Hey there everyone.
This is a cross-post from the Snapcraft forums. We’re about to release an update to the Nextcloud snap containing a number of updates mostly relating to PHP, including:
- Update to 7.1.13
- Freetype support
- LDAP support
- PCNTL support
It’s a relatively low-risk release, but we could still use some help kicking its tires. If you want in, use the candidate channel:
sudo snap install --candidate nextcloud
If you already have it installed, refresh to it:
sudo snap refresh --candidate nextcloud
We’ve put together some smoke tests to help you really give it a workout:
Please test as much as you can, and let me know if you have any questions or run into any issues.
