Call for testing: Nextcloud 12.0.5 RC2 & 11.0.7 RC2
Edit: There is now RC2 - see Call for testing: Nextcloud 12.0.5 RC2 & 11.0.7 RC2
We just released the 12.0.5 RC1 & 11.0.7 RC1. You can find the changelog at the end of this post.
To make sure everything works as expected also in your environment, we’d greatly appreciate your help to test it.
While we expect the release to not eat any data and be stable, the usual disclaimer is still valid: Make sure to have backups before updating!
… once you have done that, grab the code from https://download.nextcloud.com/server/prereleases/ and simply update your instance as usual by removing all old files and putting the new files in place. It is also shipped by our update server to all instances of Nextcloud 11 or Nextcloud 12 with the beta channel selected. (sadly most of the people migrated to the 13 beta now :laughing:)
If you encounter any issues, please leave a comment here and file an issue at https://github.com/nextcloud/server/issues (or the appropriate repository of the component)
Thanks to all the awesome people that contributed in some way to this release! Be it with coding, translating, helping people, filing issues, etc.
Keep rocking :rocket:
12.0.5 RC 1
Server
Other apps
Server 11.0.7 RC 1
Server
12.0.5 RC1 installed, upgraded all is fine!
We just published an RC2 of both versions:
12.0.5 RC2
https://download.nextcloud.com/server/prereleases/nextcloud-12.0.5RC2.zip
11.0.7 RC2
https://download.nextcloud.com/server/prereleases/nextcloud-11.0.7RC2.zip
Update done. Everything smooth :wink:
@MorrisJobke The LE certificate for download.nextcloud.com is expired. :wink:
https://help.nextcloud.com/t/ssl-cert-error-on-downloads/26270?u=thomasmarx
sure, i’d love to test. i have nextcould working on a shared server but I could test on my home system (linux, mint 18.3 Cinnamon) if you could help me install. I tried your links to download without success.
12.0.5 and 11.0.7 are released now. Thanks for your help. Changelog will also be available soon on the website: https://github.com/nextcloud/nextcloud.com/pull/762
