I’ve found this: https://github.com/nextcloud/server/issues/429 and this https://github.com/nextcloud/android/pull/3383 and it looks like the mobile app has QRCode scanner built in for easier client setup, but I cannot find where in my Nextcloud server are those QRCode for client setup… I’m using Nextcloud 15.0.4. When i create new app password/token i still have it in text form and there is no QRCode to scan…
Should I enable something or what ? Cause I cannot find anything about this in the documentation… or even what text should this QRCode contain…
Unfortunately you haven’t fully read the mentioned issue tickets. The function requires
a server part to be integrated which has been scheduled for Nextcloud v16
Sorry for my english, im french
Hi, i have my QR code, but when i can use android app, i scan and i view https://selynes.com/nextcloud, its ok, but tap enter = test of connexion and nothing… i have test whitout QR code, i have write adress but its same…
In Nextcloud version 19.0.3, in order to generate a QR code to quickly log into your Nextcloud server without entering URL, username or password, take the following steps:
