Call drops at 4+ participants (HPB in host mode behind Caddy container)
The Issue: Calls are rock-solid for 1–3 participants. As soon as a 4th person joins, video streams fail to connect or the call drops for the new participant. 1-to-1 calls work perfectly.
Environment:
  • Nextcloud Version: Nextcloud Hub 32
  • Install Type: Docker AIO (ghcr.io/nextcloud-releases/aio-talk:latest)
  • Reverse Proxy: Caddy (Running in a Docker container, network 172.18.0.0/16)
  • HPB Network: network_mode: "host"
  • VPS Firewall: UDP 20000–40000 and 49152–65535 are open in the provider’s dashboard.
This is a snippet of my docker.yml
nextcloud-talk-hpb:
image: ghcr.io/nextcloud-releases/aio-talk:latest
network_mode: “host”
environment:
- PUBLIC_IP=xxx.xxx.xxx.xxx
- TALK_PORT=3478
- TRUSTED_PROXIES=‘127.0.0.1,172.16.0.0/12’
- TALK_TRUSTED_PROXIES=‘127.0.0.1,172.16.0.0/12’
# (Secrets are verified and matching Nextcloud Talk settings)
Relevant Logs: The HPB container logs show:
hub.go:283: No trusted proxies configured, only allowing for [127.0.0.0/8, 10.0.0.0/8, 172.16.0.0/12, 192.168.0.0/16]
Even with TRUSTED_PROXIES set in the environment, the binary doesn’t seem to acknowledge the proxy. I suspect the 4+ person drop is due to the HPB’s brute-force protection triggering because it sees all participants coming from the Caddy internal IP (172.18.0.x).
Troubleshooting Done:
  1. Verified UDP port ranges are open on both UFW and VPS hardware firewall.
  2. Confirmed host.docker.internal is mapped correctly in Caddy via extra_hosts.
  3. Updated config.php with trusted_proxies array including the Docker bridge range.
in general even if HPB doesn’t work I would not expect the call to drop (for everybody) but just become unstable - 4 participants is just rule of thumb there is no real limit. The problem is simply each user must send and receive media from every other participant - at some point clients don’t have bandwidth and processing power.. but I remember stable calls with 5 or 6 participant without HPB.
172.16.0.0/12 includes your 172.18.x.x address (172.16.0.1 - 172.31.255.254)
please open udp/3478 tcp/3478 as well.
