I installed nextcloud on my TrueNAS Scale server a couple of months back and all was working fine up until I had to restart my NAS and now I cannot access the webGUI or the instance through the mobile app.
I checked the logs only to find that 4 out of the 6 total pod logs were inaccessible with all 4 showing
curl: (7) Failed to connect to 192.168.1.200 port 9001: Connection refused
Im not sure what I ould have missed during the setup process but I will say that this is only my second time setting up a nextcloud instance so go easy on me haha.
Below is the logs I was able to obtain with IPs replaced with xxx.xxx etc
Application Name:nextcloudPod Name:nextcloud-6484d8575-jx84zContainer Name:nextcloud
2023-01-26 03:07:24.764246+00:00Conf remoteip disabled.
2023-01-26 03:07:24.764271+00:00To activate the new configuration, you need to run:
2023-01-26 03:07:24.764276+00:00service apache2 reload
2023-01-26 03:07:24.857368+00:00AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using xxx.xx.x.xx. Set the 'ServerName' directive globally to suppress this message
2023-01-26 03:07:24.867738+00:00AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using xxx.xx.x.xx. Set the 'ServerName' directive globally to suppress this message
2023-01-26 03:07:24.883874+00:00[Thu Jan 26 03:07:24.883732 2023] [mpm_prefork:notice] [pid 1] AH00163: Apache/2.4.54 (Debian) PHP/8.1.14 configured -- resuming normal operations
2023-01-26 03:07:24.883894+00:00[Thu Jan 26 03:07:24.883766 2023] [core:notice] [pid 1] AH00094: Command line: 'apache2 -D FOREGROUND'
2023-01-26 03:11:12.785186+00:00[Thu Jan 26 03:11:12.785070 2023] [mpm_prefork:notice] [pid 1] AH00171: Graceful restart requested, doing restart
2023-01-26 03:11:12.791805+00:00AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using xxx.xx.x.xx. Set the 'ServerName' directive globally to suppress this message
2023-01-26 03:11:12.801382+00:00[Thu Jan 26 03:11:12.801346 2023] [mpm_prefork:notice] [pid 1] AH00163: Apache/2.4.54 (Debian) PHP/8.1.14 configured -- resuming normal operations
2023-01-26 03:11:12.801400+00:00[Thu Jan 26 03:11:12.801353 2023] [core:notice] [pid 1] AH00094: Command line: 'apache2 -D FOREGROUND'
The above log will repeat itself over and over
The only other accessible log is as follows
Application Name:nextcloudPod Name:nextcloud-postgres-7775b4965c-jnmhsContainer Name:nextcloud-postgres
2023-01-26 03:08:23.661224+00:002023-01-26T03:08:23.661224831Z
2023-01-26 03:08:23.661285+00:00PostgreSQL Database directory appears to contain a database; Skipping initialization
2023-01-26 03:08:23.661300+00:002023-01-26T03:08:23.661300664Z
2023-01-26 03:08:23.932997+00:002023-01-26 03:08:23.932 UTC [1] LOG: starting PostgreSQL 13.1 (Debian 13.1-1.pgdg100+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
2023-01-26 03:08:23.933144+00:002023-01-26 03:08:23.933 UTC [1] LOG: listening on IPv4 address "0.0.0.0", port 5432
2023-01-26 03:08:23.933165+00:002023-01-26 03:08:23.933 UTC [1] LOG: listening on IPv6 address "::", port 5432
2023-01-26 03:08:24.146450+00:002023-01-26 03:08:24.146 UTC [1] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-01-26 03:08:24.457117+00:002023-01-26 03:08:24.456 UTC [27] LOG: database system was interrupted; last known up at 2023-01-26 03:07:20 UTC
2023-01-26 03:08:24.801982+00:002023-01-26 03:08:24.801 UTC [27] LOG: database system was not properly shut down; automatic recovery in progress
2023-01-26 03:08:24.983867+00:002023-01-26 03:08:24.983 UTC [27] LOG: redo starts at 0/7A8F54A0
2023-01-26 03:08:24.983945+00:002023-01-26 03:08:24.983 UTC [27] LOG: invalid record length at 0/7A8F54D8: wanted 24, got 0
2023-01-26 03:08:24.984009+00:002023-01-26 03:08:24.983 UTC [27] LOG: redo done at 0/7A8F54A0
2023-01-26 03:08:26.231773+00:002023-01-26 03:08:26.231 UTC [1] LOG: database system is ready to accept connections
Nextcloud version (25.0.3_1.6.16)
Operating system and version (TrueNAS-SCALE-22.02.4)
Apache or nginx version (unsure)
PHP version (unsure)
