I was having some issues earlier with updates which required me to temporarily change some permissions on system files. I believe all permissions are restored, but I want to check this.
Is there a way to check if Nextcloud is leaking any files to users that are not logged in, or if Apache is doing this? Such as navigating to mynextcloud.com/something
I did some research and it looks like if https://nextcloud.domain.com/apps/files returns a 403 error the data is safe, but in my case it just redirects back to the login page.
These are the permissions on my nextcloud data folder: drwxrwx— 5 www-data www-data
Appreciate any insight on this, thanks!
