Nextcloud version: 21.0.1
Operating system and version : docker-ce 20.10.2
Docker Image : nextcloud:21.0.1-apache
nginx (as Proxy): jwilder/nginx-proxy:0.8.0
PHP version : 7.4.18(bundled with image)
Hardware : ‘Asustor AS6204T’
NextCloudClient 3.2.1git on Arch linux
Nextcloud version 3.2.1git
Git revision 5901a0f9835261a640cd8bc9397bcd3068f2acd8
Using Qt 5.15.2, built against Qt 5.15.2
Using Qt platform plugin ‘xcb’
Using ‘OpenSSL 1.1.1k 25 Mar 2021’
Running on Arch Linux, x86_64
Bigger files (the smallest i think was ~260 MB) don’t have the same checksum after upload. Checked with Checkum Addon and after download with sha256sum. Also a 440MB file which had the correct checksum
Same Problem with 20.0.9.1
Tested with the client. I copied a folder with multiple big and small files. The i removed the folder within settings and downloaded again und checked the checksums… some files wont download.
Is this the first time you’ve seen this error?: Y
- Setup Nextcloud:
nextcloud reverse proxy docker compose yml
networks:
nextcloudnet:
external: false
WebNet:
external:
volumes:
nextcloud-data:
driver: local
nextcloud-db:
driver: local
services:
nextcloud-db:
image: mariadb:10.5.9
restart: always
volumes:
- nextcloud-db:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=Password
- MYSQL_PASSWORD=Password
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
networks:
- nextcloudnet
app:
image: nextcloud:21.0.1-apache
#expose:
#- "32768"
#ports:
#- 32768:80
links:
- nextcloud-db
volumes:
- nextcloud-data:/var/www/html
environment:
- MYSQL_HOST=nextcloud-db
- NEXTCLOUD_TRUSTED_DOMAINS=nextcloud.my-domain.de
- VIRTUAL_HOST=nextcloud.my-domain.de
#- VIRTUAL_PORT=32768
- LETSENCRYPT_HOST=nextcloud.my-domain.de
- LETSENCRYPT_EMAIL=mail@gmail.com
networks:
- nextcloudnet
- WebNet
restart: always
nginx reverse proxy docker compose yml
version: '2'
networks:
WebNet:
external:
services:
nginx-proxy-simple:
image: jwilder/nginx-proxy:0.8.0
container_name: nginx-proxy-simple
ports:
- "80:80"
- "443:443"
volumes:
- nginxconf:/etc/nginx/conf.d
- nginxvhost:/etc/nginx/vhost.d
- nginxhtml:/usr/share/nginx/html
- nginxdhparam:/etc/nginx/dhparam
- nginxcerts:/etc/nginx/certs:ro
- /var/run/docker.sock:/tmp/docker.sock:ro
restart: always
networks:
- WebNet
letsencrypt:
image: jrcs/letsencrypt-nginx-proxy-companion:2.0.2
container_name: nginx-proxy-le-simple
volumes_from:
- nginx-proxy-simple
volumes:
- nginxcerts:/etc/nginx/certs:rw
restart: always
#environment:
#- ACME_CA_URI=https://acme-staging-v02.api.letsencrypt.org/directory
#- DEBUG=true
networks:
- WebNet
nginx vhost conf
## Start of configuration add by letsencrypt container location ^~ /.well-known/acme-challenge/ { auth_basic off; auth_request off; allow all; root /usr/share/nginx/html; try_files $uri =404; break; } ## End of configuration add by letsencrypt conFabian@PackEsel:/volume1/.@plugins/AppCentral/docker-ce/docker_lib/volumes/nginxvhost/_data $ cat nextcloud2.fabis-matrix.de
auth_basic off;
auth_request off;
allow all;
break;
## End of configuration add by letsencrypt container
client_max_body_size 8g;
proxy_request_buffering off;
fastcgi_read_timeout 3000;
proxy_read_timeout 3000;
nginx config.php of Nextcloud 21.0.1.1
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'XXXXXXXXXXXXXXXXXXXXXXXXXX',
'passwordsalt' => 'XXXXXXXXXXXXXXXXXXXXXXXXXX',
'secret' => 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX',
0 => 'nextcloud.MyDomain.de',
'version' => '21.0.1.1',
'overwrite.cli.url' => 'nextcloud.MyDomain.de',
'dbname' => 'nextcloud',
'dbhost' => 'nextcloud-db',
'dbuser' => 'nextcloud',
'dbpassword' => 'XXXXXXXXXXXXXXXXXXXXXXXXXX',
'mail_domain' => 'gmail.com',
'mail_smtpmode' => 'smtp',
'mail_from_address' => 'myMail',
'mail_smtpsecure' => 'ssl',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtp.gmail.com',
'mail_smtpport' => '465',
'mail_smtpname' => 'myMail@gmail.com',
'mail_smtppassword' => 'bvaziogojcaaizgu',
nginx config.php of Nextcloud 20.0.9.1
'apps_paths' =>
0 =>
'url' => '/apps',
1 =>
'writable' => true,
0 => 'nextcloud2.MyDomain.de',
'version' => '20.0.9.1',
'overwrite.cli.url' => 'http://nextcloud2.MyDomain.de',
'dbpassword' => '2p89tuvFDHFgwnh7zver6187',
- upload a big file
- Check Checksum
[PHP] Error: Error: fread(): read of 8192 bytes failed with errno=5 Input/output error at /var/www/html/3rdparty/icewind/streams/src/Wrapper.php#91 at <<closure>>
0. <<closure>>
OC\Log\ErrorHandler::onError(8, "fread(): read o ... r", "/var/www/html/3 ... p", 91, {count: 8192})
1. /var/www/html/3rdparty/icewind/streams/src/Wrapper.php line 91
fread(null, 8192)
2. /var/www/html/3rdparty/icewind/streams/src/CallbackWrapper.php line 98
Icewind\Streams\Wrapper->stream_read(8192)
3. <<closure>>
Icewind\Streams\CallbackWrapper->stream_read(8192)
4. /var/www/html/apps/dav/lib/Upload/AssemblyStream.php line 151
fread(null, 8192)
5. <<closure>>
OCA\DAV\Upload\AssemblyStream->stream_read(8192)
6. /var/www/html/3rdparty/icewind/streams/src/Wrapper.php line 91
fread(null, 8192)
7. /var/www/html/lib/private/Files/Stream/HashWrapper.php line 64
8. <<closure>>
OC\Files\Stream\HashWrapper->stream_read(8192)
9. /var/www/html/3rdparty/icewind/streams/src/Wrapper.php line 91
fread(null, 8192)
10. /var/www/html/lib/private/Files/Stream/HashWrapper.php line 64
11. <<closure>>
12. /var/www/html/3rdparty/icewind/streams/src/Wrapper.php line 91
fread(null, 8192)
13. /var/www/html/lib/private/Files/Stream/HashWrapper.php line 64
14. <<closure>>
15. /var/www/html/3rdparty/icewind/streams/src/Wrapper.php line 91
fread(null, 8192)
16. /var/www/html/3rdparty/icewind/streams/src/CallbackWrapper.php line 98
17. <<closure>>
18. /var/www/html/lib/private/Files/Storage/Local.php line 555
file_put_contents("/var/www/html/d ... t", null)
19. /var/www/html/lib/private/Files/Storage/Wrapper/Wrapper.php line 627
OC\Files\Storage\Local->writeStream("files/Studium A ... t", null, null)
20. /var/www/html/apps/dav/lib/Connector/Sabre/File.php line 207
OC\Files\Storage\Wrapper\Wrapper->writeStream("files/Studium A ... t", null)
21. /var/www/html/apps/dav/lib/Connector/Sabre/Directory.php line 156
OCA\DAV\Connector\Sabre\File->put(null)
22. /var/www/html/3rdparty/sabre/dav/lib/DAV/Tree.php line 311
OCA\DAV\Connector\Sabre\Directory->createFile("MobileSecurity2020-s004.vmdk", null)
23. /var/www/html/3rdparty/sabre/dav/lib/DAV/Tree.php line 135
Sabre\DAV\Tree->copyNode(OCA\DAV\Upload\FutureFile {}, OCA\DAV\Connector\Sabre\Directory {}, "MobileSecurity2020-s004.vmdk")
24. /var/www/html/3rdparty/sabre/dav/lib/DAV/Tree.php line 167
Sabre\DAV\Tree->copy("uploads/fabian/2135839795/.file", "files/fabian/St ... k")
25. /var/www/html/apps/dav/lib/Upload/ChunkingPlugin.php line 95
Sabre\DAV\Tree->move("uploads/fabian/2135839795/.file", "files/fabian/St ... k")
26. /var/www/html/apps/dav/lib/Upload/ChunkingPlugin.php line 77
OCA\DAV\Upload\ChunkingPlugin->performMove("uploads/fabian/2135839795/.file", "files/fabian/St ... k")
27. /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
OCA\DAV\Upload\ChunkingPlugin->beforeMove("uploads/fabian/2135839795/.file", "files/fabian/St ... k")
28. /var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 632
Sabre\DAV\Server->emit("beforeMove", ["uploads/fabian ... "])
29. /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
Sabre\DAV\CorePlugin->httpMove(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
30. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 474
Sabre\DAV\Server->emit("method:MOVE", [Sabre\HTTP\Requ ... }])
31. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 251
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
32. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 319
Sabre\DAV\Server->start()
33. /var/www/html/apps/dav/lib/Server.php line 332
Sabre\DAV\Server->exec()
34. /var/www/html/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec()
35. /var/www/html/remote.php line 167
require_once("/var/www/html/a ... p")
MOVE /remote.php/dav/uploads/fabian/2135839795/.file
from 88.134.37.196 by fabian at 2021-05-20T20:29:34+00:00
[no app in context] Error: Exception: Stream from assembly node shorter than expected, got 75653120 bytes, expected 100000000 at <<closure>>
0. <<closure>>
fread(null, 8192)
2. /var/www/html/lib/private/Files/Stream/HashWrapper.php line 64
3. <<closure>>
4. /var/www/html/3rdparty/icewind/streams/src/Wrapper.php line 91
fread(null, 8192)
5. /var/www/html/lib/private/Files/Stream/HashWrapper.php line 64
6. <<closure>>
7. /var/www/html/3rdparty/icewind/streams/src/Wrapper.php line 91
fread(null, 8192)
8. /var/www/html/lib/private/Files/Stream/HashWrapper.php line 64
9. <<closure>>
10. /var/www/html/3rdparty/icewind/streams/src/Wrapper.php line 91
fread(null, 8192)
11. /var/www/html/3rdparty/icewind/streams/src/CallbackWrapper.php line 98
12. <<closure>>
13. /var/www/html/lib/private/Files/Storage/Local.php line 555
14. /var/www/html/lib/private/Files/Storage/Wrapper/Wrapper.php line 627
15. /var/www/html/apps/dav/lib/Connector/Sabre/File.php line 207
16. /var/www/html/apps/dav/lib/Connector/Sabre/Directory.php line 156
17. /var/www/html/3rdparty/sabre/dav/lib/DAV/Tree.php line 311
18. /var/www/html/3rdparty/sabre/dav/lib/DAV/Tree.php line 135
19. /var/www/html/3rdparty/sabre/dav/lib/DAV/Tree.php line 167
20. /var/www/html/apps/dav/lib/Upload/ChunkingPlugin.php line 95
21. /var/www/html/apps/dav/lib/Upload/ChunkingPlugin.php line 77
22. /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
23. /var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 632
24. /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
25. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 474
26. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 251
27. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 319
28. /var/www/html/apps/dav/lib/Server.php line 332
29. /var/www/html/apps/dav/appinfo/v2/remote.php line 35
30. /var/www/html/remote.php line 167
[webdav] Fatal: Sabre\DAV\Exception: Stream from assembly node shorter than expected, got 75653120 bytes, expected 100000000 at <<closure>>
0. /var/www/html/apps/dav/lib/Connector/Sabre/File.php line 260
OCA\DAV\Connector\Sabre\File->convertToSabreException(Exception {})
10. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 474
11. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 251
12. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 319
13. /var/www/html/apps/dav/lib/Server.php line 332
14. /var/www/html/apps/dav/appinfo/v2/remote.php line 35
15. /var/www/html/remote.php line 167
[PHP] Error: Error: Cannot modify header information - headers already sent by (output started at /var/www/html/3rdparty/sabre/http/lib/Sapi.php:132) at /var/www/html/apps/dav/lib/Connector/Sabre/File.php#691 at <<closure>>
0. <<closure>>
OC\Log\ErrorHandler::onError(2, "Cannot modify h ... )", "/var/www/html/a ... p", 691, {string: "X-Hash ... "})
1. /var/www/html/apps/dav/lib/Connector/Sabre/File.php line 691
header("X-Hash-SHA256: ... e")
2. /var/www/html/apps/dav/lib/Connector/Sabre/File.php line 195
OCA\DAV\Connector\Sabre\File->header("X-Hash-SHA256: ... e")
3. <<closure>>
OCA\DAV\Connector\Sabre\File->OCA\DAV\Connector\Sabre\{closure}("*** sensitive parameters replaced ***")
4. /var/www/html/lib/private/Files/Stream/HashWrapper.php line 71
call_user_func(Closure {}, "*** sensitive parameter replaced ***")
5. <<closure>>
OC\Files\Stream\HashWrapper->stream_close()
6. /var/www/html/3rdparty/icewind/streams/src/Wrapper.php line 132
fclose(null)
7. /var/www/html/3rdparty/icewind/streams/src/CallbackWrapper.php line 119
Icewind\Streams\Wrapper->stream_close()
8. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 319
Icewind\Streams\CallbackWrapper->stream_close()
9. /var/www/html/apps/dav/lib/Server.php line 332
10. /var/www/html/apps/dav/appinfo/v2/remote.php line 35
11. /var/www/html/remote.php line 167
0. <<closure>>
header("X-Hash-SHA1: 63 ... a")
2. /var/www/html/apps/dav/lib/Connector/Sabre/File.php line 192
OCA\DAV\Connector\Sabre\File->header("X-Hash-SHA1: 63 ... a")
3. <<closure>>
5. <<closure>>
fclose(null)
7. /var/www/html/lib/private/Files/Stream/HashWrapper.php line 75
8. <<closure>>
9. /var/www/html/3rdparty/icewind/streams/src/Wrapper.php line 132
fclose(null)
10. /var/www/html/3rdparty/icewind/streams/src/CallbackWrapper.php line 119
11. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 319
12. /var/www/html/apps/dav/lib/Server.php line 332
13. /var/www/html/apps/dav/appinfo/v2/remote.php line 35
14. /var/www/html/remote.php line 167
0. <<closure>>
header("X-Hash-MD5: f70 ... 5")
2. /var/www/html/apps/dav/lib/Connector/Sabre/File.php line 189
OCA\DAV\Connector\Sabre\File->header("X-Hash-MD5: f70 ... 5")
3. <<closure>>
5. <<closure>>
fclose(null)
8. <<closure>>
fclose(null)
10. /var/www/html/lib/private/Files/Stream/HashWrapper.php line 75
11. <<closure>>
12. /var/www/html/3rdparty/icewind/streams/src/Wrapper.php line 132
fclose(null)
13. /var/www/html/3rdparty/icewind/streams/src/CallbackWrapper.php line 119
14. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 319
15. /var/www/html/apps/dav/lib/Server.php line 332
16. /var/www/html/apps/dav/appinfo/v2/remote.php line 35
17. /var/www/html/remote.php line 167
Did not find something relevant here…
For any hints i would be happy
