Can't get NextCloud to work with Cloudflare Zero Trust Tunnel
Full transparency, I’m a noob.
  • Nextcloud Server version:
    • NextCloud AIO 10.0.0
    • Ubuntu Server 24.04.1
  • Reverse proxy
    • Cloudflare Zero Trust Tunnel
  • Installation method
    • Docker 26.1.3
  • Are you using Cloudflare, mod_security, or similar?
    • Yes, Cloudflare
I set up a Hetzner VPS and installed Ubuntu Server 24.04. I set up a Cloudflare Tunnel on Cloudflare’s website and used the docker command with the secret key to install it. I then used the docker command to install NextCloud AIO in reverse proxy mode, referring to this guide for both general installation using a proxy as well as specifically for Cloudflare. Looking through Nextcloud’s docs, tutorials, and even ai help, I’ve been told to set the service in Cloudflare for the public hostname configuration as both http and https, as well as using the public ip address, the private machine’s, or localhost/127.0.0.1 with either port 8080 or port 11000. I tried all of these and the only way I could actually get the site to load was by using the public IP with port 8080, but this kinda defeats the purpose. Every other combination I tried led to either ip not found, time outs, http on an https error, or 502 gateway error.
Yes, I referenced this guide, and many YouTube videos.
I confirmed with curl the instance was accessible on local host port 11000, I don’t know why Cloudflare is having such issues.
Can anybody advise how they set it up?
Access Cloudflare and click on your domain, on the left select (rules) - (page rules).
On the right, click (Create page rules) and add the following options:
In (URL) type the URL of your nextcloud with * at the beginning and end, example: (**nextcloud…com/*) Just an asterisk at the beginning.
Click on (add setting) and in the box (Pick a Setting (required)) select (Cache level), next to it select (Bypass).
Click on (add setting) and in the box select (Disable Performance).
Then click (Save Page Rule).
Returning to the left sidebar Open (Scrape Shield) and uncheck (Email Address Obfuscation).
If you use Nextcloud with HTTPS you must go to the Zero Trust page choose the tunnel and in (Public hostname) choose the nextcloud host and edit - in (Additional application settings) click on (TLS) and mark (No TLS Verify). With this it should work.
In some tests I decided to add one more (Pick a Setting (required)) to the rule created with the option (Disable Security) and I noticed that it improved the upload speed.
Translated from Brazilian to English by Google translator!
