Calendar entries not showing on dashboard
I was just able to upgrade my NC installation to NC 30.0.1 and 95% of all existing problems have been solved resp error messages disappeared. The only one still not solved is this : Dein Webserver ist nicht ordnungsgemäß für die Auflösung von .well-known-URLs eingerichtet. Fehler bei: /.well-known/caldav Weitere Informationen findest du in der Dokumentation :arrow_upper_right:.
Not sure if this is related to below problem.
However the dashboard “forgets” to show the calendar entries on the day when they are due. i.E a birthday on 8th June will be visible till 07th June midnight . The same applies for all other entries in my calendars. That’s a bit irritating at times. Is the a special setting somewhere hidden ?
Tks for any clue
System : NC 30.0.1 on a Raspi 4 with Dietpi 9.8.0
I think you are talking about “upcoming events” tile which shows the events in the near future, but only before start
while it is good idea not to show past events for meetings and reminders I agree for birthdays it’s not ideal if they disappear once “started” or "during the birthday.
I suggest you open an issue on Github and suggest dashboard “upcoming events” shows the event till it ends (IMHO would be beneficial for meetings as well)
Tks for yr reply. Exactly , if yr day starts and nothing is showing it’s at least a bit stupid. Is there anybody without that “problem” ?
Hi, it’s hard to believe that I’m the only one with this probblem :face_with_open_eyes_and_hand_over_mouth: So, anybody here with a working dashboard which shows the calendar items also on the day when they are due ?
Tks
