I have the manual installation of Nextcloud (latest) on a Ubuntu 18.04.3 LTS vmware fusion box.
Its all online, but I havent got the SSL certificate certified properly. So as its self-certified, its not working on Google Chrome on other clients, especially via the domain name.
I was able to do this on the snap version with no issues, but since going to the manual installation its just getting stuck.
I have checked the DNS records, and the A record has been dynamically pointed at the IP, and I can use the website domain to get onto my nextcloud too.
But, when using certbot, Im getting this…
Domain: [mydomain].com
Type: connection
Detail: Fetching http://[mydomain].com/.well-known/acme-challenge/xDQi4zFjnD3WQdD_f0iudUmB72LRWfWPdmvxjLbbEI8: Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address. Additionally, please check that your computer has a publicly routable IP address and that no firewalls are preventing the server from communicating with the client. If you’re using the webroot plugin, you should also verify that you are serving files from the webroot path you provided.
2020-01-10 15:23:54,770:DEBUG:certbot.error_handler:Encountered exception:
Traceback (most recent call last):
- File “/usr/lib/python3/dist-packages/certbot/auth_handler.py”, line 82, in handle_authorizations*
- self._respond(aauthzrs, resp, best_effort)*
- File “/usr/lib/python3/dist-packages/certbot/auth_handler.py”, line 168, in _respond*
- self._poll_challenges(aauthzrs, chall_update, best_effort)*
- File “/usr/lib/python3/dist-packages/certbot/auth_handler.py”, line 239, in _poll_challenges*
- raise errors.FailedChallenges(all_failed_achalls)*
certbot.errors.FailedChallenges: Failed authorization procedure. [mydomain].com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://[mydomain].com/.well-known/acme-challenge/xDQi4zFjnD3WQdD_f0iudUmB72LRWfWPdmvxjLbbEI8: Timeout during connect (likely firewall problem)2020-01-10 15:23:54,770:DEBUG:certbot.error_handler:Calling registered functions
2020-01-10 15:23:54,770:INFO:certbot.auth_handler:Cleani
Does anyone know how to fix this? Or have another solution to get the SSL certificate done properly?
