Nextcloud version (eg, 20.0.5): 24.0.9
Operating system and version (eg, Ubuntu 20.04): unknown - hosted environment
Apache or nginx version (eg, Apache 2.4.25): unknown - hosted environment
PHP version (eg, 7.4): 8.0.27
I’m using two-factor authentication for some while now. Today i recognized, that my calendars are out of sync and that it didn’t change after manual sync. So i deleted my account in DAVx5 and wanted to create it again.
I created a new app password in my Nextcloud - Security settings, started my Nextcloud app on my Android phone and chose “Sync calendar & contacts” in “Settings”. Then DAVx5 opens and shows our Nextcloud “Connect to your account” page immediately.
First i chose the “Log in”-button, entered my username and my new app password and it said, that my credentials are wrong. Thought i did it there in the past but maybe i’m wrong. So i started again from the beginning and instead of choosing the “Log in”-button, i used the link “Alternative log in using app token” below that button. After adding my username and my new app password an internal server error shows up and i get an error in the nextcloud.log.
I have exactly the same behavior with the same phone but another nextcloud instance.
Do i just do it wrong?
Thanks a lot!
Nils
- Create a new app password
- Choose “Sync calendar & contacts” in Android Nextcloud app settings
- Login with your new app password
[index] Fehler: Exception: OC\Core\Service\LoginFlowV2Service::flowDoneWithAppPassword(): Argument #3 ($loginName) must be of type string, null given, called in /var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Controller/ClientFlowLoginV2Controller.php on line 227 in file '/var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Service/LoginFlowV2Service.php' line 189 at <<closure>>
0. /var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/App.php line 172
1. /var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/Route/Router.php line 298
OC\AppFramework\App::main()
2. /var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/base.php line 1030
OC\Route\Router->match()
3. /var/www/vhosts/no-domain.com/cloud.no-domain.com/index.php line 36
OC::handleRequest()
POST /login/v2/apptoken
from xxx at 2023-02-16T08:14:15+00:00
'trusted_proxies' =>
0 => '127.0.0.1',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'localhost',
1 => 'cloud.no-domain.com',
'datadirectory' => '/var/www/vhosts/no-domain.com/.nextcloud/data/91724b953bad',
'version' => '24.0.9.2',
'overwrite.cli.url' => 'https://cloud.no-domain.com/',
'dbname' => 'nextcloud_1551bb69',
'dbhost' => 'localhost:3306',
'dbuser' => 'xxx',
'dbpassword' => 'xxx',
'instanceid' => 'xxx',
'default_language' => 'de',
'default_locale' => 'de_DE',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => 'noreply',
'mail_domain' => 'no-domain.com',
'mail_smtphost' => 'xxx',
'mail_smtpport' => '465',
'mail_smtpauth' => 1,
'mail_smtpname' => 'noreply@no-domain.com',
'mail_smtppassword' => 'xxx',
'theme' => '',
'loglevel' => 2,
'ldapIgnoreNamingRules' => false,
'app_install_overwrite' =>
0 => 'files_readmemd',
'skeletondirectory' => '',
'templatedirectory' => '',
'trashbin_retention_obligation' => 'auto, 180',
'app.mail.smtp.timeout' => 45,
'profile.enabled' => false,
nextcloud.log
{“reqId”:“gMEZNxqozbzjLz5dFyvF”,“level”:3,“time”:“2023-02-16T08:13:57+00:00”,“remoteAddr”:“xxx”,“user”:“–”,“app”:“index”,“method”:“POST”,“url”:“/login/v2/apptoken”,“message”:“OC\Core\Service\LoginFlowV2Service::flowDoneWithAppPassword(): Argument #3 ($loginName) must be of type string, null given, called in /var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Controller/ClientFlowLoginV2Controller.php on line 227 in file ‘/var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Service/LoginFlowV2Service.php’ line 189”,“userAgent”:“Mozilla/5.0 (Android 10; Mobile; rv:109.0) Gecko/109.0 Firefox/109.0”,“version”:“24.0.9.2”,“exception”:{“Exception”:“Exception”,“Message”:“OC\Core\Service\LoginFlowV2Service::flowDoneWithAppPassword(): Argument #3 ($loginName) must be of type string, null given, called in /var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Controller/ClientFlowLoginV2Controller.php on line 227 in file ‘/var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Service/LoginFlowV2Service.php’ line 189”,“Code”:0,“Trace”:[{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/App.php”,“line”:172,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/Route/Router.php”,“line”:298,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:“::”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/base.php”,“line”:1030,“function”:“match”,“class”:“OC\Route\Router”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/index.php”,“line”:36,“function”:“handleRequest”,“class”:“OC”,“type”:“::”}],“File”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/Http/Dispatcher.php”,“Line”:165,“Previous”:{“Exception”:“TypeError”,“Message”:“OC\Core\Service\LoginFlowV2Service::flowDoneWithAppPassword(): Argument #3 ($loginName) must be of type string, null given, called in /var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Controller/ClientFlowLoginV2Controller.php on line 227”,“Code”:0,“Trace”:[{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Controller/ClientFlowLoginV2Controller.php”,“line”:227,“function”:“flowDoneWithAppPassword”,“class”:“OC\Core\Service\LoginFlowV2Service”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/Http/Dispatcher.php”,“line”:225,“function”:“apptokenRedirect”,“class”:“OC\Core\Controller\ClientFlowLoginV2Controller”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/Http/Dispatcher.php”,“line”:133,“function”:“executeController”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/App.php”,“line”:172,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/Route/Router.php”,“line”:298,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:“::”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/base.php”,“line”:1030,“function”:“match”,“class”:“OC\Route\Router”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/index.php”,“line”:36,“function”:“handleRequest”,“class”:“OC”,“type”:“::”}],“File”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Service/LoginFlowV2Service.php”,“Line”:189},“CustomMessage”:“–”}}
{“reqId”:“xpsomTYrjgNHx9aeHiJU”,“level”:3,“time”:“2023-02-16T08:14:15+00:00”,“remoteAddr”:“xxx”,“user”:“–”,“app”:“index”,“method”:“POST”,“url”:“/login/v2/apptoken”,“message”:“OC\Core\Service\LoginFlowV2Service::flowDoneWithAppPassword(): Argument #3 ($loginName) must be of type string, null given, called in /var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Controller/ClientFlowLoginV2Controller.php on line 227 in file ‘/var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Service/LoginFlowV2Service.php’ line 189”,“userAgent”:“Mozilla/5.0 (Android 10; Mobile; rv:109.0) Gecko/109.0 Firefox/109.0”,“version”:“24.0.9.2”,“exception”:{“Exception”:“Exception”,“Message”:“OC\Core\Service\LoginFlowV2Service::flowDoneWithAppPassword(): Argument #3 ($loginName) must be of type string, null given, called in /var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Controller/ClientFlowLoginV2Controller.php on line 227 in file ‘/var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Service/LoginFlowV2Service.php’ line 189”,“Code”:0,“Trace”:[{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/App.php”,“line”:172,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/Route/Router.php”,“line”:298,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:“::”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/base.php”,“line”:1030,“function”:“match”,“class”:“OC\Route\Router”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/index.php”,“line”:36,“function”:“handleRequest”,“class”:“OC”,“type”:“::”}],“File”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/Http/Dispatcher.php”,“Line”:165,“Previous”:{“Exception”:“TypeError”,“Message”:“OC\Core\Service\LoginFlowV2Service::flowDoneWithAppPassword(): Argument #3 ($loginName) must be of type string, null given, called in /var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Controller/ClientFlowLoginV2Controller.php on line 227”,“Code”:0,“Trace”:[{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Controller/ClientFlowLoginV2Controller.php”,“line”:227,“function”:“flowDoneWithAppPassword”,“class”:“OC\Core\Service\LoginFlowV2Service”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/Http/Dispatcher.php”,“line”:225,“function”:“apptokenRedirect”,“class”:“OC\Core\Controller\ClientFlowLoginV2Controller”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/Http/Dispatcher.php”,“line”:133,“function”:“executeController”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/App.php”,“line”:172,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/Route/Router.php”,“line”:298,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:“::”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/base.php”,“line”:1030,“function”:“match”,“class”:“OC\Route\Router”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/index.php”,“line”:36,“function”:“handleRequest”,“class”:“OC”,“type”:“::”}],“File”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Service/LoginFlowV2Service.php”,“Line”:189},“CustomMessage”:“–”}}
{“reqId”:“0FBZU8ihfdG4gNuoZEm6”,“level”:3,“time”:“2023-02-16T08:18:52+00:00”,“remoteAddr”:“xxx”,“user”:“–”,“app”:“index”,“method”:“POST”,“url”:“/login/v2/apptoken”,“message”:“OC\Core\Service\LoginFlowV2Service::flowDoneWithAppPassword(): Argument #3 ($loginName) must be of type string, null given, called in /var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Controller/ClientFlowLoginV2Controller.php on line 227 in file ‘/var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Service/LoginFlowV2Service.php’ line 189”,“userAgent”:“Mozilla/5.0 (Android 10; Mobile; rv:109.0) Gecko/109.0 Firefox/109.0”,“version”:“24.0.9.2”,“exception”:{“Exception”:“Exception”,“Message”:“OC\Core\Service\LoginFlowV2Service::flowDoneWithAppPassword(): Argument #3 ($loginName) must be of type string, null given, called in /var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Controller/ClientFlowLoginV2Controller.php on line 227 in file ‘/var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Service/LoginFlowV2Service.php’ line 189”,“Code”:0,“Trace”:[{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/App.php”,“line”:172,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/Route/Router.php”,“line”:298,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:“::”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/base.php”,“line”:1030,“function”:“match”,“class”:“OC\Route\Router”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/index.php”,“line”:36,“function”:“handleRequest”,“class”:“OC”,“type”:“::”}],“File”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/Http/Dispatcher.php”,“Line”:165,“Previous”:{“Exception”:“TypeError”,“Message”:“OC\Core\Service\LoginFlowV2Service::flowDoneWithAppPassword(): Argument #3 ($loginName) must be of type string, null given, called in /var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Controller/ClientFlowLoginV2Controller.php on line 227”,“Code”:0,“Trace”:[{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Controller/ClientFlowLoginV2Controller.php”,“line”:227,“function”:“flowDoneWithAppPassword”,“class”:“OC\Core\Service\LoginFlowV2Service”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/Http/Dispatcher.php”,“line”:225,“function”:“apptokenRedirect”,“class”:“OC\Core\Controller\ClientFlowLoginV2Controller”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/Http/Dispatcher.php”,“line”:133,“function”:“executeController”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/AppFramework/App.php”,“line”:172,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/private/Route/Router.php”,“line”:298,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:“::”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/lib/base.php”,“line”:1030,“function”:“match”,“class”:“OC\Route\Router”,“type”:“->”},{“file”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/index.php”,“line”:36,“function”:“handleRequest”,“class”:“OC”,“type”:“::”}],“File”:“/var/www/vhosts/no-domain.com/cloud.no-domain.com/core/Service/LoginFlowV2Service.php”,“Line”:189},“CustomMessage”:“–”}}
