Hey guys,
My installation is up and running fine. Now I’m trying to reach it from outside. I am aware that this is probably a router related issue, but I’m still trying to get some help here as there might be users having similar issues:
STEPS TAKEN:
Ran nc-forward-ports and confirmed a change on my routers configuration page
Router is a TP-Link Wireless N 300M TL-WR840N (I’m in Brazil, not easy to get better hardware)
Created a freedns account
Ran freeDNS, seems ok!
EXPECTED BEHAVIOR
Reach NC through freeDNS created subdomain
or at least through my current IP (v4)
PROBLEM
Can’t reach it, neither through freeDNS subdomain nor directly through IP, tried different computers, appended :80 and :443, tried http:// and https://
Any tricks you know of? Do I have to get a different router?
Thanks in advance!!!
nc-forward-ports output:
List of UPNP devices found on the network :
desc: http://192.168.0.1:49152/wps_device.xml
st: uuid:00000000-0000-1000-0000-8416f98cf3b6
st: upnp:rootdevice
desc: http://192.168.0.1:1900/igd.xml
st: urn:schemas-upnp-org:device:InternetGatewayDevice:1
Found valid IGD : http://192.168.0.1:1900/ipc
Local LAN ip address : 192.168.0.130
ExternalIPAddress = 100.71.33.130
InternalIP:Port = 192.168.0.130:80
external 100.71.33.130:80 TCP is redirected to internal 192.168.0.130:80 (duration=0)
tks! well it’s confirmed then… 201.6.134.1 is my external IP What can I do now? The (automatic “wizard”) tools in my router and in NC don’t take that situation into account!
I don´t know exact your local setup and what you have done. But I think there is something wrong with your setted port forwarding. I think the system you want to run nextcloud is a linux machine.
Type there in shell ifconfig to see the internal LAN IP. When you´ll find it (I guess it´s 192.168.178.0.130 from your previous posting) you need to enter that IP in your router under portforwarding, that the router knows which port it needs to forward to which ip.
Best regards.
My router has the external IP 100.71.33.130 and now I found out that I can reach NC through that IP when on my local network.
I guess that means the router got its IP from the modem. It’s a Motorola SBV5121
I’m not quite sure which IP it has, my router tells me that its default gateway is 100.71.32.1
It’s all quite messed up, but I’m using predefined settings, and my router gets its IP “dinamycally” (I guess it means DHCP) from the modem.
