I’m running Nextcloud with Docker and it seems to be working fine. I’m wondering if I can/should take any additional steps to improve cache static assets such as JavaScript files and images to speed things up a bit server-side.
But: In my browser console Network tab I already see cache-related headers in responses (etag, cache-control, last-modified), it feels fast (enough), and it looks like most images and JavaScripts are often cached already, so I’m thinking maybe the answer is “no”/“not necessary”/“just leave it as-is.”
- Nextcloud version:
29.0.4/ Hub 8, from the community Docker image taggednextcloud:stable - Host: Docker (compose) running on 64-bit Ubuntu 22.04 LTS server
- Web server: Apache
2.4.61 - PHP version:
8.2.21
I’m doing ad-hoc performance tests with Firefox on a desktop, but I also use Nextcloud with other clients (e.g. my Android phone). For the sake of this thread, let’s limit to talking about using Nextcloud from a web browser.
My Docker compose config file looks pretty much like this, with variables substituted in (e.g. my actual domain name). Per that config I’m using Redis and MariaDB. Both seem to be working fine.
I checked the admin manual and I found info about other types of caching, and some bits about Nginx that don’t apply for my setup.
I’m using OPCache (I recall that’s in the community Docker image).
I’m not even sure what I’d use for caching. Maybe add Varnish somewhere? Tweak Apache config? I don’t see related settings in the Traefik proxy docs.
