Borg Restore Not finding borg archive
    • 10.12.0
    • Unraid 7.0.1
    • unsure
    • nginx 2.12.3
    • replace me
    • Yes
    • 4/19/2025
    • AIO Docker
    • no
I took a backup of my server to move to to my new unraid server. The mistake I made was not having a non-encrypted copy but I have the backup and the passcode; however, when I do the restore I get this this log found below.
Any help to solve this would be amazing.
  1. Attempt to do the backup
2025-04-20T01:12:05.152227357Z A 'borg' directory was found but could not find the borg archive.
2025-04-20T01:12:05.152290737Z Only the files/folders below have been found in the borg directory.
2025-04-20T01:12:05.153684291Z .
2025-04-20T01:12:05.153714689Z ..
2025-04-20T01:12:05.153728896Z README
2025-04-20T01:12:05.153742171Z data
2025-04-20T01:12:05.153755576Z hints.17
2025-04-20T01:12:05.153768861Z index.17
2025-04-20T01:12:05.153781966Z integrity.17
2025-04-20T01:12:05.153795111Z nonce
2025-04-20T01:12:05.154125428Z The archive and most importantly the config file must be positioned directly in the 'borg' subfolder.
Hi, looks like the config file is missing. Can you create an empty one in the directory and try again? See all-in-one/Containers/borgbackup/backupscript.sh at 4616ea8cbd31ca2ecb0055195c04504253272fa7 · nextcloud/all-in-one · GitHub
There is a config file in the directory that’s not being picked up by the script - its just a config file that’s 1kb in size. Should I move it and add in a blank one?
I copied the config and put in a new one and now the borg backup isnt showing any files when I run it. Even if I put the old config back in.
2025-04-21T01:08:03.895312145Z A 'borg' directory was found but could not find the borg archive.
2025-04-21T01:08:03.895360106Z Only the files/folders below have been found in the borg directory.
2025-04-21T01:08:03.896422732Z .
2025-04-21T01:08:03.896443662Z ..
2025-04-21T01:08:03.896609587Z The archive and most importantly the config file must be positioned directly in the 'borg' subfolder.
Did you ever find a solution to this? Same issue - the restore is reporting the directory as completely empty
2025-07-10T19:38:56.793431733Z A 'borg' directory was found but could not find the borg archive.
2025-07-10T19:38:56.793463013Z Only the files/folders below have been found in the borg directory.
2025-07-10T19:38:56.794197274Z .
2025-07-10T19:38:56.794215719Z ..
2025-07-10T19:38:56.794366775Z The archive and most importantly the config file must be positioned directly in the 'borg' subfolder.
