Nextcloud 24.0.3
Operating system and version Ubuntu 20.04
PHP version 7.4
can’t read project name in cospend when using BREEZE DARK theme
covered in blue as you can see on picture
plus, the name of the project is shortened and doesn’t display fully - as expected: (2022 10 lataa…)
just
July 21, 2022, 8:50pm
2
As you’ve found, this is an issue for the developer of Breeze Dark. Have you tried the regular dark theme with any success?
opened 10:26AM - 21 Jul 22 UTC
bug
Nextcloud 24.0.3
PHP version 7.4
… The issue you are facing:
covered in blue
plus, the name of the project is shortened and doesn’t display fully, as expected: (2022 10 lataa…)
![Capture d’écran 2022-07-21 à 11 32 43](https://user-images.githubusercontent.com/59349105/180192243-881115b4-b6ea-4a47-b1d0-4155fb9f29be.png)
yes, i found their page and wondered where to post this,
i guess probably better on github
just
July 21, 2022, 9:46pm
4
I like the way you did it. Only part missing was the Github link for the forum.
You nicely covered reporting the issue and encouraging discussion + visibility around it via the forum. Nice work.
yes, i’ve reported the issue as i prefer dark to black …
thanks
Should be fixed in 24.0.2
