Hello, I’m just looking for clarification on which background jobs method to use when using external storages (SMB) with the ‘Use session credentials’ option.
I think the system cron is the prefered method, but am I correct in thinking that AJAX is the only way to update the filecache with external storage and ‘Use session credentials’.
Is it possible to use both system cron and AJAX?
