cannot mount an external disk with SMB - please help
hello dear community!
I have just installed nextcloud on a LXC under proxmox. Which also worked wonderfully. However, I aktell in the external disk implementation with SMB do not get on and hope you can help me!?
Shortly to the actual situation:
The disk I would like to integrate into nexcloud as an external disk is also in my server, but it has already been assigned to OMV, which has also been installed as a VM in proxmox.
The additional programs I have properly installed:
https://docs.nextcloud.com//server/latest/admin_manual/configuration_files/external_storage/smb.html
The hard disk I would like to point to is called β€œMain folder2”.
the host is: 192.168.178.40 and except username and password this should have been all the necessary information.
I integrate with this information my other hard disk also with SMB under Windows11 permanently.
Unfortunately, no connection is made.
i have already set the IP with \192.168.178.40\ then with http://xxx.xxx.xxx.xx/, then without additional characters, nothing works
(unfortunately i am not able to upload a screenshot here, so i have to use an external medium)
What am I doing wrong?
Best regards!
