Client 2.5 issue
Is anyone else having this issue? I installed 2.5 desktop client and it only partially sync’s or does not sync at all and I cannot get it to sync. The little icon in the tray says it synced everything but the folder is empty except for some hidden files.
The only thing I did today was upgrade the server to 14.04, would that cause the client to all of a sudden wig out?
This is super frustrating!!
You’re not the only one.
I can’t connect to ther server too. And I noticed some people with this problem too.
It may help to delete the account in the client and recreate it with the same local folder. There will be no data loss.
It didn’t.
And neither any log was created at all.
You can start the client on the command line by
nextcloud --logwindow
Names and addresses were replaced:
Blockquote
|[OCC::FolderMan::setupFolders |Setup folders from settings file|
|[OCC::defaultJournalMode |Detected filesystem “NTFS” for “C:/Users/tomaz/Nextcloud/._sync_7b60b020c6c1.db”|
|[OCC::ConfigFile::setupDefaultExcludeFilePaths |Adding system ignore list to csync: “C:/Program Files (x86)/Nextcloud/sync-exclude.lst”|
|[OCC::FolderMan::addFolderInternal |Adding folder to Folder Map OCC::Folder(0x18546ec5140) “1”|
|[OCC::FolderMan::scheduleFolder |Schedule folder “1” to sync!|
|[OCC::FolderMan::scheduleFolder |Folder is not ready to sync, not scheduled!|
|[OCC::ownCloudGui::slotSyncStateChange |Sync state changed for folder “[SERVER ADDRESS]/remote.php/webdav/” : “Not yet Started”|
|[OCC::SyncJournalDb::checkConnect |sqlite3 version “3.24.0”|
|[OCC::SyncJournalDb::checkConnect |sqlite3 journal_mode= “wal”|
|[OCC::ClientProxy::setupQtProxyFromConfig |Set proxy configuration to use system configuration|
|[OCC::WebFlowCredentials::fetchFromKeychain |Fetch from keyhchain!|
|[OCC::AccountState::slotCredentialsFetched |Fetched credentials for “[SERVER ADDRESS]” attempting to connect|
|[OCC::WebFlowCredentials::createQNAM |Get QNAM|
|[OCC::ConnectionValidator::systemProxyLookupDone |No system proxy set by OS|
|[OCC::AccessManager::createRequest |2 “” “[SERVER ADDRESS]/status.php” has X-Request-ID “a019c207-2447-4283-ba2c-a7995b624539”|
|[OCC::AbstractNetworkJob::start |OCC::CheckServerJob created for “[SERVER ADDRESS]” + “status.php” “OCC::ConnectionValidator”|
|[OCC::OCUpdater::backgroundCheckForUpdate |Checking for available update|
|[OCC::AccessManager::createRequest |2 “” “https://updates.nextcloud.org/client/?version=2.5.0.20181112&platform=win32&oem=Nextcloud&versionsuffix=v2.5.0” has X-Request-ID “721e0678-2c10-4d63-964a-a4e3cd19d05f”|
|[OCC::WebFlowCredentials::slotFinished |request finished|
|[OCC::WebFlowCredentials::stillValid |Still valid?|
|[OCC::WebFlowCredentials::stillValid |QNetworkReply::NetworkError(NoError)|
|[OCC::WebFlowCredentials::stillValid |“Unknown error”|
|[OCC::CheckServerJob::finished |status.php returns: QJsonDocument({“edition”:"",“installed”:true,“maintenance”:false,“needsDbUpgrade”:false,“productname”:“Nextcloud”,“version”:“14.0.4.2”,“versionstring”:“14.0.4”}) QNetworkReply::NetworkError(NoError) Reply: QNetworkReplyHttpImpl(0x18546fc6870)|
|[OCC::ConnectionValidator::slotStatusFound |** Application: ownCloud found: QUrl("[SERVER ADDRESS]") with version “14.0.4” ( “14.0.4.2” )|
|[OCC::ConnectionValidator::setAndCheckServerVersion |QUrl("[SERVER ADDRESS]") has server version “14.0.4.2”|
|[OCC::AccessManager::createRequest |6 “PROPFIND” “[SERVER ADDRESS]/remote.php/webdav/” has X-Request-ID “8a1fcc66-ce08-4080-95a9-4e59387af80f”|
|[OCC::AbstractNetworkJob::start |OCC::PropfindJob created for “[SERVER ADDRESS]” + “/” “OCC::ConnectionValidator”|
|[OCC::PropfindJob::finished |PROPFIND of QUrl("[SERVER ADDRESS]/remote.php/webdav/") FINISHED WITH STATUS “OK”|
|[OCC::AccessManager::createRequest |2 “” “[SERVER ADDRESS]/ocs/v1.php/cloud/capabilities?format=json” has X-Request-ID “96e425dd-9a29-4364-bd25-bcadf558a55a”|
|[OCC::AbstractNetworkJob::start |OCC::JsonApiJob created for “[SERVER ADDRESS]” + “ocs/v1.php/cloud/capabilities” “OCC::ConnectionValidator”|
|[OCC::AccessManager::createRequest |2 “” “[SERVER ADDRESS]/ocs/v1.php/config?format=json” has X-Request-ID “558e1d8e-08d1-4cc5-a8c2-73b5ab79668d”|
|[OCC::AbstractNetworkJob::start |OCC::JsonApiJob created for “[SERVER ADDRESS]” + “ocs/v1.php/config” “”|
|[OCC::JsonApiJob::finished |JsonApiJob of QUrl("[SERVER ADDRESS]/ocs/v1.php/cloud/capabilities?format=json") FINISHED WITH STATUS “OK”|
|[OCC::ConnectionValidator::slotCapabilitiesRecieved |Server capabilities QJsonObject({“activity”:{“apiv2”:[“filters”,“filters-api”,“previews”,“rich-strings”]},“bruteforce”:{“delay”:0},“core”:{“pollinterval”:60,“webdav-root”:“remote.php/webdav”},“dav”:{“chunking”:“1.0”},“end-to-end-encryption”:{“api-version”:“1.0”,“enabled”:true},“files”:{“bigfilechunking”:true,“blacklisted_files”:[".htaccess",“Thumbs.db”,“thumbs.db”],“undelete”:true,“versioning”:true},“files_sharing”:{“api_enabled”:true,“default_permissions”:31,“federation”:{“expire_date”:{“enabled”:true},“incoming”:false,“outgoing”:false},“group”:{“enabled”:true,“expire_date”:{“enabled”:true}},“group_sharing”:true,“public”:{“enabled”:true,“expire_date”:{“enabled”:false},“password”:{“enforced”:false},“send_mail”:false,“upload”:true,“upload_files_drop”:true},“resharing”:true,“sharebymail”:{“enabled”:true,“expire_date”:{“enabled”:true},“password”:{“enabled”:true},“upload_files_drop”:{“enabled”:true}},“user”:{“expire_date”:{“enabled”:true},“send_mail”:false}},“notifications”:{“admin-notifications”:[“ocs”,“cli”],“ocs-endpoints”:[“list”,“get”,“delete”,“delete-all”,“icons”,“rich-strings”],“push”:[“devices”,“object-data”]},“ocm”:{“apiVersion”:“1.0-proposal1”,“enabled”:true,“endPoint”:"[SERVER ADDRESS]/ocm",“shareTypes”:[{“name”:“file”,“protocols”:{“webdav”:"/public.php/webdav/"}}]},“password_policy”:{“enforceNonCommonPassword”:true,“enforceNumericCharacters”:false,“enforceSpecialCharacters”:false,“enforceUpperLowerCase”:false,“minLength”:8},“theming”:{“background”:"#0082C9",“background-default”:true,“background-plain”:true,“color”:"#0082C9",“color-element”:"#0082C9",“color-text”:"#ffffff",“logo”:"[SERVER ADDRESS]/core/img/logo.svg?v=11",“name”:“Nextcloud”,“slogan”:"",“url”:"[SERVER ADDRESS]"}})|
|[OCC::AccessManager::createRequest |2 “” “[SERVER ADDRESS]/ocs/v1.php/cloud/user?format=json” has X-Request-ID “52cb46c3-da47-485d-9237-8c78de0a604b”|
|[OCC::AbstractNetworkJob::start |OCC::JsonApiJob created for “[SERVER ADDRESS]” + “ocs/v1.php/cloud/user” “OCC::ConnectionValidator”|
|[OCC::JsonApiJob::finished |JsonApiJob of QUrl("[SERVER ADDRESS]/ocs/v1.php/config?format=json") FINISHED WITH STATUS “OK”|
|[OCC::ConnectionValidator::ocsConfigReceived |Determined user-visible host to be “[server_address]”|
|[OCC::JsonApiJob::finished |JsonApiJob of QUrl("[SERVER ADDRESS]/ocs/v1.php/cloud/user?format=json") FINISHED WITH STATUS “OK”|
|[OCC::AccessManager::createRequest |2 “” “[SERVER ADDRESS]/remote.php/dav/avatars/noc/128.png” has X-Request-ID “d49f18cb-a1b7-4308-9c67-a575dcec2156”|
|[OCC::AbstractNetworkJob::start |OCC::AvatarJob created for “[SERVER ADDRESS]” + “” “OCC::ConnectionValidator”|
|[OCC::ClientSideEncryption::initialize |Initializing|
|[OCC::ClientSideEncryption::getPublicKeyFromServer |Retrieving public key from server|
|[OCC::AccessManager::createRequest |2 “” “[SERVER ADDRESS]/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json” has X-Request-ID “8758ed23-2334-4333-8d32-f4b82a74115f”|
|[OCC::AbstractNetworkJob::start |OCC::JsonApiJob created for “[SERVER ADDRESS]” + “ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key” “OCC::ClientSideEncryption”|
|[OCC::AbstractNetworkJob::slotFinished |QNetworkReply::NetworkError(ContentNotFoundError) "Error transferring [SERVER ADDRESS]/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json - server replied: " QVariant(int, 404)|
|[OCC::WebFlowCredentials::stillValid |QNetworkReply::NetworkError(ContentNotFoundError)|
|[OCC::WebFlowCredentials::stillValid |“Error transferring [SERVER ADDRESS]/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json - server replied: “|
|[OCC::JsonApiJob::finished |JsonApiJob of QUrl(”[SERVER ADDRESS]/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json”) FINISHED WITH STATUS "ContentNotFoundError Error transferring [SERVER ADDRESS]/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json - server replied: “|
|[OCC::JsonApiJob::finished |Network error: “ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key” “Error transferring [SERVER ADDRESS]/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json - server replied: " QVariant(int, 404)|
|[OCC::ClientSideEncryption::getPublicKeyFromServer::::operator() |No public key on the server|
|[OCC::ClientSideEncryption::generateKeyPair |No public key, generating a pair.|
|[OCC::ClientSideEncryption::generateKeyPair |Key correctly generated|
|[OCC::ClientSideEncryption::generateKeyPair |Storing keys locally|
|[OCC::ClientSideEncryption::generateKeyPair |Keys generated correctly, sending to server.|
|[OCC::ClientSideEncryption::generateCSR |Getting the following array for the account Id “noc”|
|[OCC::ClientSideEncryption::generateCSR |Returning the certificate|
|[OCC::ClientSideEncryption::generateCSR |”-----BEGIN CERTIFICATE REQUEST-----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\nEHJGBOT9pgGk\n-----END CERTIFICATE REQUEST-----\n”|
|[OCC::SignPublicKeyApiJob::start |Sending the CSR “csr=-----BEGIN%20CERTIFICATE%20REQUEST-----%0AMIICpTCCAY0CAQEwYDELMAkGA1UEBhMCREUxGzAZBgNVBAgMEkJhZGVuLVd1ZXJ0%0AdGVtYmVyZzESMBAGA1UEBwwJU3R1dHRnYXJ0MRIwEAYDVQQKDAlOZXh0Y2xvdWQx%0ADDAKBgNVBAMMA25vYzCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBALOF%0AJbxzxBAMQ6AW0lN0sqB6meAXnu0kiBJW%2Bnqi1VUWafTGGSAsny29CAX0NKM3NA0r%0AeiqGo%2BDv7yA%2BQamUMm9qaZUTjm8BFW2FqBakKLDTfJigKPS0zF1kHXgVsL7bAreE%0ASk04CJZU8%2BVRGZtvgmtBuTCwyoVUjWvqatplVB0s3DaC6mx4hg%2F0EUWXlhg1foaY%0Ay8rjMFgfiRR7JGyJ6kMZP2UoW0s4lGrsYoIDJYBxfF0snSxmgXLrmuFtBg07InLT%0A8AWGa3b0dtXr%2FDdSEqm%2Bf0vqvpDoAp0pm7QncOjJhv%2FyXM5GQUUjl%2FBTh1PIthEr%0ARjb4W6bS96AesGEUOMcCAwEAAaAAMA0GCSqGSIb3DQEBBQUAA4IBAQAKukDFxZCh%0AiRgGifvfGQL4gvE5fITHKZNhkj6lXdmd9SFumrV3rg%2Bbc5xHGPk%2FB3y9BvMJQWBN%0AT2LE%2FltQKMgaMGfODAe29jjLiejPw7EX%2F5k42%2B2M6wpmh33OGnDN4juoIEHOd6Sr%0A1G7XPMeGe1TNYA30ZdWjo7TTDiure1B0NnazHqG1mEXaGnHlbdnkMWitb8DAWEBG%0A0Fb3WXVte6m814eCSy51f8BDQ0rvtrr0WSH2WfdRqMuF2SwSpr1NK6AWbeUdQMNC%0ALxy2BvyX2B6PSpbMBTeHHkasEnQigVTuhyQZhFA0UkQs2ebU64VEcJZkTsOD6pcE%0AEHJGBOT9pgGk%0A-----END%20CERTIFICATE%20REQUEST-----%0A”|
|[OCC::AccessManager::createRequest |4 “” “[SERVER ADDRESS]/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json” has X-Request-ID “9e9d5857-e5cb-4e61-9efd-4e881759be11”|
|[OCC::AbstractNetworkJob::start |OCC::SignPublicKeyApiJob created for “[SERVER ADDRESS]” + “ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key” “OCC::ClientSideEncryption”|
|[OCC::AbstractNetworkJob::slotFinished |QNetworkReply::NetworkError(ProtocolInvalidOperationError) "Error transferring [SERVER ADDRESS]/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json - server replied: " QVariant(int, 400)|
|[OCC::WebFlowCredentials::stillValid |QNetworkReply::NetworkError(ProtocolInvalidOperationError)|
|[OCC::WebFlowCredentials::stillValid |"Error transferring [SERVER ADDRESS]/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json - server replied: "|
|[OCC::SignPublicKeyApiJob::finished |Sending CSR ended with “ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key” "Error transferring [SERVER ADDRESS]/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json - server replied: " QVariant(int, 400)|
|[OCC::ClientSideEncryption::generateCSR::::operator() |400|
|[OCC::NSISUpdater::versionInfoArrived |Client is on latest version!|
|[OCC::AccountState::checkConnectivity |ConnectionValidator already running, ignoring “[log_in]@server_address”|
Blockquote
I have the same Problem.
Happens with NextCloud Client 2.5.0 and 2.5.1 on Windows 10 (64 bit)
Nextcloud Server Version 14.0.4.2
Dit not yet find a matching Problem Report on the GitHub Client Project, will open one.
My log looks similar, seems the end-to-end encryption fails when executing the following step:
OCC: SignPublicKeyApiJob created for [...]
with the Response
QNetworkReply::NetworkError(ProtocolInvalidOperationError) "Error transferring [...] - server replied: " QVariant(int, 400)
[OCC::WebFlowCredentials::stillValid "Error transferring https://***.your-next.cloud/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json - server replied: "
[OCC::SignPublicKeyApiJob::finished Sending CSR ended with "ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key" "Error transferring https://***.your-next.cloud/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json - server replied: " QVariant(int, 400)
[OCC::ClientSideEncryption::generateCSR::::operator() 400
[OCC::Application::setupLogging 	"################## Nextcloud locale:[de_DE] ui_lang:[] version:[2.5.1final (build 20181204)] os:[Windows 10 (10.0)]"
[OCC::Application::setupTranslations 	Using "de_DE" translation
[OCC::SocketApi::SocketApi 	server started, listening at  "\\\\.\\pipe\\ownCloud-MYUSER"
[OCC::FolderMan::FolderMan 	setting remote poll timer interval to 30000 msec
[unknown 	QSslSocket: cannot resolve SSL_CONF_CTX_new
[unknown 	QSslSocket: cannot resolve SSL_CONF_CTX_free
[unknown 	QSslSocket: cannot resolve SSL_CONF_CTX_set_ssl_ctx
[unknown 	QSslSocket: cannot resolve SSL_CONF_CTX_set_flags
[unknown 	QSslSocket: cannot resolve SSL_CONF_CTX_finish
[unknown 	QSslSocket: cannot resolve SSL_CONF_cmd
[unknown 	QSslSocket: cannot resolve SSL_set_alpn_protos
[unknown 	QSslSocket: cannot resolve SSL_CTX_set_alpn_select_cb
[unknown 	QSslSocket: cannot resolve SSL_get0_alpn_selected
[OCC::AccountManager::loadAccountHelper 	Account for QUrl("https://***.your-next.cloud") using auth type "webflow"
[OCC::WebFlowCredentials::createQNAM 	Get QNAM
[OCC::ownCloudGui::setupContextMenu 	Tray menu workarounds: noabouttoshow: false fakedoubleclick: false showhide: false manualvisibility: false
[OCC::AccessManager::createRequest 	6 "GET" "https://***.your-next.cloud/ocs/v2.php/core/navigation/apps?absolute=true&format=json" has X-Request-ID "3b88f70d-0fa2-4e33-92f8-5d512c5f36db"
[OCC::AbstractNetworkJob::start 	OCC::OcsNavigationAppsJob created for "https://***.your-next.cloud" + "ocs/v2.php/core/navigation/apps" ""
[unknown 	QString::arg: Argument missing: Wenn diese Option aktiviert ist und keine andere Protokollierung konfiguriert ist, werden die Protokolle in einen temporären Ordner geschrieben und verfallen nach einigen Stunden. Diese Einstellung bleibt bei Client-Neustarts erhalten.
Protokolle werden in % 1 geschrieben, C:/Users/MYUSER/AppData/Local/Temp/Nextcloud-logdir
[OCC::FolderMan::setupFolders 	Setup folders from settings file
[OCC::defaultJournalMode 	Detected filesystem "NTFS" for "C:/Users/MYUSER/Nextcloud/._sync_9489c7d5593a.db"
[OCC::ConfigFile::setupDefaultExcludeFilePaths 	Adding user defined ignore list to csync: "C:/Users/MYUSER/AppData/Roaming/Nextcloud/sync-exclude.lst"
[OCC::FolderMan::addFolderInternal 	Adding folder to Folder Map  OCC::Folder(0x1a591f20270) "1"
[OCC::FolderMan::scheduleFolder 	Schedule folder  "1"  to sync!
[OCC::FolderMan::scheduleFolder 	Folder is not ready to sync, not scheduled!
[OCC::ownCloudGui::slotSyncStateChange 	Sync state changed for folder  "https://***.your-next.cloud/remote.php/webdav/" :  "Not yet Started"
[OCC::SyncJournalDb::checkConnect 	sqlite3 version "3.24.0"
[OCC::SyncJournalDb::checkConnect 	sqlite3 journal_mode= "wal"
[OCC::ClientProxy::setupQtProxyFromConfig 	Set proxy configuration to use system configuration
[OCC::WebFlowCredentials::fetchFromKeychain 	Fetch from keyhchain!
[OCC::AccountState::slotCredentialsFetched 	Fetched credentials for "https://***.your-next.cloud" attempting to connect
[OCC::ConnectionValidator::systemProxyLookupDone 	No system proxy set by OS
[OCC::AccessManager::createRequest 	2 "" "https://***.your-next.cloud/status.php" has X-Request-ID "5df5ae70-7036-4c11-84fe-fae22a0b4a57"
[OCC::AbstractNetworkJob::start 	OCC::CheckServerJob created for "https://***.your-next.cloud" + "status.php" "OCC::ConnectionValidator"
[OCC::WebFlowCredentials::slotFinished 	request finished
[OCC::WebFlowCredentials::stillValid 	Still valid?
[OCC::WebFlowCredentials::stillValid 	QNetworkReply::NetworkError(NoError)
[OCC::WebFlowCredentials::stillValid 	"Unbekannter Fehler"
[OCC::CheckServerJob::finished 	status.php returns:  QJsonDocument({"edition":"","installed":true,"maintenance":false,"needsDbUpgrade":false,"productname":"Nextcloud","version":"14.0.4.2","versionstring":"14.0.4"})   QNetworkReply::NetworkError(NoError)  Reply:  QNetworkReplyHttpImpl(0x1a59202e7a0)
[OCC::ConnectionValidator::slotStatusFound 	** Application: ownCloud found:  QUrl("https://***.your-next.cloud")  with version  "14.0.4" ( "14.0.4.2" )
[OCC::ConnectionValidator::setAndCheckServerVersion 	QUrl("https://***.your-next.cloud") has server version "14.0.4.2"
[OCC::AccessManager::createRequest 	6 "PROPFIND" "https://***.your-next.cloud/remote.php/webdav/" has X-Request-ID "bcae1836-823d-4eef-bee0-787eca9a24d3"
[OCC::AbstractNetworkJob::start 	OCC::PropfindJob created for "https://***.your-next.cloud" + "/" "OCC::ConnectionValidator"
[OCC::PropfindJob::finished 	PROPFIND of QUrl("https://***.your-next.cloud/remote.php/webdav/") FINISHED WITH STATUS "OK"
[OCC::AccessManager::createRequest 	2 "" "https://***.your-next.cloud/ocs/v1.php/cloud/capabilities?format=json" has X-Request-ID "03322323-19de-401c-b7e8-4e635c2ebc3a"
[OCC::AbstractNetworkJob::start 	OCC::JsonApiJob created for "https://***.your-next.cloud" + "ocs/v1.php/cloud/capabilities" "OCC::ConnectionValidator"
[OCC::AccessManager::createRequest 	2 "" "https://***.your-next.cloud/ocs/v1.php/config?format=json" has X-Request-ID "3b5aeda3-7cec-4bc4-9b87-cc0492785ddb"
[OCC::AbstractNetworkJob::start 	OCC::JsonApiJob created for "https://***.your-next.cloud" + "ocs/v1.php/config" ""
[OCC::JsonApiJob::finished 	JsonApiJob of QUrl("https://***.your-next.cloud/ocs/v1.php/cloud/capabilities?format=json") FINISHED WITH STATUS "OK"
[OCC::ConnectionValidator::slotCapabilitiesRecieved 	Server capabilities QJsonObject({"activity":{"apiv2":["filters","filters-api","previews","rich-strings"]},"bruteforce":{"delay":0},"core":{"pollinterval":60,"webdav-root":"remote.php/webdav"},"dav":{"chunking":"1.0"},"end-to-end-encryption":{"api-version":"1.0","enabled":true},"files":{"bigfilechunking":true,"blacklisted_files":[".htaccess"],"undelete":true,"versioning":true},"files_sharing":{"api_enabled":true,"default_permissions":31,"federation":{"expire_date":{"enabled":true},"incoming":true,"outgoing":true},"group":{"enabled":true,"expire_date":{"enabled":true}},"group_sharing":true,"public":{"enabled":true,"expire_date":{"enabled":false},"password":{"enforced":false},"send_mail":false,"upload":true,"upload_files_drop":true},"resharing":true,"sharebymail":{"enabled":true,"expire_date":{"enabled":true},"password":{"enabled":true},"upload_files_drop":{"enabled":true}},"user":{"expire_date":{"enabled":true},"send_mail":false}},"notifications":{"admin-notifications":["ocs","cli"],"ocs-endpoints":["list","get","delete","delete-all","icons","rich-strings"],"push":["devices","object-data"]},"ocm":{"apiVersion":"1.0-proposal1","enabled":true,"endPoint":"https://***.your-next.cloud/ocm","shareTypes":[{"name":"file","protocols":{"webdav":"/public.php/webdav/"}}]},"password_policy":{"enforceNonCommonPassword":true,"enforceNumericCharacters":false,"enforceSpecialCharacters":false,"enforceUpperLowerCase":false,"minLength":8},"theming":{"background":"https://***.your-next.cloud/core/img/background.png?v=0","background-default":true,"background-plain":false,"color":"#0082c9","color-element":"#0082c9","color-text":"#ffffff","logo":"https://***.your-next.cloud/core/img/logo.svg?v=0","name":"Nextcloud","slogan":"ein sicherer Ort fĂĽr all Deine Daten","url":"https://nextcloud.com"}})
[OCC::AccessManager::createRequest 	2 "" "https://***.your-next.cloud/ocs/v1.php/cloud/user?format=json" has X-Request-ID "b897a3cc-3ceb-4a1d-89f5-7bfe2d59b94d"
[OCC::AbstractNetworkJob::start 	OCC::JsonApiJob created for "https://***.your-next.cloud" + "ocs/v1.php/cloud/user" "OCC::ConnectionValidator"
[OCC::JsonApiJob::finished 	JsonApiJob of QUrl("https://***.your-next.cloud/ocs/v1.php/config?format=json") FINISHED WITH STATUS "OK"
[OCC::ConnectionValidator::ocsConfigReceived 	Determined user-visible host to be "***.your-next.cloud"
[OCC::JsonApiJob::finished 	JsonApiJob of QUrl("https://***.your-next.cloud/ocs/v1.php/cloud/user?format=json") FINISHED WITH STATUS "OK"
[OCC::AccessManager::createRequest 	2 "" "https://***.your-next.cloud/remote.php/dav/avatars/MYUSER/128.png" has X-Request-ID "5f37776d-1475-4978-8c4d-2c99fbb2ed34"
[OCC::AbstractNetworkJob::start 	OCC::AvatarJob created for "https://***.your-next.cloud" + "" "OCC::ConnectionValidator"
[OCC::ClientSideEncryption::initialize 	Initializing
[OCC::ClientSideEncryption::getPublicKeyFromServer 	Retrieving public key from server
[OCC::AccessManager::createRequest 	2 "" "https://***.your-next.cloud/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json" has X-Request-ID "a4d8ebaf-9106-4e8c-b958-12ac560a0a7b"
[OCC::AbstractNetworkJob::start 	OCC::JsonApiJob created for "https://***.your-next.cloud" + "ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key" "OCC::ClientSideEncryption"
[OCC::AbstractNetworkJob::slotFinished 	QNetworkReply::NetworkError(ContentNotFoundError) "Error transferring https://***.your-next.cloud/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json - server replied: " QVariant(int, 404)
[OCC::WebFlowCredentials::stillValid 	QNetworkReply::NetworkError(ContentNotFoundError)
[OCC::JsonApiJob::finished 	JsonApiJob of QUrl("https://***.your-next.cloud/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json") FINISHED WITH STATUS "ContentNotFoundError Error transferring https://***.your-next.cloud/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json - server replied: "
[OCC::JsonApiJob::finished 	Network error:  "ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key" "Error transferring https://***.your-next.cloud/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json - server replied: " QVariant(int, 404)
[OCC::ClientSideEncryption::getPublicKeyFromServer::::operator() 	No public key on the server
[OCC::ClientSideEncryption::generateKeyPair 	No public key, generating a pair.
[OCC::ClientSideEncryption::generateKeyPair 	Key correctly generated
[OCC::ClientSideEncryption::generateKeyPair 	Storing keys locally
[OCC::ClientSideEncryption::generateKeyPair 	Keys generated correctly, sending to server.
[OCC::ClientSideEncryption::generateCSR 	Getting the following array for the account Id "MYUSER"
[OCC::ClientSideEncryption::generateCSR 	Returning the certificate
[OCC::ClientSideEncryption::generateCSR 	"-----BEGIN CERTIFICATE REQUEST-----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\n4UUaEPrJQis65cg71sI=\n-----END CERTIFICATE REQUEST-----\n"
[OCC::SignPublicKeyApiJob::start 	Sending the CSR "csr=-----BEGIN%20CERTIFICATE%20REQUEST-----%0AMIICqjCCAZICAQEwZTELMAkGA1UEBhMCREUxGzAZBgNVBAgMEkJhZGVuLVd1ZXJ0%0AdGVtYmVyZzESMBAGA1UEBwwJU3R1dHRnYXJ0MRIwEAYDVQQKDAlOZXh0Y2xvdWQx%0AXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX%0AAQEA5HlCZ20o%2BnLFQi1Nv%2BYMfoTiWGqoojZI41XuKCbZm4kWLerdOM8CsDS52dvQ%0AQL6UsgViPvu8P5%2F3E%2B1n6X8kQJFyvW4ehlAMrwwlKY%2BVkTSB8ss8wmnePNYHrfDE%0AElGmuuBp6x%2FdduhrdeBCMM%2F9XviGenzdqRM5Y7ymQGe36RfIyUXBdB0%2F6QwygVvb%0ALdj3xnuL%2BMnL%2BgblpjuqFARvi%2F2z0VYxq%2Bw%2BF38ic1CVezVwUB1Xtz1neHfBC5YE%0ABZ95B%2Bbh9tfxn3SjtAHT8Ov1EzB%2FZsvlIa%2BRPDwwugWCIVt6jXT9eCtYr7%2BTOwIv%0AyQluy5cc3tmztZmnbxgcEUWKOQIDAQABoAAwDQYJKoZIhvcNAQEFBQADggEBAC0e%0AYRGZi7H6dZ7XVLn6j4%2B4GQ%2BMK6%2FO3PZlvr6dxWAq5rePaX8v1ISSFcBf5qVw2ZD8%0AjzYNQLyrBFNAhLJZHQXh2lpcEI0fr5RncmRDBKdpDBhNdCTfGQdP1jl2nsn0PI7z%0A0kS1XXp6EpVZPO2fY1vedt%2BwlZyC8Pa6gcqXQg49Wx9mtm91d%2F5h2lY56Vv2cYuu%0AbgC4nA2ljredGU3I5UsLEkqQMxH9c%2F9BiMsNPkXd5xLJsncpeYgD%2BsH%2BjpkvcrX6%0AEt%2BZecyK1pPIaq55qUay%2F%2Fl6HmrlI9x3MVoZZthNYn2oagAORCpC1pJhiACbd0Ib%0A4UUaEPrJQis65cg71sI%3D%0A-----END%20CERTIFICATE%20REQUEST-----%0A"
[OCC::AccessManager::createRequest 	4 "" "https://***.your-next.cloud/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json" has X-Request-ID "a6b34a3f-92f8-4841-9ca9-a0cd9468df32"
[OCC::AbstractNetworkJob::start 	OCC::SignPublicKeyApiJob created for "https://***.your-next.cloud" + "ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key" "OCC::ClientSideEncryption"
[OCC::AbstractNetworkJob::slotFinished 	QNetworkReply::NetworkError(ProtocolInvalidOperationError) "Error transferring https://***.your-next.cloud/ocs/v2.php/apps/end_to_end_encryption/api/v1/public-key?format=json - server replied: " QVariant(int, 400)
[OCC::WebFlowCredentials::stillValid 	QNetworkReply::NetworkError(ProtocolInvalidOperationError)
[OCC::OCUpdater::backgroundCheckForUpdate 	Checking for available update
[OCC::AccessManager::createRequest 	2 "" "https://updates.nextcloud.org/client/?version=2.5.1.20181204&platform=win32&oem=Nextcloud&versionsuffix=final" has X-Request-ID "e68bade5-3f98-4ce7-b9ef-f6f91a10c8f4"
[OCC::NSISUpdater::versionInfoArrived 	Client is on latest version!
[OCC::AccountState::checkConnectivity 	ConnectionValidator already running, ignoring "MYUSER@***.your-next.cloud"
[OCC::AccessManager::createRequest 	6 "GET" "https://***.your-next.cloud/ocs/v2.php/core/navigation/apps?absolute=true&format=json" has X-Request-ID "f20acbb2-f6e4-4048-93e6-0a6514fe76ee"
[OCC::AccessManager::createRequest 	6 "GET" "https://***.your-next.cloud/ocs/v2.php/core/navigation/apps?absolute=true&format=json" has X-Request-ID "a130327c-8b18-4b94-be6e-17d1b151e474"
[OCC::AccountManager::saveAccount 	Saving account "https://***.your-next.cloud"
[OCC::AccountManager::saveAccountHelper 	Saving  0  unknown certs.
[OCC::AccountManager::saveAccountHelper 	Saving cookies. "C:/Users/MYUSER/AppData/Local/Nextcloud/cookies0.db"
[unknown 	QIODevice::write (QFile, "C:\Users\MYUSER\AppData\Local\Nextcloud\cookies0.db"): device not open
[OCC::AccountManager::saveAccount 	Saved account settings, status: QSettings::Status(NoError)
[OCC::AccountManager::save 	Saved all account settings, status: QSettings::Status(NoError)
[OCC::SyncJournalDb::close 	Closing DB "C:/Users/MYUSER/Nextcloud/._sync_9489c7d5593a.db"
[unknown 	Could not parse stylesheet of object 0x1a58f31f2c0
[OCC::WebViewPage::WebViewPage 	Time for a webview!
