Capabilities of OCA\CloudFederationAPI\
    • 31.0.0
    • Ubuntu 24.04
    • replace me
    • 8.3.17
    • Yes
    • replace me
    • no
There are many errors related to Capabilities of OCA\CloudFederationAPI\ took xxx seconds to generate.
There are no steps to replicate. The system is usable, but the log is full of them, sometimes leveled as Error others as Fatal.
{"reqId":"GXXQp6RuZ7RjcdHTckZR","level":4,"time":"2025-03-09T01:00:13+00:00","remoteAddr":"84.79.237.36","user":"my_user","app":"no app in context","method":"GET","url":"/nextcloud/index.phpadmin/logging","message":"Capabilities of OCA\\CloudFederationAPI\\Capabilities took 6.18 seconds to generate.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/133.0.0.0 Safari/537.36","version":"31.0.0.18","data":[],"id":"67cce822b10a6"}
        "default_phone_region": "ES",
        "overwrite.cli.url": "https:\/\/cloud.uep.cat\/nextcloud\/",
        "overwritewebroot": "\/nextcloud",
            "cloud.uep.cat"
        "default_language": "ca",
        "default_locale": "ca_ES",
        "default_timezone": "Europe\/Madrid",
        "dbtype": "mysql",
        "version": "31.0.0.18",
        "dbport": "",
        "mysql.utf8mb4": true,
        "filelocking.enabled": true,
        "upgrade.disable-web": true,
        "enable_previews": true,
        "enabledPreviewProviders": [
            "OC\\Preview\\Movie",
            "OC\\Preview\\Image",
            "OC\\Preview\\Imaginary"
        "redis": {
            "port": "6379"
        "objectstore": {
            "class": "\\OC\\Files\\ObjectStore\\S3",
            "arguments": {
                "bucket": "clouduepcat-nextcloud",
                "autocreate": true,
                "hostname": "s3.fr-par.scw.cloud",
                "key": "***REMOVED SENSITIVE VALUE***",
                "port": 443,
                "use_ssl": true,
                "region": "fr-par"
        "memories.exiftool": "\/config\/www\/nextcloud\/apps\/memories\/bin-ext\/exiftool-amd64-musl",
        "memories.vod.path": "\/config\/www\/nextcloud\/apps\/memories\/bin-ext\/go-vod-amd64",
        "memories.gis_type": 1,
        "loglevel": 2,
        "filesystem_check_changes": 1,
        "app_install_overwrite": [
            "facerecognition"
    "apps": {
        "activity": {
            "enabled": "yes",
            "installed_version": "4.0.0",
            "types": "filesystem"
        "admin_audit": {
            "enabled": "yes",
            "installed_version": "1.21.0",
            "types": "logging"
        "analytics": {
            "enabled": "yes",
            "installed_version": "5.2.4",
            "types": ""
        "app_api": {
            "enabled": "yes",
            "installed_version": "5.0.2",
            "types": ""
        "backgroundjob": {
            "lastjob": "73187"
        "bruteforcesettings": {
            "enabled": "yes",
            "types": ""
        "calendar": {
            "enabled": "yes",
            "installed_version": "5.1.3",
            "types": ""
        "circles": {
            "enabled": "yes",
            "installed_version": "31.0.0-dev.0",
            "loopback_tmp_path": "\/nextcloud\/",
            "loopback_tmp_scheme": "https",
            "maintenance_run": "0",
            "maintenance_update": "{\"3\":1741479901,\"2\":1741482002,\"1\":1741482002}",
            "migration_22": "1",
            "migration_run": "0",
            "types": "filesystem,dav"
        "cloud_federation_api": {
            "enabled": "yes",
            "installed_version": "1.14.0",
        "comments": {
            "enabled": "yes",
            "types": "logging"
        "contacts": {
            "enabled": "yes",
            "installed_version": "7.0.3",
            "types": "dav"
        "contactsinteraction": {
            "enabled": "yes",
            "installed_version": "1.12.0",
            "types": "dav"
        "core": {
            "backgroundjobs_mode": "cron",
            "group.sortBy": "2",
            "installedat": "1718184529.7264",
            "lastcron": 1741482003,
            "lastupdateResult": "[]",
            "lastupdatedat": 1741480335,
            "metadataGenerationDone": true,
            "moveavatarsdone": "yes",
            "previewsCleanedUp": "1",
            "public_files": "files_sharing\/public.php",
            "vendor": "nextcloud",
            "files_metadata": {
                "photos-original_date_time": {
                    "value": null,
                    "type": "int",
                    "etag": "",
                    "indexed": true,
                    "editPermission": 0
                "blurhash": {
                    "value": null,
                    "type": "string",
                    "etag": "67ccc7617385d",
                    "indexed": false,
                    "editPermission": 0
                "photos-exif": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-ifd0": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-gps": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-size": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "files-live-photo": {
                    "value": null,
                    "type": "string",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-place": {
                    "value": null,
                    "type": "string",
                    "etag": "",
                    "indexed": true,
                    "editPermission": 0
            "oc.integritycheck.checker": []
        "dashboard": {
            "enabled": "yes",
            "installed_version": "7.11.0",
            "types": ""
        "dav": {
            "buildCalendarReminderIndex": "yes",
            "buildCalendarSearchIndex": "yes",
            "builtSocialSearchIndex": "yes",
            "chunks_migrated": "1",
            "enabled": "yes",
            "installed_version": "1.33.0",
            "regeneratedBirthdayCalendarsForYearFix": "yes",
        "facerecognition": {
            "assigned_memory": "8589934592",
            "enabled": "no",
            "installed_version": "0.9.60",
        "federatedfilesharing": {
            "enabled": "yes",
            "types": ""
        "federation": {
            "enabled": "no",
            "types": "authentication"
        "files": {
            "enabled": "yes",
            "installed_version": "2.3.1",
            "mimetype_version": "31.0.0.18",
        "files_downloadlimit": {
            "enabled": "yes",
            "types": ""
        "files_pdfviewer": {
            "enabled": "yes",
            "types": ""
        "files_reminders": {
            "enabled": "yes",
            "installed_version": "1.4.0",
            "types": ""
        "files_sharing": {
            "enabled": "yes",
            "installed_version": "1.23.1",
        "files_trashbin": {
            "enabled": "yes",
        "files_versions": {
            "enabled": "yes",
            "installed_version": "1.24.0",
        "firstrunwizard": {
            "enabled": "yes",
            "types": ""
        "integration_google": {
            "client_id": "***REMOVED SENSITIVE VALUE***",
            "client_secret": "***REMOVED SENSITIVE VALUE***",
            "enabled": "yes",
            "installed_version": "3.2.0",
            "types": "",
            "use_popup": "1"
        "logreader": {
            "enabled": "yes",
            "shownLevels": "[3,4]",
            "types": "logging"
        "lookup_server_connector": {
            "enabled": "yes",
            "installed_version": "1.19.0",
        "memories": {
            "enabled": "yes",
            "installed_version": "7.5.2",
            "last_index_job_duration": "12.64",
            "last_index_job_start": "1741481403",
            "last_index_job_status": "Indexing completed successfully",
            "last_index_job_status_type": "success",
            "types": ""
        "nextcloud_announcements": {
            "enabled": "yes",
            "installed_version": "3.0.0",
            "pub_date": "Thu, 24 Oct 2019 00:00:00 +0200",
            "types": "logging"
        "notifications": {
            "enabled": "yes",
            "types": "logging"
        "oauth2": {
            "enabled": "yes",
            "installed_version": "1.19.1",
        "password_policy": {
            "enabled": "yes",
        "photos": {
            "enabled": "yes",
            "installed_version": "4.0.0-dev.1",
            "lastPlaceMappedUser": "benetj",
            "lastPlaceMappingDone": "true",
            "types": "dav,authentication"
        "privacy": {
            "enabled": "yes",
            "readableLocation": "fr",
            "types": ""
        "profile": {
            "enabled": "yes",
            "installed_version": "1.0.0",
            "types": ""
        "provisioning_api": {
            "enabled": "yes",
            "types": "prevent_group_restriction"
        "recommendations": {
            "enabled": "yes",
            "types": ""
        "related_resources": {
            "enabled": "yes",
            "installed_version": "2.0.0",
            "types": ""
        "richdocumentscode": {
            "enabled": "no"
        "serverinfo": {
            "cached_count_appdata_files": 290812,
            "cached_count_filecache": 362896,
            "cached_count_storages": "8",
            "enabled": "yes",
            "size_appdata_storage": 2993624967,
            "types": ""
        "settings": {
            "enabled": "yes",
            "types": ""
        "sharebymail": {
            "enabled": "yes",
        "support": {
            "SwitchUpdaterServerHasRun": "yes",
            "enabled": "yes",
            "types": "session"
        "survey_client": {
            "enabled": "yes",
            "last_report": "{\"id\":\"oczw2paiooxi\",\"items\":[[\"server\",\"version\",\"30.0.6.2\"],[\"server\",\"code\",\"other\"],[\"server\",\"enable_avatars\",\"yes\"],[\"server\",\"enable_previews\",\"yes\"],[\"server\",\"memcache.local\",\"\\\\OC\\\\Memcache\\\\APCu\"],[\"server\",\"memcache.distributed\",\"\\\\OC\\\\Memcache\\\\Redis\"],[\"server\",\"asset-pipeline.enabled\",\"no\"],[\"server\",\"filelocking.enabled\",\"yes\"],[\"server\",\"memcache.locking\",\"\\\\OC\\\\Memcache\\\\Redis\"],[\"server\",\"debug\",\"no\"],[\"server\",\"cron\",\"cron\"],[\"php\",\"version\",\"8.3.16\"],[\"php\",\"memory_limit\",-1],[\"php\",\"max_execution_time\",0],[\"php\",\"upload_max_filesize\",107374182400],[\"database\",\"type\",\"mysql\"],[\"database\",\"version\",\"11.4.4\"],[\"database\",\"size\",560037888],[\"apps\",\"activity\",\"3.0.0\"],[\"apps\",\"admin_audit\",\"1.20.0\"],[\"apps\",\"analytics\",\"5.2.4\"],[\"apps\",\"app_api\",\"4.0.6\"],[\"apps\",\"bruteforcesettings\",\"3.0.0\"],[\"apps\",\"calendar\",\"5.0.10\"],[\"apps\",\"circles\",\"30.0.0\"],[\"apps\",\"cloud_federation_api\",\"1.13.0\"],[\"apps\",\"comments\",\"1.20.1\"],[\"apps\",\"contacts\",\"6.1.3\"],[\"apps\",\"contactsinteraction\",\"1.11.0\"],[\"apps\",\"dashboard\",\"7.10.0\"],[\"apps\",\"dav\",\"1.31.1\"],[\"apps\",\"facerecognition\",\"disabled\"],[\"apps\",\"federatedfilesharing\",\"1.20.0\"],[\"apps\",\"federation\",\"1.20.0\"],[\"apps\",\"files\",\"2.2.0\"],[\"apps\",\"files_downloadlimit\",\"3.0.0\"],[\"apps\",\"files_pdfviewer\",\"3.0.0\"],[\"apps\",\"files_reminders\",\"1.3.0\"],[\"apps\",\"files_sharing\",\"1.22.0\"],[\"apps\",\"files_trashbin\",\"1.20.1\"],[\"apps\",\"files_versions\",\"1.23.0\"],[\"apps\",\"firstrunwizard\",\"3.0.0\"],[\"apps\",\"integration_google\",\"3.1.1\"],[\"apps\",\"logreader\",\"3.0.0\"],[\"apps\",\"lookup_server_connector\",\"1.18.0\"],[\"apps\",\"memories\",\"7.4.1\"],[\"apps\",\"nextcloud_announcements\",\"2.0.0\"],[\"apps\",\"notifications\",\"3.0.0\"],[\"apps\",\"oauth2\",\"1.18.1\"],[\"apps\",\"password_policy\",\"2.0.0\"],[\"apps\",\"photos\",\"3.0.2\"],[\"apps\",\"privacy\",\"2.0.0\"],[\"apps\",\"provisioning_api\",\"1.20.0\"],[\"apps\",\"recommendations\",\"3.0.0\"],[\"apps\",\"related_resources\",\"1.5.0\"],[\"apps\",\"richdocumentscode\",\"disabled\"],[\"apps\",\"serverinfo\",\"2.0.0\"],[\"apps\",\"settings\",\"1.13.0\"],[\"apps\",\"sharebymail\",\"1.20.0\"],[\"apps\",\"support\",\"2.0.0\"],[\"apps\",\"survey_client\",\"2.0.0\"],[\"apps\",\"systemtags\",\"1.20.0\"],[\"apps\",\"text\",\"4.1.0\"],[\"apps\",\"theming\",\"2.6.0\"],[\"apps\",\"twofactor_backupcodes\",\"1.19.0\"],[\"apps\",\"updatenotification\",\"1.20.0\"],[\"apps\",\"user_status\",\"1.10.0\"],[\"apps\",\"viewer\",\"3.0.0\"],[\"apps\",\"weather_status\",\"1.10.0\"],[\"apps\",\"webhook_listeners\",\"1.1.0-dev\"],[\"apps\",\"workflowengine\",\"2.12.0\"],[\"stats\",\"num_files\",361643],[\"stats\",\"num_users\",3],[\"stats\",\"num_storages\",8],[\"stats\",\"num_storages_local\",1],[\"stats\",\"num_storages_home\",1],[\"stats\",\"num_storages_other\",6],[\"stats\",\"num_comments\",0],[\"stats\",\"num_comment_markers\",0],[\"stats\",\"num_systemtags\",0],[\"stats\",\"num_systemtags_mappings\",0],[\"files_sharing\",\"num_shares\",4],[\"files_sharing\",\"num_shares_user\",2],[\"files_sharing\",\"num_shares_groups\",0],[\"files_sharing\",\"num_shares_link\",2],[\"files_sharing\",\"num_shares_link_no_password\",2],[\"files_sharing\",\"num_fed_shares_sent\",0],[\"files_sharing\",\"num_fed_shares_received\",0],[\"files_sharing\",\"permissions_0_1\",2],[\"files_sharing\",\"permissions_3_1\",2],[\"encryption\",\"enabled\",\"no\"],[\"encryption\",\"default_module\",\"no\"]]}",
            "last_sent": "1739818217",
            "types": ""
        "systemtags": {
            "enabled": "yes",
            "installed_version": "1.21.1",
            "types": "logging"
        "text": {
            "enabled": "yes",
            "installed_version": "5.0.0",
            "types": "dav"
        "theming": {
            "enabled": "yes",
            "installed_version": "2.6.1",
            "types": "logging"
        "twofactor_backupcodes": {
            "enabled": "yes",
            "installed_version": "1.20.0",
            "types": ""
        "updatenotification": {
            "analytics": "5.2.4",
            "calendar": "5.1.3",
            "contacts": "7.0.3",
            "core": "30.0.5.1",
            "enabled": "yes",
            "integration_google": "3.1.1",
            "memories": "7.5.2",
            "types": "",
            "update_check_errors": 0
        "user_status": {
            "enabled": "yes",
            "installed_version": "1.11.0",
            "types": ""
        "viewer": {
            "enabled": "yes",
            "types": ""
        "weather_status": {
            "enabled": "yes",
            "types": ""
        "webhook_listeners": {
            "enabled": "yes",
            "installed_version": "1.2.0",
        "workflowengine": {
            "enabled": "yes",
            "installed_version": "2.13.0",
  - activity: 4.0.0
  - admin_audit: 1.21.0
  - analytics: 5.2.4
  - app_api: 5.0.2
  - bruteforcesettings: 4.0.0
  - calendar: 5.1.3
  - circles: 31.0.0-dev.0
  - comments: 1.21.0
  - contacts: 7.0.3
  - contactsinteraction: 1.12.0
  - dashboard: 7.11.0
  - dav: 1.33.0
  - files: 2.3.1
  - files_downloadlimit: 4.0.0
  - files_pdfviewer: 4.0.0
  - files_reminders: 1.4.0
  - files_sharing: 1.23.1
  - files_trashbin: 1.21.0
  - files_versions: 1.24.0
  - firstrunwizard: 4.0.0
  - integration_google: 3.2.0
  - logreader: 4.0.0
  - memories: 7.5.2
  - notifications: 4.0.0
  - oauth2: 1.19.1
  - password_policy: 3.0.0
  - photos: 4.0.0-dev.1
  - privacy: 3.0.0
  - profile: 1.0.0
  - provisioning_api: 1.21.0
  - recommendations: 4.0.0
  - related_resources: 2.0.0
  - serverinfo: 3.0.0
  - settings: 1.14.0
  - sharebymail: 1.21.0
  - support: 3.0.0
  - survey_client: 3.0.0
  - systemtags: 1.21.1
  - text: 5.0.0
  - theming: 2.6.1
  - updatenotification: 1.21.0
  - user_status: 1.11.0
  - viewer: 4.0.0
  - weather_status: 1.11.0
  - webhook_listeners: 1.2.0
  - workflowengine: 2.13.0
  - encryption: 2.19.0
  - facerecognition: 0.9.60 (installed 0.9.60)
  - federation: 1.21.0 (installed 1.21.0)
  - files_external: 1.23.0
  - suspicious_login: 9.0.1
  - user_ldap: 1.22.0
I too have this, also the webUI is extremly slow.
{"reqId":"4kYVKftgVqPpRDyUHlBo","level":4,"time":"2025-03-20 09:00:52","remoteAddr":"MYIP","user":false,"app":"no app in context","method":"GET","url":"/login","message":"Capabilities of OCA\\CloudFederationAPI\\Capabilities took 6.3300000000000001 seconds to generate.","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/134.0.0.0 Safari/537.36","version":"31.0.2.1","data":[]}
After upgrading to 31.0.2 I am seeing this in the logs. Log page freezes after I copy raw. Running as a docker under unraid (linuxserver.io). First time I have seen this. Reverse proxy: nginx 25.03.1.
{"reqId":"b86xgG0VRnkQq4FSA9DO","level":4,"time":"2025-03-31T16:12:26+00:00","remoteAddr":"192.168.1.161","user":false,"app":"no app in context","method":"GET","url":"/login","message":"Capabilities of OCA\\CloudFederationAPI\\Capabilities took 3.26 seconds to generate.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/134.0.0.0 Safari/537.36","version":"31.0.2.1","data":[],"id":"67eaf39508521"}
Nextcloud Server version (e.g., 29.x.x):
Nextcloud Hub 10 (31.0.2)
Operating system and version (e.g., Ubuntu 24.04):
Ubuntu 24.04.2 LTS
Web server and version (e.g, Apache 2.4.25):
nginx/1.27.3
PHP version (e.g, 8.3):
PHP 8.3.6
Is this the first time you’ve seen this error? (Yes / No):
No
When did this problem seem to first start?
Immediately after upgrading to 31.0.1
Installation method (e.g. AlO, NCP, Bare Metal/Archive, etc.)
AWS EC2 Instance: t3a.xlarge
Are you using CloudfIare, mod_security, or similar? (Yes / No)
no
No steps needed to reproduce, it is constant. I did try it with encryption disabled and enabled, there was no difference.
I cannot load the log from the web interface as it locks the window.
sudo -u www-data php occ log:tail
Level App Message Time
Error no app in context Capabilities of OCA\CloudFederationAPI\Capabilities took 1.26 seconds to generate. 2025-04-03T19:36:46+00:00
Error no app in context Capabilities of OCA\CloudFederationAPI\Capabilities took 1.43 seconds to generate. 2025-04-03T20:01:01+00:00
Error no app in context Capabilities of OCA\CloudFederationAPI\Capabilities took 1.24 seconds to generate. 2025-04-03T20:27:04+00:00
Error no app in context Capabilities of OCA\CloudFederationAPI\Capabilities took 1.22 seconds to generate. 2025-04-03T21:06:09+00:00
Error no app in context Capabilities of OCA\CloudFederationAPI\Capabilities took 1.14 seconds to generate. 2025-04-03T21:06:11+00:00
Error no app in context Capabilities of OCA\CloudFederationAPI\Capabilities took 1.17 seconds to generate. 2025-04-03T21:06:14+00:00
Error no app in context Capabilities of OCA\CloudFederationAPI\Capabilities took 1.24 seconds to generate. 2025-04-03T21:10:24+00:00
Error no app in context Capabilities of OCA\CloudFederationAPI\Capabilities took 1.27 seconds to generate. 2025-04-03T21:33:19+00:00
Error no app in context Capabilities of OCA\CloudFederationAPI\Capabilities took 1.16 seconds to generate. 2025-04-03T21:44:11+00:00
Error no app in context Capabilities of OCA\CloudFederationAPI\Capabilities took 1.21 seconds to generate. 2025-04-03T21:46:54+00:00
“system”: {
“instanceid”: “REMOVED SENSITIVE VALUE”,
“passwordsalt”: “REMOVED SENSITIVE VALUE”,
“secret”: “REMOVED SENSITIVE VALUE”,
“trusted_domains”: [
“nextcloud.focus-sis.com”
“datadirectory”: “REMOVED SENSITIVE VALUE”,
“dbtype”: “mysql”,
“version”: “31.0.2.1”,
“overwrite.cli.url”: “https://nextcloud.focus-sis.com”,
“dbname”: “REMOVED SENSITIVE VALUE”,
“dbhost”: “REMOVED SENSITIVE VALUE”,
“dbport”: “”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“dbuser”: “REMOVED SENSITIVE VALUE”,
“dbpassword”: “REMOVED SENSITIVE VALUE”,
“installed”: true,
“maintenance_window_start”: 1,
“default_phone_region”: “US”,
“mail_from_address”: “REMOVED SENSITIVE VALUE”,
“mail_smtpmode”: “smtp”,
“mail_sendmailmode”: “smtp”,
“mail_domain”: “REMOVED SENSITIVE VALUE”,
“mail_smtphost”: “REMOVED SENSITIVE VALUE”,
“mail_smtpport”: “587”,
“maintenance”: false,
“memcache.local”: “\OC\Memcache\APCu”,
“memcache.distributed”: “\OC\Memcache\Redis”,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “REMOVED SENSITIVE VALUE”,
“port”: 6379
“app_install_overwrite”: [
“fulltextsearch”
“ldapProviderFactory”: “OCA\User_LDAP\LDAPProviderFactory”,
“theme”: “”,
“loglevel”: 2,
“log.condition”: {
“apps”: [
“admin_audit”
“logfile_audit”: “/var/www/nextcloud/data/nextcloud.log”
  • activity: 4.0.0
  • admin_audit: 1.21.0
  • announcementcenter: 7.1.0
  • app_api: 5.0.2
  • assistant: 2.4.0
  • bruteforcesettings: 4.0.0
  • calendar: 5.2.0
  • circles: 31.0.0
  • collectives: 2.16.1
  • comments: 1.21.0
  • contacts: 7.0.4
  • contactsinteraction: 1.12.0
  • dashboard: 7.11.0
  • dav: 1.33.0
  • deck: 1.15.0
  • encryption: 2.19.0
  • files: 2.3.1
  • files_downloadlimit: 4.0.0
  • files_external: 1.23.0
  • files_pdfviewer: 4.0.0
  • files_reminders: 1.4.0
  • files_sharing: 1.23.1
  • files_trashbin: 1.21.0
  • files_versions: 1.24.0
  • firstrunwizard: 4.0.0
  • fulltextsearch_elasticsearch: 31.0.0
  • group_everyone: 0.1.17
  • groupfolders: 19.0.4
  • integration_github: 3.1.1
  • integration_gitlab: 3.1.2
  • integration_jira: 1.3.0
  • integration_openproject: 2.8.1
  • logreader: 4.0.0
  • notes: 4.11.0
  • notifications: 4.0.0
  • oauth2: 1.19.1
  • password_policy: 3.0.0
  • photos: 4.0.0-dev.1
  • polls: 7.4.1
  • privacy: 3.0.0
  • profile: 1.0.0
  • provisioning_api: 1.21.0
  • recommendations: 4.0.0
  • related_resources: 2.0.0
  • richdocuments: 8.6.3
  • richdocumentscode: 24.4.1302
  • serverinfo: 3.0.0
  • settings: 1.14.0
  • sharebymail: 1.21.0
  • support: 3.0.0
  • survey_client: 3.0.0
  • suspicious_login: 9.0.1
  • systemtags: 1.21.1
  • tables: 0.9.0
  • tasks: 0.16.1
  • text: 5.0.0
  • theming: 2.6.1
  • updatenotification: 1.21.0
  • user_ldap: 1.22.0
  • user_saml: 6.5.0
  • user_status: 1.11.0
  • user_usage_report: 2.0.0
  • viewer: 4.0.0
  • weather_status: 1.11.0
  • webhook_listeners: 1.2.0
  • workflow_pdf_converter: 2.0.0
  • workflowengine: 2.13.0
Yeah I have been noticing the same issue. It also seems to be triggered by the general NC cron jobs since this error pops up about every two hours. Constantly and without fail.
I have been seeing this error in both a few versions already. So at least in 31 and 30.
There was a fix merged, not sure if it is in the latest release, though.
I am on 31.0,3, so not in the latest available.
However, thanks to your heads up, I found the the Re: Issue and commit.
To those who may have the same error:
The fixed will be shipped in 31.0.4, due in May.
Or if you know how, you can replicate the fix now but for most, know that a fix is incoming.
I am on 31.0.4 and the problem is still ocurring.
Same here, 31.0.4
Thanks
It’s not May yet :slight_smile:
31.0.4 was an intermediate release, so the fix is pushed to 31.0.5 in May.
Same errors in log with 31.0.6
Same here, 31.0.6
Thanks
Hi ! Same with Nextcloud Hub 10 (31.0.7)
Some has posted this “fix”, seems that the problem is an overloaded/slow server :
