This is a question rather than a support ticket. I’m trying to import files and images that have tag metadata attached and I expected Nextcloud to display them on import since it has tagging. However I can’t get any tags to show up and tagging in nextcloud is tedious since you can’t tag several files at the same time. For those who use tags, what are the solutions to be able to use tagging on NextCloud? Is there any way to get your tags to show up?
I don’t know about importing tags but you can certainly tag multiple files at a time. When you select one or more files an “Action” button appears at the top and when you click it you get a little menu with “Manage tags” as its first entry. You can then choose existing tags or create a new one.
