example
longer
example
here
Nextcloud version (eg, 20.0.5): 20 something (it wont start)
Operating system and version (eg, Ubuntu 20.04): FreeBSD 12 jail
Apache or nginx version (eg, Apache 2.4.25): 2.4.41
PHP version (eg, 7.4): 7.3.15
The issue you are facing: Login screen wont show after power outage - error 500
Is this the first time you’ve seen this error? (Y/N): YES
- n/a
Can't log in to NC
I had a power outage yesterday and since then mysql will not start. I was not doing any updates or anything, it was just ticking along before the outage. Now power is back, Apache server is up n running, but mysql wont start. Maybe I just need to reinstall a package, or clear a cache?
When booting the Nextcloud FreeBSD jail that houses the NC instance, the messages log states:
nextcloud root[4068]: /etc/rc: WARNING: failed to start mysql
If I ssh to the command line and try to start mysql I get this:
root@nextcloud:~ # service mysql-server start
Starting mysql.
limits: NO: No such file or directory
/usr/local/etc/rc.d/mysql-server: WARNING: failed to start mysql
Although that directory does exist (are they referring to something else?):
root@nextcloud:/usr/local/etc/rc.d # ls -la
total 127
drwxr-xr-x 2 root wheel 13 Sep 5 15:59 .
drwxr-xr-x 20 root wheel 42 Sep 5 16:17 ..
-r-xr-xr-x 1 root wheel 6230 Jan 30 2020 apache24
-r-xr-xr-x 1 root wheel 945 Aug 26 03:31 avahi-daemon
-r-xr-xr-x 1 root wheel 1197 Aug 26 03:31 avahi-dnsconfd
-rwxr-xr-x 1 root wheel 447 Aug 26 09:19 cupsd
-rwxr-xr-x 1 root wheel 592 Aug 26 03:24 dbus
-r-xr-xr-x 1 root wheel 3068 Jan 31 2020 garb
-r-xr-xr-x 1 root wheel 1834 Jan 30 2020 htcacheclean
-r-xr-xr-x 1 root wheel 4103 Feb 4 2020 mysql-server
-r-xr-xr-x 1 root wheel 1305 Feb 22 2020 php-fpm
-rwxr-xr-x 1 root wheel 1143 Aug 26 09:09 tcsd
-rwxr-xr-x 1 root wheel 527 Aug 26 09:06 tpmd
Everything was fine and dandy before the power outage. I have a dump of my databases but I guess this problem is something else, more low level.
Trying to check the mysql version I got this:
root@nextcloud:~ # mysql -u root -p
ld-elf.so.1: Shared object "libssl.so.8" not found, required by "mysql"
Trying to check the php version I got this in return:
root@nextcloud:~ # php -v
PHP Warning: PHP Startup: Unable to load dynamic library 'curl.so' (tried: /usr/local/lib/php/20180731/curl.so (Shared object "libssl.so.8" not found, required by "libcurl.so.4"), /usr/local/lib/php/20180731/curl.so.so (Cannot open "/usr/local/lib/php/20180731/curl.so.so")) in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library 'ldap.so' (tried: /usr/local/lib/php/20180731/ldap.so (Shared object "libssl.so.8" not found, required by "libldap-2.4.so.2"), /usr/local/lib/php/20180731/ldap.so.so (Cannot open "/usr/local/lib/php/20180731/ldap.so.so")) in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library 'openssl.so' (tried: /usr/local/lib/php/20180731/openssl.so (Shared object "libssl.so.8" not found, required by "openssl.so"), /usr/local/lib/php/20180731/openssl.so.so (Cannot open "/usr/local/lib/php/20180731/openssl.so.so")) in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library 'zip.so' (tried: /usr/local/lib/php/20180731/zip.so (Shared object "libssl.so.8" not found, required by "libzip.so.5"), /usr/local/lib/php/20180731/zip.so.so (Cannot open "/usr/local/lib/php/20180731/zip.so.so")) in Unknown on line 0
PHP 7.3.15 (cli) (built: Feb 22 2020 01:13:52) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.3.15, Copyright (c) 1998-2018 Zend Technologies
with Zend OPcache v7.3.15, Copyright (c) 1999-2018, by Zend Technologies
