Breaking: Removal of PSR-0 class loader in Nextcloud 27
Hello app devs,
Here’s a heads-up for the maintainers of apps that still use class file names following the deprecated PSR-0 standard.
What will change?
Until Nextcloud 26 PSR-0 files will still be loaded by default. With 27 apps have to finally upgrade to PSR-4 or ship their own class loader. We highly recommend PSR-4 for better performance.
How do I adjust my app?
If you have a class \OCA\MyApp\FooBar at myapp/foobar.php then rename and move the file to lib/FooBar. The file name must match the class name. The namespace after \OCA\MyApp must match the directory structure inside lib.
Another famous example is myapp/appinfo/application.php. That file should be migrated to lib/AppInfo/Application.php.
Resources
Ref Upgrade to Nextcloud 26 — Nextcloud latest Developer Manual latest documentation
Ref PSR-4: Autoloader - PHP-FIG
Ref perf(autoloader): Drop legacy class autoloader by ChristophWurst · Pull Request #36114 · nextcloud/server · GitHub
