING
Raw output
Array
[twofactor_rcdevsopenotp] => Array
[FILE_MISSING] => Array
[l10n/.tx/config] => Array
[expected] => 5ad14bb93e25fd93ebbd96e1e995367db065d11953f0c3ac707962098956f1a9f5534a7dcceb834ebfb4a6b3edd7f6a8c6cbddd01c052bbb61fe951c779f2fca
[current] =>
Nextcloud version (eg, 13.0.5):
Running shared web space
Is this the first time you’ve seen this error? Y:
- run update 13.0.4 (coming from 13.0.2)
n.a. no access for me (web space)
PASTE HERE
PASTE HERE
