Calender issue with NC32
Dear Nextcloud Community,
we¹ are currently developing PermaplanT, a web app that should support sustainable and bio-diverse gardening. We heavily integrated Nextcloud, to be used for files, chats etc. to enable users to collaborate.
We are facing several challenges with Nextcloud and now see the need to have a staging environment so that all the problems are not immediately user-facing. For example, the calender completely broke after the upgrade from 30.0.7 to 30.0.8. Our Nextcloud calender now has an endless spinner on the left side and doesn’t show calender entries. The browser shows to one person (my log see below):
We already fixed many CORS and Keycloak integration issues but this time we are stuck. We used this calender heavily for development planning.
Is there someone who is interested in the web app or generally in sustainability and wants to help us with this and other Nextcloud challenges?
best regards, Markus
¹ we are mostly from TU Wien and I am in the process of setting up a non-profit (gemeinnütziger und mildtätiger Verein) called Perma, for sustainable future development.
    • 32.0.0
    • Devuan Linux 5 (daedalus 12.11)
    • apache2
    • Caddy:alpine, we want to migrate to HAProxy
    • 8.3
    • First time reporting, we see it for a while now.
    • Upgrade to Nextcloud version 30.0.8
    • AIO
    • we use Keycloak for auth
Calender has no entries.
  1. Visit Calender (needed to remove URL because of 4 URLs restrictions)
Nothing while accessing the calender
Source-Map-Fehler: Error: JSON.parse: unexpected character at line 1 column 1 of the JSON data
Stack in the worker:parseSourceMapInput@resource://devtools/client/shared/vendor/source-map/lib/util.js:163:15
_factory@resource://devtools/client/shared/vendor/source-map/lib/source-map-consumer.js:1066:22
SourceMapConsumer@resource://devtools/client/shared/vendor/source-map/lib/source-map-consumer.js:26:12
_fetch@resource://devtools/client/shared/source-map-loader/utils/fetchSourceMap.js:83:19
Ressourcen-Adresse: https://cloud.permaplant.net/index.php/apps/calendar/dayGridMonth/%3Canonymous%20code%3E
Source-Map-Adresse: installHook.js.map
Notifications permissions not yet requested NotificationsApp.vue:457:12
Polling interval updated to 30000 NotificationsApp.vue:403:12
Started background fetcher as session_keepalive is enabled NotificationsApp.vue:273:13
Failed sending heartbeat, got: undefined UserStatus.vue:159:1
[ERROR] calendar: [Vue error]: Error in beforeMount hook (Promise/async): TypeError: can't access property "split", t is undefined
Object { app: "calendar", uid: "...", level: 2, error: TypeError, vm: {…}, info: "beforeMount hook (Promise/async)" }
Uncaught (in promise) TypeError: can't access property "findAllCalendars", d() is undefined
    p caldavService.js:66
    backgroundSyncJob Calendar.vue:267
    setInterval handler*created Calendar.vue:265
    VueJS 28
    <anonymous> main.js:53
    <anonymous> main.js:63
caldavService.js:66:9
    (Async: setInterval handler)
    VueJS 28
    <anonym> main.js:53
    <anonym> main.js:63
    <anonym> main.js:63
(these errors repeat)
couldnt find log of Caddy
            "cloud.permaplant.net"
        "dbtype": "pgsql",
        "version": "32.0.0.13",
        "dbpersistent": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "loglevel": 2,
        "memories.exiftool": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/exiftool-amd64-glibc",
        "memories.vod.path": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/go-vod-amd64",
        "overwriteprotocol": "https",
        "overwrite.cli.url": "https:\/\/cloud.permaplant.net",
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "upgrade.disable-web": true,
        "maintenance_window_start": 22,
        "default_phone_region": "AT",
        "chunkSize": "5120MB",
        "skeletondirectory": "\\srv\\nextcloud_user_template",
        "auth.webauthn.enabled": false,
        "app.mail.verify-tls-peer": false,
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": 587,
        "mail_smtpsecure": "tls",
        "mail_smtpauthtype": "PLAIN",
        "mail_smtpauth": 1,
        "user_oidc": {
            "selfencoded_bearer_validation_audience_check": false,
            "selfencoded_bearer_validation_azp_check": false,
            "allow_multiple_user_backends": 0
        "app_install_overwrite": [
            "passwords"
  - activity: 5.0.0-dev.0
  - admin_audit: 1.22.0
  - analytics: 6.0.1
  - app_api: 32.0.0
  - bookmarks: 16.0.0
  - calendar: 6.0.2
  - circles: 32.0.0
  - collectives: 3.2.3
  - comments: 1.22.0
  - contacts: 8.0.4
  - contactsinteraction: 1.13.1
  - cookbook: 0.11.4
  - cospend: 3.1.6
  - dashboard: 7.12.0
  - dav: 1.34.2
  - deck: 1.16.0
  - federation: 1.22.0
  - files: 2.4.0
  - files_external: 1.24.0
  - files_reminders: 1.5.0
  - files_sharing: 1.24.0
  - files_trashbin: 1.22.0
  - files_versions: 1.25.0
  - firstrunwizard: 5.0.0-dev.0
  - forms: 5.2.2
  - integration_gitlab: 3.2.0
  - logreader: 5.0.0-dev.0
  - notes: 4.12.3
  - notifications: 5.0.0-dev.0
  - oauth2: 1.20.0
  - passwords: 2025.10.20
  - photos: 5.0.0-dev.1
  - polls: 8.5.0
  - privacy: 4.0.0-dev.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - serverinfo: 4.0.0-dev.0
  - settings: 1.15.1
  - sharebymail: 1.22.0
  - spreed: 22.0.1
  - support: 4.0.0-dev.0
  - systemtags: 1.22.0
  - text: 6.0.0-dev.0
  - theming: 2.7.0
  - updatenotification: 1.22.0
  - user_oidc: 8.1.0
  - user_status: 1.12.0
  - viewer: 5.0.0-dev.0
  - weather_status: 1.12.0
  - webhook_listeners: 1.3.0
  - workflowengine: 2.14.0
  - bbb: 2.8.0 (installed 2.8.0)
  - cms_pico: 1.0.21 (installed 1.0.21)
  - encryption: 2.20.0
  - external: 7.0.0 (installed 7.0.0)
  - files_automatedtagging: 3.0.0 (installed 3.0.0)
  - files_rightclick: 1.4.0 (installed 1.6.0)
  - files_texteditor: 2.15.1 (installed 2.15.1)
  - groupfolders: 20.1.2 (installed 20.1.2)
  - mail: 5.5.11 (installed 5.5.11)
  - memories: 7.7.0 (installed 7.7.0)
  - metadata: 0.23.0 (installed 0.23.0)
  - phonetrack: 0.9.1 (installed 0.9.1)
  - previewgenerator: 5.10.0 (installed 5.10.0)
  - quota_warning: 1.22.0 (installed 1.22.0)
  - survey_client: 4.0.0-dev.0 (installed 1.7.0)
  - twofactor_totp: 14.0.0
  - uppush: 2.3.1 (installed 2.3.1)
  - user_ldap: 1.23.0
  - user_migration: 9.0.0 (installed 9.0.0)
What we already tried without success is:
rm -r data/appdata_/css/ data/appdata_/js/
occ files:scan-app-data
The only thing that worked was rolling back to 30.0.7, but this is not possible anymore, as we already did a lot in Nextcloud since we upgraded to NC32. (We probably should have reported this problem earlier here.)
Thank you for your time!
having a staging environment is always a good idea..
I can’t say for sure what is the problem - calendar works all 3 of my instances running NC32 two of them with OpenID login through Keycloak. I also believe there would be many complaints in the forum if it would be a general problem. but I’m confident
is not going to help rather brake almost everything!
From your config I see you are still on 32.0.0 so I would recommend you upgrade to 32.0.1 to bring back assets you removed before and dig deeper into the problem if it persist.
Thank you for the hint that a new version is available! I updated to 32.0.1 but updating did not fix this issue (like the other updates from 30.0.8 on).
The calender entries are still not shown and there is an endless spinner. The error messages seem to be the same:
Content-Security-Policy: Die Einstellungen der Seite haben das Laden einer Ressource (media-src) auf data: blockiert, da sie gegen folgende Direktive verstößt: "media-src 'self' blob:" now
@nextcloud/calendar-js app is using version 2.2025b of the timezone database index.mjs:251:13
Calendar API not initialized <anonymous code>:1:147461
Initializing unified search plugin-filters from talk search.js:22:10
Notifications permissions granted NotificationsApp.vue:449:13
Polling interval updated to 30000 NotificationsApp.vue:412:12
Started background fetcher as session_keepalive is enabled NotificationsApp.vue:279:13
Object { app: "calendar", uid: "bodhi", level: 2, error: TypeError, vm: {…}, info: "beforeMount hook (Promise/async)" }
Got notification data, restoring default polling interval. NotificationsApp.vue:368:13
The Die Einstellungen der Seite haben das Laden einer Ressource (media-src) auf data: blockiert, da sie gegen folgende Direktive verstößt: "media-src 'self' blob:" and can't access property "split", t is undefined is shown at other pages, too.
But the findAllCalendars error seems to be specific to this page. I don’t know if it related to the error, though.
this sounds like you setup some custom config related to contentsecuritypolicy and for this reason the browser doesn’t load JavaScript from your server. CSP is provided by Nextcloud application and your reverse proxy should not add/change such headers.
Same issue here. And this is a vanilla NC32 without any customizations and/or reverse proxies etc.
@Summerhill thank you for jumping in.
Do you maybe have many calenders and/or many calender entries?
It is of course a wild guess if there is a relation, but maybe relevant to the issue is to say that we have many calenders and a big calender with many entries shared with a Keycloak group: About 14 people coordinated their meetings in one shared calender.
But anyways, good to know that we are not the only ones. We will soon setup a new NC32 on our staging machine and see if we can reproduce it.
It’s a huge calendar with many entries. Strange behavior: The sync with CalDav Synchronizer in Outlook quits with HTTP-500 Error but the sync from Outlook to an iPhone over Nextcloud works. But you can’t see the calender in the nextcloud webapp.
@Summerhill Interesting. Do you have shares of calenders with Keycloak groups? Maybe this is the culprit?
For me syncing to Thunderbird works without any issues.
No, I have no shares. What I can see in the logs is a memory leak. It consumes all the RAM, even if I set it to 1GB.
Edit: After updating the Calendar to 6.0.4 there are no more entries in the nextcloud log. But I still get a 500 Error for calling: remote.php/dav/principals/users/myusername/
In the PHP logs I see the following issues:
PHP Fatal error: Allowed memory size of 805306368 bytes exhausted (tried to allocate 20480 bytes) in /www/htdocs/xxx/xxx/apps/dav/lib/CalDAV/Calendar.php on line 276
PHP Fatal error: Allowed memory size of 805306368 bytes exhausted (tried to allocate 20480 bytes) in /www/htdocs/xxx/xxx/lib/private/Log/LogDetails.php on line 50
Same issue here too.
I have also the same issue. I described it also on the github: https://github.com/nextcloud/calendar/issues/7703
Same issue also here.
