Sorry to hear youâre facing problems.
The community help forum (help.nextcloud.com) is for home and non-enterprise users. Support is provided by other community members on a best effort / âas availableâ basis. All of those responding are volunteering their time to help you.
If youâre using Nextcloud in a business/critical setting, paid and SLA-based support services can be accessed via portal.nextcloud.com where Nextcloud engineers can help ensure your business keeps running smoothly.
- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isnât supplied; for fastest response please provide as much as you can. ![]()
- 30.0.5.1
- Ubuntu 24.04.1
2.4.58
1.26.2
- Is this the first time youâve seen this error? (Yes / No):
after installation
today
AIO Docker
no
I had a fully working an secure version of NC AIO. Then I installed CloudPanel as a frontend. Using the nginx functionality NC AIO is running but not as secure as without CloudPanel. X-Frame-Options, X-Content-Type-Options, X-XSS-Protection, X-Permitted-Cross-Domain-Policies are shown a no secure.
curl -I https://cloud.example.com
HTTP/2 302
server: nginx
date: Mon, 10 Feb 2025 11:44:52 GMT
content-type: text/html; charset=UTF-8
content-security-policy: default-src âselfâ; script-src âselfâ ânonce-TQYKE0Vz9ebQl5keYn+DYNygEBNfOSDCtrHQeGRktQY=â; style-src âselfâ âunsafe-inlineâ; frame-src *; img-src * data: blob:; font-src âselfâ data:; media-src *; connect-src *; object-src ânoneâ; base-uri âselfâ;
referrer-policy: no-referrer
set-cookie: oc_sessionPassphrase=UddNEA8R4I5fTrFMmGSVhN5mLXIUE%2Bf6yxWWzADSBbpAh0odP4ppJYPDUSO1YfD7T%2FNXvoEKAx1SFVLSVBMKmfUwhnsfAYX7FsCxQcUDT9v5dxgeF%2Fsxg3gg%2F5RDtsoA; path=/; secure; HttpOnly; SameSite=Lax
set-cookie: __Host-nc_sameSiteCookielax=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=lax
set-cookie: __Host-nc_sameSiteCookiestrict=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=strict
set-cookie: oc9fc0ubvieu=f9808319c792a4ed97688c1c500619b2; path=/; secure; HttpOnly; SameSite=Lax
strict-transport-security: max-age=31536000;
x-content-type-options: nosniff
x-frame-options: SAMEORIGIN
x-permitted-cross-domain-policies: none
x-robots-tag: noindex, nofollow
x-xss-protection: 1; mode=block
x-robots-tag: none
x-permitted-cross-domain-policies: master-only
referrer-policy: same-origin
alt-svc: h3=â:443â; ma=86400
cache-control: no-transform
PASTE HERE
PASTE
PASTE HERE
"one-click-instance": true,
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"redis": {
"port": 6379
"overwritehost": "cloud.example.com",
"overwriteprotocol": "https",
"localhost",
"cloud.example.com"
"dbtype": "pgsql",
"version": "30.0.5.1",
"overwrite.cli.url": "https:\/\/cloud.example.com\/",
"dbport": "",
"loglevel": 2,
"log_type": "file",
"log_rotate_size": 10485760,
"log.condition": {
"apps": [
"admin_audit"
"preview_max_x": 2048,
"preview_max_y": 2048,
"jpeg_quality": 60,
"enabledPreviewProviders": {
"1": "OC\\Preview\\Image",
"2": "OC\\Preview\\MarkDown",
"3": "OC\\Preview\\MP3",
"4": "OC\\Preview\\TXT",
"6": "OC\\Preview\\Movie",
"7": "OC\\Preview\\Krita",
"enable_previews": true,
"upgrade.disable-web": true,
"mail_smtpmode": "smtp",
"activity_expire_days": 30,
"share_folder": "\/Shared",
"htaccess.RewriteBase": "\/",
"dbpersistent": false,
"forbidden_filename_basenames": [
"con",
"prn",
"aux",
"nul",
"com0",
"com1",
"com2",
"com3",
"com4",
"com5",
"com6",
"com7",
"com8",
"com9",
"com\u00b9",
"com\u00b2",
"com\u00b3",
"lpt0",
"lpt1",
"lpt2",
"lpt3",
"lpt4",
"lpt5",
"lpt6",
"lpt7",
"lpt8",
"lpt9",
"lpt\u00b9",
"lpt\u00b2",
"lpt\u00b3"
"forbidden_filename_characters": [
"forbidden_filename_extensions": [
".filepart",
".part"
"DOMAIN": "cloud.example.com"
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
