example
longer
example
here
Nextcloud version (eg, 29.0.5): 29.0.3.4 (Docker AIO 9.1.0)
Operating system and version (eg, Ubuntu 29.04): Ubuntu 20.04 64 Bit
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.59
PHP version (eg, 8.3): no idea
I did a system upgrade, and the nextcloud website and client started giving me “Error code: SEC_ERROR_UNKNOWN_ISSUER” and something about not trusting self-signed certificates.
I went over to the AIO (domain.tld:8443) stopped the containers, made a backup and upgraded the master container.
After doing so, the problem persisted so I decided to restore to backup and it still didn’t fix anything, and here we are now.
- apt update && upgrade
- start getting certificate problems
- update master-container through nextcloud AIO panel
The output of your log in Container Nextcloud AIO Nextcloud (removed my domain name with nextcloud.domain.tld):
2024-07-01T21:16:23.615327222Z Waiting for database to start...
2024-07-01T21:16:28.627696783Z Waiting for database to start...
2024-07-01T21:16:33.634187290Z Connection to nextcloud-aio-database (172.18.0.4) 5432 port [tcp/postgresql] succeeded!
2024-07-01T21:16:35.689177935Z now
2024-07-01T21:16:35.689227962Z -------------------------------
2024-07-01T21:16:35.689234179Z 2024-07-01 21:16:35.688129+00
2024-07-01T21:16:35.689237764Z (1 row)
2024-07-01T21:16:35.689241030Z
2024-07-01T21:16:35.699432308Z + '[' -f /dev-dri-group-was-added ']'
2024-07-01T21:16:35.700527421Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-07-01T21:16:35.701524025Z + '[' -n '' ']'
2024-07-01T21:16:35.701699262Z + set +x
2024-07-01T21:16:35.715469619Z Enabling Imagick...
2024-07-01T21:16:36.853806205Z WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/main: No such file or directory
2024-07-01T21:16:36.853852690Z WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/community: No such file or directory
2024-07-01T21:16:36.884817909Z Connection to nextcloud-aio-redis (172.18.0.5) 6379 port [tcp/redis] succeeded!
2024-07-01T21:16:39.354656209Z Applying one-click-instance settings...
2024-07-01T21:16:39.903232614Z System config value one-click-instance set to boolean true
2024-07-01T21:16:40.464505676Z System config value one-click-instance.user-limit set to integer 100
2024-07-01T21:16:41.085088829Z System config value one-click-instance.link set to string https://nextcloud.com/all-in-one/
2024-07-01T21:16:41.682939700Z support already enabled
2024-07-01T21:16:41.704568534Z Adjusting log files...
2024-07-01T21:16:42.263664788Z System config value upgrade.cli-upgrade-link set to string https://github.com/nextcloud/all-in-one/discussions/2726
2024-07-01T21:16:42.847885971Z System config value logfile set to string /var/www/html/data/nextcloud.log
2024-07-01T21:16:43.441841270Z Config value logfile for app admin_audit set to /var/www/html/data/audit.log
2024-07-01T21:16:44.001534008Z System config value updatedirectory set to string /nc-updater
2024-07-01T21:16:44.592420862Z Applying network settings...
2024-07-01T21:16:45.173187896Z System config value allow_local_remote_servers set to boolean true
2024-07-01T21:16:45.746877329Z System config value davstorage.request_timeout set to integer 3600
2024-07-01T21:16:46.325686768Z System config value trusted_domains => 1 set to string nextcloud.domain.tld
2024-07-01T21:16:46.886503920Z System config value overwrite.cli.url set to string https://nextcloud.domain.tld/
2024-07-01T21:16:47.507907259Z System config value htaccess.RewriteBase set to string /
2024-07-01T21:16:48.072197512Z .htaccess has been updated
2024-07-01T21:16:48.663982228Z System config value dbpersistent set to boolean false
2024-07-01T21:16:49.280090841Z System config value auth.bruteforce.protection.enabled set to boolean true
2024-07-01T21:16:49.894716814Z System config value ratelimit.protection.enabled set to boolean true
2024-07-01T21:16:50.493608712Z System config value files_external_allow_create_new_local set to boolean false
2024-07-01T21:16:52.222168426Z System config value trusted_proxies => 0 set to string 127.0.0.1
2024-07-01T21:16:52.801390091Z System config value trusted_proxies => 1 set to string ::1
2024-07-01T21:16:53.480139927Z System config value trusted_proxies => 10 set to string 172.18.0.0/16
2024-07-01T21:16:54.024375162Z Config value base_endpoint for app notify_push set to https://nextcloud.domain.tld/push
2024-07-01T21:16:54.044145091Z + echo nextcloud-aio-collabora
2024-07-01T21:16:54.044709120Z + grep -q 'nextcloud-.*-collabora'
2024-07-01T21:16:54.045711255Z + COLLABORA_HOST=nextcloud.domain.tld
2024-07-01T21:16:54.045997098Z + set +x
2024-07-01T21:16:55.182847338Z Config value wopi_url for app richdocuments set to https://nextcloud.domain.tld/
2024-07-01T21:16:55.838236666Z No ipv6-address found for nextcloud.domain.tld.
2024-07-01T21:16:56.397520395Z Config value wopi_allowlist for app richdocuments set to 74.48.52.82,127.0.0.1/8,192.168.0.0/16,172.16.0.0/12,10.0.0.0/8,fd00::/8,::1
2024-07-01T21:16:56.417297145Z + '[' -z '' ']'
2024-07-01T21:16:56.417333632Z + TALK_HOST=nextcloud.domain.tld
2024-07-01T21:16:56.417339408Z + HPB_PATH=/standalone-signaling/
2024-07-01T21:16:56.417432310Z + '[' -z '' ']'
2024-07-01T21:16:56.417445951Z + TURN_DOMAIN=nextcloud.domain.tld
2024-07-01T21:16:56.417449839Z + set +x
2024-07-01T21:16:59.327465415Z Config value recording_servers of app spreed deleted
2024-07-01T21:16:59.885627170Z System config value enabledPreviewProviders => 0 set to string OC\Preview\Imaginary
2024-07-01T21:17:00.526330972Z System config value preview_imaginary_url set to string http://nextcloud-aio-imaginary:9000
2024-07-01T21:17:01.104283088Z System config value preview_imaginary_key set to string 6effe65de83caf2e7976513f834e017a5f483d5f808cdbe9
2024-07-01T21:17:01.158532852Z + '[' true = true ']'
2024-07-01T21:17:01.158562700Z + '[' 443 = 443 ']'
2024-07-01T21:17:01.159587879Z ++ dig nextcloud-aio-apache A +short +search
2024-07-01T21:17:01.160293126Z ++ head -n1
2024-07-01T21:17:01.161869105Z ++ grep '^[0-9.]\+$'
2024-07-01T21:17:01.162198903Z ++ sort
2024-07-01T21:17:01.185474196Z + IPv4_ADDRESS_APACHE=172.18.0.9
2024-07-01T21:17:01.186314687Z ++ dig nextcloud-aio-apache AAAA +short +search
2024-07-01T21:17:01.187415854Z ++ grep '^[0-9a-f:]\+$'
2024-07-01T21:17:01.188063264Z ++ sort
2024-07-01T21:17:01.190634226Z ++ head -n1
2024-07-01T21:17:01.212009660Z + IPv6_ADDRESS_APACHE=
2024-07-01T21:17:01.213006628Z ++ dig nextcloud-aio-mastercontainer A +short +search
2024-07-01T21:17:01.214099409Z ++ ++ grep '^[0-9.]\+$'
2024-07-01T21:17:01.214356881Z sort
2024-07-01T21:17:01.216646147Z ++ head -n1
2024-07-01T21:17:01.242054208Z + IPv4_ADDRESS_MASTERCONTAINER=172.18.0.10
2024-07-01T21:17:01.243382940Z ++ dig nextcloud-aio-mastercontainer AAAA +short +search
2024-07-01T21:17:01.244293563Z ++ head -n1
2024-07-01T21:17:01.246505708Z ++ sort
2024-07-01T21:17:01.252333969Z ++ grep '^[0-9a-f:]\+$'
2024-07-01T21:17:01.268006839Z + IPv6_ADDRESS_MASTERCONTAINER=
2024-07-01T21:17:01.268689252Z + sed -i 's|^;listen.allowed_clients|listen.allowed_clients|' /usr/local/etc/php-fpm.d/www.conf
2024-07-01T21:17:01.274508414Z + sed -i 's|listen.allowed_clients.*|listen.allowed_clients = 127.0.0.1,::1,172.18.0.9,,172.18.0.10,|' /usr/local/etc/php-fpm.d/www.conf
2024-07-01T21:17:01.277289883Z + sed -i '/^listen.allowed_clients/s/,,/,/g' /usr/local/etc/php-fpm.d/www.conf
2024-07-01T21:17:01.280091226Z + sed -i '/^listen.allowed_clients/s/,$//' /usr/local/etc/php-fpm.d/www.conf
2024-07-01T21:17:01.281959733Z + grep listen.allowed_clients /usr/local/etc/php-fpm.d/www.conf
2024-07-01T21:17:01.283340949Z listen.allowed_clients = 127.0.0.1,::1,172.18.0.9,172.18.0.10
2024-07-01T21:17:01.283840996Z + set +x
2024-07-01T21:17:02.933082363Z [01-Jul-2024 21:17:02] NOTICE: fpm is running, pid 434
2024-07-01T21:17:02.933378885Z [01-Jul-2024 21:17:02] NOTICE: ready to handle connections
2024-07-01T21:17:17.766741813Z Activating Collabora config...
2024-07-01T21:17:18.405473607Z ✓ Reset callback url autodetect
2024-07-01T21:17:18.405834106Z Checking configuration
2024-07-01T21:17:18.406090741Z 🛈 Configured WOPI URL: https://nextcloud.domain.tld/
2024-07-01T21:17:18.406423746Z 🛈 Configured public WOPI URL: https://nextcloud.domain.tld
2024-07-01T21:17:18.406818212Z 🛈 Configured callback URL:
2024-07-01T21:17:18.406830036Z
2024-07-01T21:17:18.434611228Z Failed to fetch discovery endpoint from https://nextcloud.domain.tld/
2024-07-01T21:17:18.434633941Z cURL error 60: SSL certificate problem: self-signed certificate in certificate chain (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://nextcloud.domain.tld/hosting/discovery
2024-07-01T21:55:25.956609621Z [01-Jul-2024 21:55:25] NOTICE: Terminating ...
2024-07-01T21:55:25.956653841Z [01-Jul-2024 21:55:25] NOTICE: exiting, bye-bye!
2024-07-01T21:55:26.961237476Z +++ pgrep -f /var/www/html/cron.php
2024-07-01T21:55:26.965760974Z Cronjob successfully exited.
2024-07-01T21:55:26.966007025Z ++ '[' -n '' ']'
2024-07-01T21:55:26.966018884Z ++ echo 'Cronjob successfully exited.'
2024-07-01T21:55:26.966034559Z ++ exit
2024-07-01T23:24:32.344436799Z Waiting for database to start...
2024-07-01T23:24:37.406386348Z Connection to nextcloud-aio-database (172.18.0.10) 5432 port [tcp/postgresql] succeeded!
2024-07-01T23:24:39.553990329Z now
2024-07-01T23:24:39.554106037Z -------------------------------
2024-07-01T23:24:39.554113176Z 2024-07-01 23:24:39.543097+00
2024-07-01T23:24:39.554116723Z (1 row)
2024-07-01T23:24:39.554119964Z
2024-07-01T23:24:39.569326959Z + '[' -f /dev-dri-group-was-added ']'
2024-07-01T23:24:39.570616558Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-07-01T23:24:39.571674250Z + '[' -n '' ']'
2024-07-01T23:24:39.571782115Z + set +x
2024-07-01T23:24:39.604428979Z Connection to nextcloud-aio-redis (172.18.0.9) 6379 port [tcp/redis] succeeded!
2024-07-01T23:24:40.202294299Z Checking connection to appstore
2024-07-01T23:24:41.638925014Z Appstore is reachable
2024-07-01T23:24:44.246242358Z Maintenance mode already disabled
2024-07-01T23:24:44.263898967Z Getting and backing up the status of apps for later, this might take a while...
2024-07-01T23:24:44.267096268Z Disabling apps before the update in order to make the update procedure more safe. This can take a while...
2024-07-01T23:24:45.741892988Z notes 4.9.4 disabled
2024-07-01T23:24:47.656445239Z cfg_share_links 5.1.0 disabled
2024-07-01T23:24:48.881184223Z richdocuments 8.3.8 disabled
2024-07-01T23:24:49.998802375Z contacts 5.5.3 disabled
2024-07-01T23:24:51.199535187Z extract 1.3.6 disabled
2024-07-01T23:24:52.429533353Z tasks 0.15.0 disabled
2024-07-01T23:24:53.665538046Z notify_push 0.6.12 disabled
2024-07-01T23:24:54.843448489Z theming_customcss 1.16.0 disabled
2024-07-01T23:24:56.072161463Z side_menu 3.12.0 disabled
2024-07-01T23:24:57.260979622Z epubviewer 1.6.2 disabled
2024-07-01T23:24:58.391022840Z calendar 4.7.0 disabled
2024-07-01T23:24:59.602837024Z twofactor_nextcloud_notification 3.9.0 disabled
2024-07-01T23:25:00.740774831Z No such app enabled: files_rightclick
2024-07-01T23:25:02.041956616Z spreed 18.0.9 disabled
2024-07-01T23:25:03.388023396Z deck 1.12.2 disabled
2024-07-01T23:25:04.330249915Z No such app enabled: passman
2024-07-01T23:25:04.791896561Z System config value app_install_overwrite deleted
2024-07-01T23:25:07.619763955Z notes new version available: 4.10.0
2024-07-01T23:15:25.210410541Z notes updated
2024-07-01T23:15:25.212850403Z tasks new version available: 0.16.0
2024-07-01T23:15:26.142128195Z tasks updated
2024-07-01T23:15:26.142670501Z epubviewer new version available: 1.6.3
2024-07-01T23:15:27.928562741Z epubviewer updated
2024-07-01T23:15:27.929378445Z calendar new version available: 4.7.8
2024-07-01T23:15:30.485007006Z calendar updated
2024-07-01T23:15:30.488725269Z deck new version available: 1.12.3
2024-07-01T23:15:32.646602801Z deck updated
2024-07-01T23:15:32.664995361Z passman new version available: 2.4.9
2024-07-01T23:15:34.279607801Z passman updated
2024-07-01T23:15:35.479954241Z Initializing nextcloud 29.0.3.4 ...
2024-07-01T23:15:46.121472214Z Initializing finished
2024-07-01T23:15:46.123833127Z Upgrading nextcloud from 28.0.4.1 to 29.0.3.4...
2024-07-01T23:15:46.702581005Z Nextcloud or one of the apps require upgrade - only a limited number of commands are available
2024-07-01T23:15:46.702617119Z You may use your browser or the occ upgrade command to do the upgrade
2024-07-01T23:15:46.718296954Z System config value integrity.check.disabled deleted
2024-07-01T23:15:47.093095459Z Nextcloud or one of the apps require upgrade - only a limited number of commands are available
2024-07-01T23:15:47.093121866Z You may use your browser or the occ upgrade command to do the upgrade
2024-07-01T23:15:47.111637708Z Setting log level to debug
2024-07-01T23:15:47.113707687Z Turned on maintenance mode
2024-07-01T23:15:47.498010263Z Updating database schema
2024-07-01T23:15:50.712890608Z Updated database
2024-07-01T23:15:50.723446840Z Updating <federation> ...
2024-07-01T23:15:50.734275279Z Updated <federation> to 1.19.0
2024-07-01T23:15:50.734915855Z Updating <lookup_server_connector> ...
2024-07-01T23:15:50.740419311Z Updated <lookup_server_connector> to 1.17.0
2024-07-01T23:15:50.740939182Z Updating <oauth2> ...
2024-07-01T23:15:50.970098070Z Updated <oauth2> to 1.17.0
2024-07-01T23:15:50.970461167Z Updating <password_policy> ...
2024-07-01T23:15:50.975951959Z Updated <password_policy> to 1.19.0
2024-07-01T23:15:50.976535283Z Updating <photos> ...
2024-07-01T23:15:51.299066964Z Updated <photos> to 2.5.0
2024-07-01T23:15:51.299534092Z Updating <suspicious_login> ...
2024-07-01T23:15:51.311078084Z Updated <suspicious_login> to 7.0.0
2024-07-01T23:15:51.312107064Z Updating <files> ...
2024-07-01T23:15:51.327036122Z Updated <files> to 2.1.0
2024-07-01T23:15:51.329529285Z Updating <activity> ...
2024-07-01T23:15:51.344626759Z Updated <activity> to 2.21.1
2024-07-01T23:15:51.345287390Z Updating <circles> ...
2024-07-01T23:15:51.679231454Z Updated <circles> to 29.0.0-dev
2024-07-01T23:15:51.679685158Z Updating <cloud_federation_api> ...
2024-07-01T23:15:51.685502511Z Updated <cloud_federation_api> to 1.12.0
2024-07-01T23:15:51.686146208Z Updating <dav> ...
2024-07-01T23:15:53.458321993Z Fix broken values of calendar objects
2024-07-01T23:15:53.458344498Z
2024-07-01T23:15:53.465482231Z Starting ...
2024-07-01T23:15:53.465927083Z 0/0 [>---------------------------] 0%
2024-07-01T23:15:53.499195862Z Clean up old calendar subscriptions from deleted users that were not cleaned-up
2024-07-01T23:15:53.499257003Z
2024-07-01T23:15:53.499453260Z Starting ...
2024-07-01T23:15:53.499660119Z 0/0 [->--------------------------] 0%
2024-07-01T23:15:53.519380443Z Updated <dav> to 1.30.1
2024-07-01T23:15:53.519758808Z Updating <files_external> ...
2024-07-01T23:15:53.527082988Z Updated <files_external> to 1.21.0
2024-07-01T23:15:53.562072687Z Updating <files_sharing> ...
2024-07-01T23:15:53.793851793Z Fix broken values of calendar objects
2024-07-01T23:15:53.793885463Z
2024-07-01T23:15:53.794175573Z Starting ...
2024-07-01T23:15:53.794437752Z 0/0 [--->------------------------] 0%
2024-07-01T23:15:53.808778153Z Clean up old calendar subscriptions from deleted users that were not cleaned-up
2024-07-01T23:15:53.808851000Z
2024-07-01T23:15:53.809065435Z Starting ...
2024-07-01T23:15:53.809273791Z 0/0 [----->----------------------] 0%
2024-07-01T23:15:53.816651455Z Updated <files_sharing> to 1.21.0
2024-07-01T23:15:53.817092689Z Updating <files_trashbin> ...
2024-07-01T23:15:53.824230174Z Updated <files_trashbin> to 1.19.0
2024-07-01T23:15:53.828408192Z Updating <files_versions> ...
2024-07-01T23:15:53.836149426Z Updated <files_versions> to 1.22.0
2024-07-01T23:15:53.841452462Z Updating <sharebymail> ...
2024-07-01T23:15:53.848110369Z Updated <sharebymail> to 1.19.0
2024-07-01T23:15:53.848654550Z Updating <workflowengine> ...
2024-07-01T23:15:54.080411973Z Fix broken values of calendar objects
2024-07-01T23:15:54.080439217Z
2024-07-01T23:15:54.080936103Z Starting ...
2024-07-01T23:15:54.081251182Z 0/0 [------->--------------------] 0%
2024-07-01T23:15:54.095793629Z Clean up old calendar subscriptions from deleted users that were not cleaned-up
2024-07-01T23:15:54.095829982Z
2024-07-01T23:15:54.096069109Z Starting ...
2024-07-01T23:15:54.096321988Z 0/0 [--------->------------------] 0%
2024-07-01T23:15:54.103375690Z Updated <workflowengine> to 2.11.0
2024-07-01T23:15:54.103729878Z Updating <admin_audit> ...
2024-07-01T23:15:54.110894513Z Updated <admin_audit> to 1.19.0
2024-07-01T23:15:54.115095917Z Updating <comments> ...
2024-07-01T23:15:54.120694580Z Updated <comments> to 1.19.0
2024-07-01T23:15:54.125330529Z Updating <firstrunwizard> ...
2024-07-01T23:15:54.131281103Z Updated <firstrunwizard> to 2.18.0
2024-07-01T23:15:54.131772048Z Updating <logreader> ...
2024-07-01T23:15:54.137239596Z Updated <logreader> to 2.14.0
2024-07-01T23:15:54.137656765Z Updating <nextcloud_announcements> ...
2024-07-01T23:15:54.144426599Z Updated <nextcloud_announcements> to 1.18.0
2024-07-01T23:15:54.144949888Z Updating <notifications> ...
2024-07-01T23:15:54.153739807Z Updated <notifications> to 2.17.0
2024-07-01T23:15:54.154257075Z Updating <systemtags> ...
2024-07-01T23:15:54.159291068Z Updated <systemtags> to 1.19.0
2024-07-01T23:15:54.160076157Z Updating <theming> ...
2024-07-01T23:15:54.383162668Z Fix broken values of calendar objects
2024-07-01T23:15:54.383183429Z
2024-07-01T23:15:54.383455637Z Starting ...
2024-07-01T23:15:54.383685888Z 0/0 [----------->----------------] 0%
2024-07-01T23:15:54.398326291Z Clean up old calendar subscriptions from deleted users that were not cleaned-up
2024-07-01T23:15:54.398347824Z
2024-07-01T23:15:54.398544566Z Starting ...
2024-07-01T23:15:54.398802755Z 0/0 [------------->--------------] 0%
2024-07-01T23:15:54.404927590Z Updated <theming> to 2.4.0
2024-07-01T23:15:54.405210715Z Updating <contactsinteraction> ...
2024-07-01T23:15:54.412576644Z Updated <contactsinteraction> to 1.10.0
2024-07-01T23:15:54.413059311Z Updating <federatedfilesharing> ...
2024-07-01T23:15:54.419216991Z Updated <federatedfilesharing> to 1.19.0
2024-07-01T23:15:54.419576970Z Updating <files_pdfviewer> ...
2024-07-01T23:15:54.424856594Z Updated <files_pdfviewer> to 2.10.0
2024-07-01T23:15:54.425215143Z Updating <files_reminders> ...
2024-07-01T23:15:54.434030523Z Updated <files_reminders> to 1.2.0
2024-07-01T23:15:54.434446008Z Updating <nextcloud-aio> ...
2024-07-01T23:15:54.439953389Z Updated <nextcloud-aio> to 0.6.0
2024-07-01T23:15:54.440421871Z Updating <privacy> ...
2024-07-01T23:15:54.446592895Z Updated <privacy> to 1.13.0
2024-07-01T23:15:54.447068100Z Updating <provisioning_api> ...
2024-07-01T23:15:54.452521259Z Updated <provisioning_api> to 1.19.0
2024-07-01T23:15:54.452913094Z Updating <recommendations> ...
2024-07-01T23:15:54.457784228Z Updated <recommendations> to 2.1.0
2024-07-01T23:15:54.458163319Z Updating <related_resources> ...
2024-07-01T23:15:54.462885085Z Updated <related_resources> to 1.4.0
2024-07-01T23:15:54.463222376Z Updating <serverinfo> ...
2024-07-01T23:15:54.469719222Z Updated <serverinfo> to 1.19.0
2024-07-01T23:15:54.470104620Z Updating <settings> ...
2024-07-01T23:15:54.475149756Z Updated <settings> to 1.12.0
2024-07-01T23:15:54.475508904Z Updating <support> ...
2024-07-01T23:15:54.704026923Z Fix broken values of calendar objects
2024-07-01T23:15:54.704099103Z
2024-07-01T23:15:54.704445799Z Starting ...
2024-07-01T23:15:54.704667486Z 0/0 [-------------->-------------] 0%
2024-07-01T23:15:54.717922869Z Clean up old calendar subscriptions from deleted users that were not cleaned-up
2024-07-01T23:15:54.718040577Z
2024-07-01T23:15:54.718301681Z Starting ...
2024-07-01T23:15:54.718593287Z 0/0 [---------------->-----------] 0%
2024-07-01T23:15:54.725684953Z Updated <support> to 1.12.0
2024-07-01T23:15:54.726157442Z Updating <survey_client> ...
2024-07-01T23:15:54.957364265Z Fix broken values of calendar objects
2024-07-01T23:15:54.957526899Z
2024-07-01T23:15:54.957786515Z Starting ...
2024-07-01T23:15:54.958035104Z 0/0 [------------------>---------] 0%
2024-07-01T23:15:54.971523697Z Clean up old calendar subscriptions from deleted users that were not cleaned-up
2024-07-01T23:15:54.971688029Z
2024-07-01T23:15:54.972024741Z Starting ...
2024-07-01T23:15:54.972260798Z 0/0 [-------------------->-------] 0%
2024-07-01T23:15:54.978333085Z Updated <survey_client> to 1.17.0
2024-07-01T23:15:54.978676502Z Updating <text> ...
2024-07-01T23:15:55.295687315Z Fix broken values of calendar objects
2024-07-01T23:15:55.295734065Z
2024-07-01T23:15:55.296183211Z Starting ...
2024-07-01T23:15:55.296429266Z 0/0 [---------------------->-----] 0%
2024-07-01T23:15:55.310736372Z Clean up old calendar subscriptions from deleted users that were not cleaned-up
2024-07-01T23:15:55.310765514Z
2024-07-01T23:15:55.311121972Z Starting ...
2024-07-01T23:15:55.311405291Z 0/0 [------------------------>---] 0%
2024-07-01T23:15:55.509037365Z Updated <text> to 3.10.1
2024-07-01T23:15:55.509380320Z Updating <twofactor_backupcodes> ...
2024-07-01T23:15:55.729271686Z Fix broken values of calendar objects
2024-07-01T23:15:55.729293664Z
2024-07-01T23:15:55.729583431Z Starting ...
2024-07-01T23:15:55.729883335Z 0/0 [-------------------------->-] 0%
2024-07-01T23:15:55.744625406Z Clean up old calendar subscriptions from deleted users that were not cleaned-up
2024-07-01T23:15:55.744644916Z
2024-07-01T23:15:55.744977939Z Starting ...
2024-07-01T23:15:55.745227079Z 0/0 [>---------------------------] 0%
2024-07-01T23:15:55.752657408Z Updated <twofactor_backupcodes> to 1.18.0
2024-07-01T23:15:55.752999407Z Updating <twofactor_totp> ...
2024-07-01T23:15:55.758399646Z Updated <twofactor_totp> to 11.0.0-dev
2024-07-01T23:15:55.758762014Z Updating <user_status> ...
2024-07-01T23:15:55.766606058Z Updated <user_status> to 1.9.0
2024-07-01T23:15:55.767087489Z Updating <viewer> ...
2024-07-01T23:15:55.772704023Z Updated <viewer> to 2.3.0
2024-07-01T23:15:55.773357700Z Updating <weather_status> ...
2024-07-01T23:15:55.779181110Z Updated <weather_status> to 1.9.0
2024-07-01T23:16:00.631333349Z Starting code integrity check...
2024-07-01T23:16:14.295205993Z Finished code integrity check
2024-07-01T23:16:14.296888937Z Update successful
2024-07-01T23:16:14.297501847Z Turned off maintenance mode
2024-07-01T23:16:14.297753735Z Resetting log level
2024-07-01T23:16:14.935031629Z Cloud 29.0.3
2024-07-01T23:16:15.591561203Z Posting notifications to users that are admins...
2024-07-01T23:16:17.915012010Z Posting 'Nextcloud update to 29.0.3.4 successful!' to: admin
2024-07-01T23:16:18.473715424Z Posting 'Nextcloud update to 29.0.3.4 successful!' to: user
2024-07-01T23:16:19.100246666Z Done!
2024-07-01T23:16:19.730072174Z richdocuments new version available: 8.4.3
2024-07-01T23:16:21.864248728Z richdocuments updated
2024-07-01T23:16:21.865159739Z contacts new version available: 6.0.0
2024-07-01T23:16:23.275124974Z contacts updated
2024-07-01T23:16:23.302851457Z spreed new version available: 19.0.4
2024-07-01T23:16:32.937474060Z spreed updated
2024-07-01T23:16:32.938141763Z deck new version available: 1.13.1
2024-07-01T23:16:34.949119613Z deck updated
2024-07-01T23:16:35.560249389Z Restoring the status of apps. This can take a while...
2024-07-01T23:16:35.560393114Z Enabling deck...
2024-07-01T23:16:36.146580323Z Enabling notes...
2024-07-01T23:16:36.688791422Z Enabling calendar...
2024-07-01T23:16:37.247558446Z Enabling notify_push...
2024-07-01T23:16:37.836666838Z Enabling richdocuments...
2024-07-01T23:16:38.450324618Z Enabling tasks...
2024-07-01T23:16:39.018111082Z Enabling extract...
2024-07-01T23:16:41.257816616Z The extract app could not get enabled. Probably because it is not compatible with the new Nextcloud version.
2024-07-01T23:16:41.797364151Z Posting notifications to users that are admins...
2024-07-01T23:16:44.377613554Z Posting 'Could not enable the extract app after the Nextcloud update!' to: admin
2024-07-01T23:16:44.911081865Z Posting 'Could not enable the extract app after the Nextcloud update!' to: user
2024-07-01T23:16:45.493593448Z Done!
2024-07-01T23:16:45.493621888Z Enabling epubviewer...
2024-07-01T23:16:46.149514404Z Enabling cfg_share_links...
2024-07-01T23:16:47.293293657Z Config value 'enabled' for app 'cfg_share_links' is now set to '["admin"]', stored as mixed in fast cache
2024-07-01T23:16:47.321359639Z Enabling spreed...
2024-07-01T23:16:47.965349698Z Enabling side_menu...
2024-07-01T23:16:48.652780115Z Enabling contacts...
2024-07-01T23:16:49.420793364Z Enabling twofactor_nextcloud_notification...
2024-07-01T23:16:50.110323582Z Enabling theming_customcss...
2024-07-01T23:16:51.411526979Z All apps are up-to-date or no updates could be found
2024-07-01T23:16:52.085256803Z Doing some optimizations...
2024-07-01T23:16:52.693562831Z - Repair MySQL collation
2024-07-01T23:16:52.693744144Z - Not a mysql database -> nothing to do
2024-07-01T23:16:52.693901665Z - Clean tags and favorites
2024-07-01T23:16:52.702117485Z - 0 tags of deleted users have been removed.
2024-07-01T23:16:52.706808699Z - 0 tags for delete files have been removed.
2024-07-01T23:16:52.707671229Z - 0 tag entries for deleted tags have been removed.
2024-07-01T23:16:52.708440649Z - 0 tags with no entries have been removed.
2024-07-01T23:16:52.708573790Z - Repair invalid shares
2024-07-01T23:16:52.711153228Z - Move .step file of updater to backup location
2024-07-01T23:16:52.711320033Z - Add move avatar background job
2024-07-01T23:16:52.711480452Z - Repair step already executed
2024-07-01T23:16:52.711636760Z - Add preview cleanup background jobs
2024-07-01T23:16:52.711827080Z - Migrate oauth2_clients table to nextcloud schema
2024-07-01T23:16:52.986267757Z - Update the oauth2_access_tokens table schema.
2024-07-01T23:16:53.186199893Z - Update the oauth2_clients table schema.
2024-07-01T23:16:53.670683301Z - Delete clients (and their related access tokens) with the redirect_uri starting with oc:// or ending with *
2024-07-01T23:16:53.674868145Z - Fix potential broken mount points
2024-07-01T23:16:53.676882489Z - No mounts updated
2024-07-01T23:16:53.677031286Z - Repair language codes
2024-07-01T23:16:53.677184735Z - Add log rotate job
2024-07-01T23:16:53.680422188Z - Clear frontend caches
2024-07-01T23:16:53.681027664Z - Image cache cleared
2024-07-01T23:16:53.698252798Z - JS cache cleared
2024-07-01T23:16:53.698358275Z - Clear every generated avatar
2024-07-01T23:16:53.698555825Z - Add preview background cleanup job
2024-07-01T23:16:53.700938670Z - Queue a one-time job to cleanup old backups of the updater
2024-07-01T23:16:53.702586758Z - Cleanup invalid photocache files for carddav
2024-07-01T23:16:53.702708645Z - Add background job to cleanup login flow v2 tokens
2024-07-01T23:16:53.704504538Z - Remove potentially over exposing share links
2024-07-01T23:16:53.704605283Z - No need to remove link shares.
2024-07-01T23:16:53.704755456Z - Clear access cache of projects
2024-07-01T23:16:53.704913032Z - Reset generated avatar flag
2024-07-01T23:16:53.705112231Z - Keep legacy encryption enabled
2024-07-01T23:16:53.705248011Z - Check encryption key format
2024-07-01T23:16:53.705393299Z - Remove old dashboard app config data
2024-07-01T23:16:53.705544233Z - Add job to cleanup the bruteforce entries
2024-07-01T23:16:53.707118239Z - Queue a one-time job to check for user uploaded certificates
2024-07-01T23:16:53.707267756Z - Repair DAV shares
2024-07-01T23:16:53.707415378Z - Add background job to set the lookup server share state for users
2024-07-01T23:16:53.709285886Z - Add token cleanup job
2024-07-01T23:16:53.710973756Z - Clean up abandoned apps
2024-07-01T23:16:53.711931088Z - Add possibly missing system config
2024-07-01T23:16:53.712050390Z - Add AI tasks cleanup job
2024-07-01T23:16:53.715100535Z - Queue a job to generate metadata
2024-07-01T23:16:53.716555852Z - migrate lazy config values
2024-07-01T23:16:53.719836499Z - Upgrading Circles App
2024-07-01T23:16:53.730732041Z - Fix component of birthday calendars
2024-07-01T23:16:53.732348402Z - 2 birthday calendars updated.
2024-07-01T23:16:53.732547842Z - Regenerating birthday calendars to use new icons and fix old birthday events without year
2024-07-01T23:16:53.732733523Z - Repair step already executed
2024-07-01T23:16:53.732920189Z - Fix broken values of calendar objects
2024-07-01T23:16:53.735304104Z 0 [>---------------------------]
2024-07-01T23:16:53.735486806Z - Registering building of calendar search index as background job
2024-07-01T23:16:53.735699857Z - Repair step already executed
2024-07-01T23:16:53.735877903Z - Register building of social profile search index as background job
2024-07-01T23:16:53.736097277Z - Repair step already executed
2024-07-01T23:16:53.736259181Z - Registering background jobs to update cache for webcal calendars
2024-07-01T23:16:53.737576310Z - Added 0 background jobs to update webcal calendars
2024-07-01T23:16:53.737755363Z - Registering building of calendar reminder index as background job
2024-07-01T23:16:53.737959047Z - Repair step already executed
2024-07-01T23:16:53.738198824Z - Clean up orphan event and contact data
2024-07-01T23:16:53.739770584Z - 0 events without a calendar have been cleaned up
2024-07-01T23:16:53.741384099Z - 0 properties without an events have been cleaned up
2024-07-01T23:16:53.742975234Z - 0 changes without a calendar have been cleaned up
2024-07-01T23:16:53.743869592Z - 0 cached events without a calendar subscription have been cleaned up
2024-07-01T23:16:53.744968720Z - 0 changes without a calendar subscription have been cleaned up
2024-07-01T23:16:53.746913603Z - 0 contacts without an addressbook have been cleaned up
2024-07-01T23:16:53.748796773Z - 0 properties without a contact have been cleaned up
2024-07-01T23:16:53.749970738Z - 0 changes without an addressbook have been cleaned up
2024-07-01T23:16:53.750172691Z - Remove activity entries of private events
2024-07-01T23:16:53.767505411Z - Removed 0 activity entries
2024-07-01T23:16:53.767526693Z - Clean up old calendar subscriptions from deleted users that were not cleaned-up
2024-07-01T23:16:53.768618296Z 0 [->--------------------------]
2024-07-01T23:16:53.768810413Z - 0 calendar subscriptions without an user have been cleaned up
2024-07-01T23:16:53.768976527Z - Remove invalid object properties
2024-07-01T23:16:53.770345882Z - 0 invalid object properties removed.
2024-07-01T23:16:53.770484401Z - Fix the share type of guest shares when migrating from ownCloud
2024-07-01T23:16:53.770626484Z - Copy the share password into the dedicated column
2024-07-01T23:16:53.770766674Z - Set existing shares as accepted
2024-07-01T23:16:53.770932383Z - Clean up meta table
2024-07-01T23:16:53.771813004Z - Show a hint about the new editor to existing users
2024-07-01T23:16:53.772009735Z - Set binary permissions
2024-07-01T23:16:53.772235244Z - Update OAuth token expiration times
2024-07-01T23:16:53.772933499Z - init metadata
2024-07-01T23:16:53.773888664Z - Create help command
2024-07-01T23:16:53.775881784Z - Invalidate access cache for projects conversation provider
2024-07-01T23:16:53.776088333Z - Invalidation not required
2024-07-01T23:16:53.776298864Z - Cache the user display names
2024-07-01T23:16:53.778213650Z - Switches from default updater server to the customer one if a valid subscription is available
2024-07-01T23:16:53.778455417Z - Repair step already executed
2024-07-01T23:16:53.778657557Z - Send an admin notification if monthly report is disabled
2024-07-01T23:16:53.779541828Z - Force-reset all Text document sessions
2024-07-01T23:16:53.779682134Z - Initialize migration of background images from dashboard to theming app
2024-07-01T23:16:53.782681008Z - Add background job to check for backup codes
2024-07-01T23:16:53.784199914Z - Populating added database structures for workflows
2024-07-01T23:16:54.683670030Z Adding additional oc_npushhash_di index to the oc_notifications_pushhash table, this can take some time...
2024-07-01T23:16:54.982261874Z oc_notifications_pushhash table updated successfully.
2024-07-01T23:16:54.982501107Z Adding additional schedulobj_lastmodified_idx index to the oc_schedulingobjects table, this can take some time...
2024-07-01T23:16:55.257500972Z oc_schedulingobjects table updated successfully.
2024-07-01T23:16:55.900666715Z Done.
2024-07-01T23:16:56.820208729Z Done.
2024-07-01T23:16:57.701496848Z All tables already up to date!
2024-07-01T23:16:58.397667955Z mimetypelist.js is updated
2024-07-01T23:16:59.030324943Z Added mimetype "audio/aac" to database
2024-07-01T23:16:59.045534862Z Added mimetype "text/x-rst" to database
2024-07-01T23:16:59.052317769Z Added 2 new mimetypes
2024-07-01T23:16:59.052346782Z Updated 0 filecache rows
2024-07-01T23:17:00.393422518Z Applying one-click-instance settings...
2024-07-01T23:17:01.009438767Z System config value one-click-instance set to boolean true
2024-07-01T23:17:01.716113390Z System config value one-click-instance.user-limit set to integer 100
2024-07-01T23:17:02.459114959Z System config value one-click-instance.link set to string https://nextcloud.com/all-in-one/
2024-07-01T23:17:03.088603762Z support already enabled
2024-07-01T23:17:03.112496124Z Adjusting log files...
2024-07-01T23:17:03.718680188Z System config value upgrade.cli-upgrade-link set to string https://github.com/nextcloud/all-in-one/discussions/2726
2024-07-01T23:17:04.402282728Z System config value logfile set to string /var/www/html/data/nextcloud.log
2024-07-01T23:17:05.027065640Z Config value were not updated
2024-07-01T23:17:05.632986967Z System config value updatedirectory set to string /nc-updater
2024-07-01T23:17:06.303967234Z Applying network settings...
2024-07-01T23:17:06.915158748Z System config value allow_local_remote_servers set to boolean true
2024-07-01T23:17:07.585418393Z System config value davstorage.request_timeout set to integer 3600
2024-07-01T23:17:08.259209772Z System config value trusted_domains => 1 set to string nextcloud.domain.tld
2024-07-01T23:17:08.873657001Z System config value overwrite.cli.url set to string https://nextcloud.domain.tld/
2024-07-01T23:17:09.536999385Z System config value htaccess.RewriteBase set to string /
2024-07-01T23:17:10.200328234Z .htaccess has been updated
2024-07-01T23:17:10.825078104Z System config value dbpersistent set to boolean false
2024-07-01T23:17:11.471256012Z System config value auth.bruteforce.protection.enabled set to boolean true
2024-07-01T23:17:12.113019406Z System config value ratelimit.protection.enabled set to boolean true
2024-07-01T23:17:12.733861235Z System config value files_external_allow_create_new_local set to boolean false
2024-07-01T23:17:14.678409905Z notify_push is up-to-date or no updates could be found
2024-07-01T23:17:15.293968056Z System config value trusted_proxies => 0 set to string 127.0.0.1
2024-07-01T23:17:15.941929633Z System config value trusted_proxies => 1 set to string ::1
2024-07-01T23:17:16.660243878Z System config value trusted_proxies => 10 set to string 172.18.0.0/16
2024-07-01T23:17:17.331017039Z Config value were not updated
2024-07-01T23:17:17.358066269Z + + grep -q echo 'nextcloud-.*-collabora'
2024-07-01T23:17:17.358311094Z nextcloud-aio-collabora
2024-07-01T23:17:17.364075685Z + COLLABORA_HOST=nextcloud.domain.tld
2024-07-01T23:17:17.364113895Z + set +x
2024-07-01T23:17:18.695516496Z richdocuments is up-to-date or no updates could be found
2024-07-01T23:17:19.399031567Z Config value were not updated
2024-07-01T23:17:20.194874008Z No ipv6-address found for nextcloud.domain.tld.
2024-07-01T23:17:20.774588310Z Config value were not updated
2024-07-01T23:17:20.794305747Z + '[' -z '' ']'
2024-07-01T23:17:20.794336891Z + TALK_HOST=nextcloud.domain.tld
2024-07-01T23:17:20.794342757Z + HPB_PATH=/standalone-signaling/
2024-07-01T23:17:20.794347581Z + '[' -z '' ']'
2024-07-01T23:17:20.794352398Z + TURN_DOMAIN=nextcloud.domain.tld
2024-07-01T23:17:20.794357226Z + set +x
2024-07-01T23:17:22.067959479Z spreed is up-to-date or no updates could be found
2024-07-01T23:17:24.671122494Z Config value recording_servers of app spreed deleted
2024-07-01T23:17:25.287108748Z System config value enabledPreviewProviders => 0 set to string OC\Preview\Imaginary
2024-07-01T23:17:25.939416526Z System config value preview_imaginary_url set to string http://nextcloud-aio-imaginary:9000
2024-07-01T23:17:26.603348646Z System config value preview_imaginary_key set to string 6effe65de83caf2e7976513f834e017a5f483d5f808cdbe9
2024-07-01T23:17:26.656459417Z + '[' true = true ']'
2024-07-01T23:17:26.656660775Z + '[' 443 = 443 ']'
2024-07-01T23:17:26.657192853Z ++ head -n1
2024-07-01T23:17:26.657660732Z ++ sort
2024-07-01T23:17:26.659162805Z ++ grep '^[0-9.]\+$'
2024-07-01T23:17:26.662918716Z ++ dig nextcloud-aio-apache A +short +search
2024-07-01T23:17:26.689670482Z + IPv4_ADDRESS_APACHE=172.18.0.6
2024-07-01T23:17:26.693427606Z ++ head -n1
2024-07-01T23:17:26.693465553Z ++ sort
2024-07-01T23:17:26.693775546Z ++ grep '^[0-9a-f:]\+$'
2024-07-01T23:17:26.695301263Z ++ dig nextcloud-aio-apache AAAA +short +search
2024-07-01T23:17:26.720308014Z + IPv6_ADDRESS_APACHE=
2024-07-01T23:17:26.723413374Z ++ sort
2024-07-01T23:17:26.723850737Z ++ grep '^[0-9.]\+$'
2024-07-01T23:17:26.724829493Z ++ dig nextcloud-aio-mastercontainer A +short +search
2024-07-01T23:17:26.727923444Z ++ head -n1
2024-07-01T23:17:26.751144038Z + IPv4_ADDRESS_MASTERCONTAINER=172.18.0.5
2024-07-01T23:17:26.752321045Z ++ dig nextcloud-aio-mastercontainer AAAA +short +search
2024-07-01T23:17:26.755436720Z ++ grep '^[0-9a-f:]\+$'
2024-07-01T23:17:26.755908940Z ++ sort
2024-07-01T23:17:26.757942285Z ++ head -n1
2024-07-01T23:17:26.781731782Z + IPv6_ADDRESS_MASTERCONTAINER=
2024-07-01T23:17:26.782285612Z + sed -i 's|^;listen.allowed_clients|listen.allowed_clients|' /usr/local/etc/php-fpm.d/www.conf
2024-07-01T23:17:26.789250980Z + sed -i 's|listen.allowed_clients.*|listen.allowed_clients = 127.0.0.1,::1,172.18.0.6,,172.18.0.5,|' /usr/local/etc/php-fpm.d/www.conf
2024-07-01T23:17:26.792390765Z + sed -i '/^listen.allowed_clients/s/,,/,/g' /usr/local/etc/php-fpm.d/www.conf
2024-07-01T23:17:26.795253191Z + sed -i '/^listen.allowed_clients/s/,$//' /usr/local/etc/php-fpm.d/www.conf
2024-07-01T23:17:26.797296584Z + grep listen.allowed_clients /usr/local/etc/php-fpm.d/www.conf
2024-07-01T23:17:26.798469653Z listen.allowed_clients = 127.0.0.1,::1,172.18.0.6,172.18.0.5
2024-07-01T23:17:26.798978376Z + set +x
2024-07-01T23:17:28.503892143Z [01-Jul-2024 23:17:28] NOTICE: fpm is running, pid 1326
2024-07-01T23:17:28.503949766Z [01-Jul-2024 23:17:28] NOTICE: ready to handle connections
2024-07-01T23:17:43.288436265Z Activating Collabora config...
2024-07-01T23:17:44.050269828Z ✓ Reset callback url autodetect
2024-07-01T23:17:44.050327969Z Checking configuration
2024-07-01T23:17:44.050335814Z 🛈 Configured WOPI URL: https://nextcloud.domain.tld
2024-07-01T23:17:44.050341672Z 🛈 Configured public WOPI URL: https://nextcloud.domain.tld
2024-07-01T23:17:44.050347325Z 🛈 Configured callback URL:
2024-07-01T23:17:44.050352668Z
2024-07-01T23:17:44.132189382Z Failed to fetch discovery endpoint from https://nextcloud.domain.tld
2024-07-01T23:17:44.132503888Z cURL error 60: SSL certificate problem: self-signed certificate in certificate chain (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://nextcloud.domain.tld/hosting/discovery
2024-07-02T00:25:55.721081698Z [02-Jul-2024 00:25:55] NOTICE: Terminating ...
2024-07-02T00:25:55.726539015Z [02-Jul-2024 00:25:55] NOTICE: exiting, bye-bye!
2024-07-02T00:25:56.734075924Z +++ pgrep -f /var/www/html/cron.php
2024-07-02T00:25:56.748242687Z ++ '[' -n '' ']'
2024-07-02T00:25:56.748271284Z ++ echo 'Cronjob successfully exited.'
2024-07-02T00:25:56.748275422Z ++ exit
2024-07-02T00:25:56.748450602Z Cronjob successfully exited.
2024-07-02T00:46:17.808699879Z Waiting for database to start...
2024-07-02T00:46:22.874328746Z Connection to nextcloud-aio-database (172.18.0.8) 5432 port [tcp/postgresql] succeeded!
2024-07-02T00:46:24.950467365Z now
2024-07-02T00:46:24.950567037Z -------------------------------
2024-07-02T00:46:24.950574430Z 2024-07-02 00:46:24.942224+00
2024-07-02T00:46:24.950578017Z (1 row)
2024-07-02T00:46:24.950581224Z
2024-07-02T00:46:24.962455138Z + '[' -f /dev-dri-group-was-added ']'
2024-07-02T00:46:24.963725522Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-07-02T00:46:24.965143421Z + '[' -n '' ']'
2024-07-02T00:46:24.965518050Z + set +x
2024-07-02T00:46:24.997002609Z Connection to nextcloud-aio-redis (172.18.0.7) 6379 port [tcp/redis] succeeded!
2024-07-02T00:46:28.088489850Z Applying one-click-instance settings...
2024-07-02T00:46:28.778644886Z System config value one-click-instance set to boolean true
2024-07-02T00:46:29.489285073Z System config value one-click-instance.user-limit set to integer 100
2024-07-02T00:46:30.214155134Z System config value one-click-instance.link set to string https://nextcloud.com/all-in-one/
2024-07-02T00:46:30.985134222Z support already enabled
2024-07-02T00:46:31.018934506Z Adjusting log files...
2024-07-02T00:46:31.619400532Z System config value upgrade.cli-upgrade-link set to string https://github.com/nextcloud/all-in-one/discussions/2726
2024-07-02T00:46:32.279877077Z System config value logfile set to string /var/www/html/data/nextcloud.log
2024-07-02T00:46:32.915617344Z Config value were not updated
2024-07-02T00:46:33.538305547Z System config value updatedirectory set to string /nc-updater
2024-07-02T00:46:34.143047419Z Applying network settings...
2024-07-02T00:46:34.708022242Z System config value allow_local_remote_servers set to boolean true
2024-07-02T00:46:35.347835451Z System config value davstorage.request_timeout set to integer 3600
2024-07-02T00:46:36.066694193Z System config value trusted_domains => 1 set to string nextcloud.domain.tld
2024-07-02T00:46:36.680786747Z System config value overwrite.cli.url set to string https://nextcloud.domain.tld/
2024-07-02T00:46:37.310800324Z System config value htaccess.RewriteBase set to string /
2024-07-02T00:46:37.964496304Z .htaccess has been updated
2024-07-02T00:46:38.564529091Z System config value dbpersistent set to boolean false
2024-07-02T00:46:39.186364766Z System config value auth.bruteforce.protection.enabled set to boolean true
2024-07-02T00:46:39.847986826Z System config value ratelimit.protection.enabled set to boolean true
2024-07-02T00:46:40.457675152Z System config value files_external_allow_create_new_local set to boolean false
2024-07-02T00:46:43.026507111Z notify_push is up-to-date or no updates could be found
2024-07-02T00:37:00.207655582Z System config value trusted_proxies => 0 set to string 127.0.0.1
2024-07-02T00:37:00.790791435Z System config value trusted_proxies => 1 set to string ::1
2024-07-02T00:37:01.479791690Z System config value trusted_proxies => 10 set to string 172.18.0.0/16
2024-07-02T00:37:02.104760403Z Config value were not updated
2024-07-02T00:37:02.126356332Z + grep -q 'nextcloud-.*-collabora'
2024-07-02T00:37:02.127376886Z + echo nextcloud-aio-collabora
2024-07-02T00:37:02.128174695Z + COLLABORA_HOST=nextcloud.domain.tld
2024-07-02T00:37:02.129001632Z + set +x
2024-07-02T00:37:03.588835688Z richdocuments is up-to-date or no updates could be found
2024-07-02T00:37:04.429633265Z Config value were not updated
2024-07-02T00:37:05.092513459Z No ipv6-address found for nextcloud.domain.tld.
2024-07-02T00:37:05.664812891Z Config value were not updated
2024-07-02T00:37:05.690473536Z + '[' -z '' ']'
2024-07-02T00:37:05.690523428Z + TALK_HOST=nextcloud.domain.tld
2024-07-02T00:37:05.690528511Z + HPB_PATH=/standalone-signaling/
2024-07-02T00:37:05.690532195Z + '[' -z '' ']'
2024-07-02T00:37:05.690535466Z + TURN_DOMAIN=nextcloud.domain.tld
2024-07-02T00:37:05.690538949Z + set +x
2024-07-02T00:37:06.964409397Z spreed is up-to-date or no updates could be found
2024-07-02T00:37:09.444514702Z Config value recording_servers of app spreed deleted
2024-07-02T00:37:10.033305575Z System config value enabledPreviewProviders => 0 set to string OC\Preview\Imaginary
2024-07-02T00:37:10.669540288Z System config value preview_imaginary_url set to string http://nextcloud-aio-imaginary:9000
2024-07-02T00:37:11.301945103Z System config value preview_imaginary_key set to string 6effe65de83caf2e7976513f834e017a5f483d5f808cdbe9
2024-07-02T00:37:11.357681249Z + '[' true = true ']'
2024-07-02T00:37:11.358318195Z + '[' 443 = 443 ']'
2024-07-02T00:37:11.359780346Z ++ dig nextcloud-aio-apache A +short +search
2024-07-02T00:37:11.360929408Z ++ grep '^[0-9.]\+$'
2024-07-02T00:37:11.361166089Z ++ sort
2024-07-02T00:37:11.365001872Z ++ head -n1
2024-07-02T00:37:11.384853041Z + IPv4_ADDRESS_APACHE=172.18.0.6
2024-07-02T00:37:11.385996829Z ++ dig nextcloud-aio-apache AAAA +short +search
2024-07-02T00:37:11.386516003Z ++ grep '^[0-9a-f:]\+$'
2024-07-02T00:37:11.386706183Z ++ sort
2024-07-02T00:37:11.387561605Z ++ head -n1
2024-07-02T00:37:11.411577831Z + IPv6_ADDRESS_APACHE=
2024-07-02T00:37:11.413334102Z ++ dig nextcloud-aio-mastercontainer A +short +search
2024-07-02T00:37:11.413811688Z ++ sort
2024-07-02T00:37:11.414271465Z ++ grep '^[0-9.]\+$'
2024-07-02T00:37:11.415343250Z ++ head -n1
2024-07-02T00:37:11.438963454Z + IPv4_ADDRESS_MASTERCONTAINER=172.18.0.10
2024-07-02T00:37:11.440673992Z ++ dig nextcloud-aio-mastercontainer AAAA +short ++ grep '^[0-9a-f:]\+$'
2024-07-02T00:37:11.440930049Z +search
2024-07-02T00:37:11.441779984Z ++ sort
2024-07-02T00:37:11.441991283Z ++ head -n1
2024-07-02T00:37:11.465055479Z + IPv6_ADDRESS_MASTERCONTAINER=
2024-07-02T00:37:11.466151238Z + sed -i 's|^;listen.allowed_clients|listen.allowed_clients|' /usr/local/etc/php-fpm.d/www.conf
2024-07-02T00:37:11.473965115Z + sed -i 's|listen.allowed_clients.*|listen.allowed_clients = 127.0.0.1,::1,172.18.0.6,,172.18.0.10,|' /usr/local/etc/php-fpm.d/www.conf
2024-07-02T00:37:11.477424014Z + sed -i '/^listen.allowed_clients/s/,,/,/g' /usr/local/etc/php-fpm.d/www.conf
2024-07-02T00:37:11.480520893Z + sed -i '/^listen.allowed_clients/s/,$//' /usr/local/etc/php-fpm.d/www.conf
2024-07-02T00:37:11.482699574Z + grep listen.allowed_clients /usr/local/etc/php-fpm.d/www.conf
2024-07-02T00:37:11.484094243Z listen.allowed_clients = 127.0.0.1,::1,172.18.0.6,172.18.0.10
2024-07-02T00:37:11.484778067Z + set +x
2024-07-02T00:37:13.145792295Z [02-Jul-2024 00:37:13] NOTICE: fpm is running, pid 474
2024-07-02T00:37:13.145817771Z [02-Jul-2024 00:37:13] NOTICE: ready to handle connections
2024-07-02T00:37:27.977460246Z Activating Collabora config...
2024-07-02T00:37:28.631521384Z ✓ Reset callback url autodetect
2024-07-02T00:37:28.631582242Z Checking configuration
2024-07-02T00:37:28.631587027Z 🛈 Configured WOPI URL: https://nextcloud.domain.tld
2024-07-02T00:37:28.631590714Z 🛈 Configured public WOPI URL: https://nextcloud.domain.tld
2024-07-02T00:37:28.631594567Z 🛈 Configured callback URL:
2024-07-02T00:37:28.631598082Z
2024-07-02T00:37:28.690131993Z Failed to fetch discovery endpoint from https://nextcloud.domain.tld
2024-07-02T00:37:28.690162754Z cURL error 60: SSL certificate problem: self-signed certificate in certificate chain (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://nextcloud.domain.tld/hosting/discovery
2024-07-02T00:49:36.480739063Z [02-Jul-2024 00:49:36] NOTICE: Terminating ...
2024-07-02T00:49:36.480805487Z [02-Jul-2024 00:49:36] NOTICE: exiting, bye-bye!
2024-07-02T00:49:36.499509339Z +++ pgrep -f /var/www/html/cron.php
2024-07-02T00:49:36.514028070Z Cronjob successfully exited.
2024-07-02T00:49:36.514048267Z ++ '[' -n '' ']'
2024-07-02T00:49:36.514101233Z ++ echo 'Cronjob successfully exited.'
2024-07-02T00:49:36.514105670Z ++ exit
2024-07-02T01:22:35.212657388Z Connection to nextcloud-aio-database (172.18.0.4) 5432 port [tcp/postgresql] succeeded!
2024-07-02T01:22:37.387912167Z now
2024-07-02T01:22:37.387940870Z -------------------------------
2024-07-02T01:22:37.387945150Z 2024-07-02 01:22:37.370963+00
2024-07-02T01:22:37.387948440Z (1 row)
2024-07-02T01:22:37.387951590Z
2024-07-02T01:22:37.423238443Z + '[' -f /dev-dri-group-was-added ']'
2024-07-02T01:22:37.424526327Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-07-02T01:22:37.428986699Z + '[' -n '' ']'
2024-07-02T01:22:37.429008464Z + set +x
2024-07-02T01:22:37.542353643Z Connection to nextcloud-aio-redis (172.18.0.8) 6379 port [tcp/redis] succeeded!
2024-07-02T01:22:42.477947918Z Applying one-click-instance settings...
2024-07-02T01:22:43.149658225Z System config value one-click-instance set to boolean true
2024-07-02T01:22:43.849838747Z System config value one-click-instance.user-limit set to integer 100
2024-07-02T01:22:44.500348317Z System config value one-click-instance.link set to string https://nextcloud.com/all-in-one/
2024-07-02T01:22:45.445300793Z support already enabled
2024-07-02T01:22:45.476749012Z Adjusting log files...
2024-07-02T01:22:46.177607189Z System config value upgrade.cli-upgrade-link set to string https://github.com/nextcloud/all-in-one/discussions/2726
2024-07-02T01:22:46.984023783Z System config value logfile set to string /var/www/html/data/nextcloud.log
2024-07-02T01:22:47.683976840Z Config value were not updated
2024-07-02T01:22:48.414408199Z System config value updatedirectory set to string /nc-updater
2024-07-02T01:22:49.250909932Z Applying network settings...
2024-07-02T01:22:49.893458988Z System config value allow_local_remote_servers set to boolean true
2024-07-02T01:22:50.487279792Z System config value davstorage.request_timeout set to integer 3600
2024-07-02T01:22:51.115403280Z System config value trusted_domains => 1 set to string nextcloud.domain.tld
2024-07-02T01:22:51.748184281Z System config value overwrite.cli.url set to string https://nextcloud.domain.tld/
2024-07-02T01:22:52.387538081Z System config value htaccess.RewriteBase set to string /
2024-07-02T01:22:53.021929153Z .htaccess has been updated
2024-07-02T01:22:53.619728531Z System config value dbpersistent set to boolean false
2024-07-02T01:22:54.212884994Z System config value auth.bruteforce.protection.enabled set to boolean true
2024-07-02T01:22:54.896954565Z System config value ratelimit.protection.enabled set to boolean true
2024-07-02T01:22:55.485756222Z System config value files_external_allow_create_new_local set to boolean false
2024-07-02T01:22:57.393483784Z notify_push is up-to-date or no updates could be found
2024-07-02T01:22:57.976458472Z System config value trusted_proxies => 0 set to string 127.0.0.1
2024-07-02T01:22:58.566785955Z System config value trusted_proxies => 1 set to string ::1
2024-07-02T01:22:59.231302888Z System config value trusted_proxies => 10 set to string 172.18.0.0/16
2024-07-02T01:22:59.843575961Z Config value were not updated
2024-07-02T01:22:59.870042490Z + echo nextcloud-aio-collabora
2024-07-02T01:22:59.870849390Z + grep -q 'nextcloud-.*-collabora'
2024-07-02T01:22:59.878685529Z + COLLABORA_HOST=nextcloud.domain.tld
2024-07-02T01:22:59.878703481Z + set +x
2024-07-02T01:13:17.066920361Z richdocuments is up-to-date or no updates could be found
2024-07-02T01:13:17.684889171Z Config value were not updated
2024-07-02T01:13:18.350858899Z No ipv6-address found for nextcloud.domain.tld.
2024-07-02T01:13:18.994409539Z Config value were not updated
2024-07-02T01:13:19.018127961Z + '[' -z '' ']'
2024-07-02T01:13:19.018171102Z + TALK_HOST=nextcloud.domain.tld
2024-07-02T01:13:19.018175454Z + HPB_PATH=/standalone-signaling/
2024-07-02T01:13:19.018178815Z + '[' -z '' ']'
2024-07-02T01:13:19.018181618Z + TURN_DOMAIN=nextcloud.domain.tld
2024-07-02T01:13:19.018248441Z + set +x
2024-07-02T01:13:20.421546185Z spreed is up-to-date or no updates could be found
2024-07-02T01:13:23.002673388Z Config value recording_servers of app spreed deleted
2024-07-02T01:13:23.580395406Z System config value enabledPreviewProviders => 0 set to string OC\Preview\Imaginary
2024-07-02T01:13:24.167589372Z System config value preview_imaginary_url set to string http://nextcloud-aio-imaginary:9000
2024-07-02T01:13:24.755868880Z System config value preview_imaginary_key set to string 6effe65de83caf2e7976513f834e017a5f483d5f808cdbe9
2024-07-02T01:13:24.805270883Z + '[' true = true ']'
2024-07-02T01:13:24.806129517Z + '[' 443 = 443 ']'
2024-07-02T01:13:24.807421288Z ++ dig nextcloud-aio-apache A +short +search
2024-07-02T01:13:24.810327023Z ++ grep '^[0-9.]\+$'
2024-07-02T01:13:24.810585351Z ++ sort
2024-07-02T01:13:24.814972043Z ++ head -n1
2024-07-02T01:13:24.832826801Z + IPv4_ADDRESS_APACHE=172.18.0.7
2024-07-02T01:13:24.834140454Z ++ dig nextcloud-aio-apache AAAA +short +search
2024-07-02T01:13:24.834433456Z ++ grep '^[0-9a-f:]\+$'
2024-07-02T01:13:24.835298759Z ++ sort
2024-07-02T01:13:24.835625391Z ++ head -n1
2024-07-02T01:13:24.856036151Z + IPv6_ADDRESS_APACHE=
2024-07-02T01:13:24.856779631Z ++ dig nextcloud-aio-mastercontainer A +short +search
2024-07-02T01:13:24.857461249Z ++ grep '^[0-9.]\+$'
2024-07-02T01:13:24.858216570Z ++ sort
2024-07-02T01:13:24.858937661Z ++ head -n1
2024-07-02T01:13:24.882189053Z + IPv4_ADDRESS_MASTERCONTAINER=172.18.0.5
2024-07-02T01:13:24.882908231Z ++ dig nextcloud-aio-mastercontainer AAAA +short +search
2024-07-02T01:13:24.883552704Z ++ grep '^[0-9a-f:]\+$'
2024-07-02T01:13:24.884359699Z ++ sort
2024-07-02T01:13:24.884783794Z ++ head -n1
2024-07-02T01:13:24.908220038Z + IPv6_ADDRESS_MASTERCONTAINER=
2024-07-02T01:13:24.908482547Z + sed -i 's|^;listen.allowed_clients|listen.allowed_clients|' /usr/local/etc/php-fpm.d/www.conf
2024-07-02T01:13:24.915088577Z + sed -i 's|listen.allowed_clients.*|listen.allowed_clients = 127.0.0.1,::1,172.18.0.7,,172.18.0.5,|' /usr/local/etc/php-fpm.d/www.conf
2024-07-02T01:13:24.918019178Z + sed -i '/^listen.allowed_clients/s/,,/,/g' /usr/local/etc/php-fpm.d/www.conf
2024-07-02T01:13:24.921683663Z + sed -i '/^listen.allowed_clients/s/,$//' /usr/local/etc/php-fpm.d/www.conf
2024-07-02T01:13:24.923890301Z + grep listen.allowed_clients /usr/local/etc/php-fpm.d/www.conf
2024-07-02T01:13:24.925194863Z listen.allowed_clients = 127.0.0.1,::1,172.18.0.7,172.18.0.5
2024-07-02T01:13:24.925449090Z + set +x
2024-07-02T01:13:26.574942895Z [02-Jul-2024 01:13:26] NOTICE: fpm is running, pid 475
2024-07-02T01:13:26.575051499Z [02-Jul-2024 01:13:26] NOTICE: ready to handle connections
2024-07-02T01:13:41.413098073Z Activating Collabora config...
2024-07-02T01:13:42.097735189Z ✓ Reset callback url autodetect
2024-07-02T01:13:42.097811391Z Checking configuration
2024-07-02T01:13:42.097820421Z 🛈 Configured WOPI URL: https://nextcloud.domain.tld
2024-07-02T01:13:42.097826807Z 🛈 Configured public WOPI URL: https://nextcloud.domain.tld
2024-07-02T01:13:42.097833240Z 🛈 Configured callback URL:
2024-07-02T01:13:42.097839261Z
2024-07-02T01:13:42.156411759Z Failed to fetch discovery endpoint from https://nextcloud.domain.tld
2024-07-02T01:13:42.156533023Z cURL error 60: SSL certificate problem: self-signed certificate in certificate chain (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://nextcloud.domain.tld/hosting/discovery
I have no idea how to access the config.php files from a docker container. If it’s required, please notify me and I’ll try to figure out how to.
The output of Nextcloud AIO Apache
container :
2024-07-01T21:17:00.852699010Z Waiting for Nextcloud to start...
2024-07-01T21:17:05.856101437Z Connection to nextcloud-aio-nextcloud (172.18.0.7) 9000 port [tcp/*] succeeded!
2024-07-01T21:17:07.470524209Z [Mon Jul 01 21:17:07.469903 2024] [mpm_event:notice] [pid 53:tid 139968126130984] AH00489: Apache/2.4.59 (Unix) configured -- resuming normal operations
2024-07-01T21:17:07.470584976Z [Mon Jul 01 21:17:07.469995 2024] [core:notice] [pid 53:tid 139968126130984] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
2024-07-01T21:17:07.508444836Z {"level":"info","ts":1719868627.5075228,"msg":"using config from file","file":"/tmp/Caddyfile"}
2024-07-01T21:17:07.515676526Z {"level":"info","ts":1719868627.5153105,"msg":"adapted config to JSON","adapter":"caddyfile"}
2024-07-01T21:17:07.532548755Z {"level":"info","ts":1719868627.5320961,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
2024-07-01T23:17:24.262265948Z Waiting for Nextcloud to start...
2024-07-01T23:17:29.266941567Z Connection to nextcloud-aio-nextcloud (172.18.0.7) 9000 port [tcp/*] succeeded!
2024-07-01T23:17:31.263392613Z [Mon Jul 01 23:17:31.262617 2024] [mpm_event:notice] [pid 128:tid 139716551797544] AH00489: Apache/2.4.59 (Unix) configured -- resuming normal operations
2024-07-01T23:17:31.263633046Z [Mon Jul 01 23:17:31.263383 2024] [core:notice] [pid 128:tid 139716551797544] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
2024-07-01T23:17:31.280897711Z {"level":"info","ts":1719875851.2803996,"msg":"using config from file","file":"/tmp/Caddyfile"}
2024-07-01T23:17:31.284413671Z {"level":"info","ts":1719875851.2841513,"msg":"adapted config to JSON","adapter":"caddyfile"}
2024-07-01T23:17:31.290897388Z {"level":"info","ts":1719875851.2905128,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
2024-07-02T00:46:17.294730327Z Waiting for Nextcloud to start...
2024-07-02T00:37:08.910507296Z Waiting for Nextcloud to start...
2024-07-02T00:37:13.913505931Z Connection to nextcloud-aio-nextcloud (172.18.0.4) 9000 port [tcp/*] succeeded!
2024-07-02T00:37:15.918938705Z {"level":"info","ts":1719880635.9182475,"msg":"using config from file","file":"/tmp/Caddyfile"}
2024-07-02T00:37:15.922944806Z {"level":"info","ts":1719880635.9226887,"msg":"adapted config to JSON","adapter":"caddyfile"}
2024-07-02T00:37:15.930395387Z {"level":"info","ts":1719880635.930021,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
2024-07-02T00:37:15.935220341Z [Tue Jul 02 00:37:15.934912 2024] [mpm_event:notice] [pid 51:tid 139627430406952] AH00489: Apache/2.4.59 (Unix) configured -- resuming normal operations
2024-07-02T00:37:15.935547231Z [Tue Jul 02 00:37:15.935288 2024] [core:notice] [pid 51:tid 139627430406952] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
2024-07-02T00:49:36.533200820Z [Tue Jul 02 00:49:36 2024] [error] [(111)Connection refused] [client: [AH00957: FCGI: attempt to connect to 172.18.0.4:9000 (nextcloud-aio-nextcloud:9000) failed]
2024-07-02T00:49:36.544867573Z [Tue Jul 02 00:49:36 2024] [error] [client: 98.148.240.99] [AH01079: failed to make connection to backend: nextcloud-aio-nextcloud] [Mozilla/5.0 (Linux) mirall/3.13.0git (Nextcloud, arch-6.9.6-arch1-1 ClientArchitecture: x86_64 OsArchitecture: x86_64)]
2024-07-02T01:22:34.606979792Z Waiting for Nextcloud to start...
2024-07-02T01:22:39.609109356Z Waiting for Nextcloud to start...
2024-07-02T01:22:44.612736560Z Waiting for Nextcloud to start...
2024-07-02T01:22:49.615936992Z Waiting for Nextcloud to start...
2024-07-02T01:22:54.618630754Z Waiting for Nextcloud to start...
2024-07-02T01:22:59.621445151Z Waiting for Nextcloud to start...
2024-07-02T01:13:20.594177284Z Waiting for Nextcloud to start...
2024-07-02T01:13:25.595176449Z Waiting for Nextcloud to start...
2024-07-02T01:13:30.599522102Z Connection to nextcloud-aio-nextcloud (172.18.0.3) 9000 port [tcp/*] succeeded!
2024-07-02T01:13:32.466168507Z [Tue Jul 02 01:13:32.465661 2024] [mpm_event:notice] [pid 52:tid 139653111319336] AH00489: Apache/2.4.59 (Unix) configured -- resuming normal operations
2024-07-02T01:13:32.466209394Z [Tue Jul 02 01:13:32.465774 2024] [core:notice] [pid 52:tid 139653111319336] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
2024-07-02T01:13:32.496328391Z {"level":"info","ts":1719882812.4957905,"msg":"using config from file","file":"/tmp/Caddyfile"}
2024-07-02T01:13:32.498828398Z {"level":"info","ts":1719882812.498628,"msg":"adapted config to JSON","adapter":"caddyfile"}
2024-07-02T01:13:32.505510640Z {"level":"info","ts":1719882812.5049987,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
Hopefully, I provided sufficient information to help fix this issue. If you need more information please do let me know what else I should add.
