example
longer
example
here
Nextcloud version (eg, 18.0.2): 20.0.4.0
Operating system and version (eg, Ubuntu 20.04): Arch linux
Apache or nginx version (eg, Apache 2.4.25): apache 2.4.41
PHP version (eg, 7.1): 7.3.12
It seems the whitelisted IPs are not honoured by bruteforce. At least we have several IPs listed in the bruteforce table that we whitelisted before.
- Whitelist some IPs for bruteforce
- check oc_bruteforce_attempts for your whitelisted IP
There is not much logging for this
nothing to configure for this
apache has really nothing to do with the problem
