Nextcloud version (19.0.1):
Operating system and version (CentOS 7):
Apache or nginx version (Apache 2.4.6):
PHP version (7.3.21):
Hello everyone ! I’ve been using Nextcloud for a year now, never got any particular issue that I coudn’t solve. I need help on this one.
So I was doing a migration from a drive to another one and somehow, everything messed up. (even my backup…).
On the admin account, when I check the server overview, I have this error :
It was not possible to execute the cron job via CLI. The following technical errors have appeared:
Your data directory is invalid Ensure there is a file called “.ocdata” in the root of the data directory.
Your data directory is not writable
It’s the first time I get this error, even if I moved already the data folder in the past. I’ve done some search on the forum but no answers could fix my issue.
So I checked the .ocdata in my data folder :
/var/www/html/nextcloud/data/.ocdata
Rights : rw-r–r--
User:group : apache:apache
For this one I think it’s related to the second issue.
When I check the data folder :
Rights : rwxrwx—
I don’t know what do I need to check more…
The cloud is working, I can read files and upload too. I have the errors but it’s working “fine” I just fear side effects or invisible issues.
For some reason my Admin logs don’t work anymore (infinite spin)
config.php file
'passwordsalt' => '---',
'secret' => '---',
0 => 'localhost',
1 => '192.168.X.X',
2 => 'my_domain_name',
'datadirectory' => '/var/www/html/nextcloud/data',
'version' => '19.0.1.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'oc_nextcloud',
'dbpassword' => '---',
'instanceid' => '---',
'overwritehost' => 'my_domain_name',
'overwrite.cli.url' => 'https://my_domain_name',
'theme' => '',
'loglevel' => 2,
'updater.secret' => '---',
No errors related in error.log in my apache log folder.
I can provide more informations if needed.
Thanks for your answers.
CraftMarine
