Nextcloud version: 12.0.4
Operating system and version : Gentoo Linux x64
nginx version: 1.12.2
PHP version: 7.1
I have a big problem with my nextcloud installation. I try to sync my music collection with my laptop.
This are ~25GB. But every time the nextcloud client fails (sometimes after 200MB, 400MB or immediately).
The message in the client:
<filename 1>: Connection closed
<filename 2>: Operation abborted
<filename 3>. Operation abborted
Here is the nginx-error.log:
2018/01/21 14:12:45 [info] 24598#24598: *1320 SSL_write() failed (SSL:) (104: Connection reset by peer) while sending to client, client: 192.168.0.1, server: nextcloud.domain, request: “GET /remote.php/dav/files/siggi/Musik/Die%20Apokalyptischen%20Reiter/Tief/10%20Die%20Apokalyptischen%20Reiter%20-%20Die%20Welt%20ist%20tief.mp3 HTTP/1.1”, upstream: “fastcgi://unix:/run/php-fpm.socket:”, host: "nextcloud.domain"
2018/01/21 14:12:45 [info] 24598#24598: *1333 epoll_wait() reported that client prematurely closed connection, so upstream connection is closed too (104: Connection reset by peer) while sending to client, client: 192.168.0.1, server: nextcloud.domain, request: “GET /remote.php/dav/files/siggi/Musik/Die%20Apokalyptischen%20Reiter/Tief/11%20Die%20Apokalyptischen%20Reiter%20-%20So%20fern.mp3 HTTP/1.1”, upstream: “fastcgi://unix:/run/php-fpm.socket:”, host: "nextcloud.domain"
2018/01/21 14:12:45 [info] 24598#24598: *1345 epoll_wait() reported that client prematurely closed connection, so upstream connection is closed too while sending request to upstream, client: 192.168.0.1, server: nextcloud.domain, request: “GET /remote.php/dav/files/siggi/Musik/Die%20Apokalyptischen%20Reiter/Tief/folder.jpg HTTP/1.1”, upstream: “fastcgi://unix:/run/php-fpm.socket:”, host: “nextcloud.domain”
Here are my nginx config files:
nginx.conf:
user nginx nginx;
worker_processes auto;
error_log /var/log/nginx/error_log info;
events {
worker_connections 1024;
use epoll;
http {
upstream php-handler {
server unix:/run/php-fpm.socket;
include /etc/nginx/mime.types;
default_type application/octet-stream;
log_format main
'$http_x_forwarded_for - $remote_user [$time_local] '
'"$request" $status $bytes_sent '
'"$http_referer" "$http_user_agent" '
'"$gzip_ratio"';
client_header_timeout 10m;
client_body_timeout 10m;
send_timeout 10m;
connection_pool_size 256;
client_header_buffer_size 25600k;
large_client_header_buffers 4 2k;
request_pool_size 4k;
gzip off;
output_buffers 1 32k;
postpone_output 1460;
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 75 20;
ignore_invalid_headers on;
include /etc/nginx/vhosts/*.conf;
vhosts/nextcloud.domain.conf:
server {
listen *:80;
server_name nextcloud.domain;
return 301 https://$server_name$request_uri;
#HTTPS-Server
server {
#listen *:443 ssl;
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_certificate /etc/letsencrypt/live/domain.de/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/domain.de/privkey.pem; # managed by Certbot
ssl_session_cache shared:SSL:10m;
ssl_session_timeout 5m;
add_header X-Robots-Tag none;
root /var/www/nextcloud.domain/htdocs/nextcloud/;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
# set max upload size
client_max_body_size 2G;
fastcgi_buffers 256 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
#pagespeed off;
location / {
rewrite ^ /index.php$uri;
deny all;
deny all;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
fastcgi_split_path_info ^(.+\.php)(/.*)$;
include fastcgi_params;
fastcgi_param HTTPS on;
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
fastcgi_buffering off;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
location ~* \.(?:css|js|woff|svg|gif)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=15778463";
access_log off;
location ~* \.(?:png|html|ttf|ico|jpg|jpeg)$ {
# Optional: Don't log access to other assets
access_log off;
I hope somebody can help me with this problem.
dsiggi
