Borg remote backup not working after fresh setup
    • Nextcloud Hub 26 Winter (33.0.6)
      Nextcloud AIO v13.3.1
    • Openmediavault8.5.4-1 (Synchrony) on Linux 7.0.13+deb13-amd64
    • Yes
    • First time trying the remote backup (local backup works) after fresh install
    • AIO
    • no
I recently installed OMV / Nextcloud on an old laptop with a usb disk attached just to try out and it was working fine, until I realized I had ignored many recent updates. Unfortunately after updating nextcloud the database would not startup, and…guess what? I had not made any backups…
So I reset the instance with the instructions here and started over with the same host name and recreating the users and moving the data back etc (basically blindly follwing the quickstart guides as at the start). However once I got to backing up I ran into this little issue.
A local backup on the USB disk worked OK but I was interested in remote backups so I went with the BorgBase offer.
Remote borg backup fails with an UNPROTECTED PRIVATE KEY FILE error (see log below)
I made it work by setting the permissions to 600 on /volumes/nextcloud_aio_mastercontainer/_data/data/id_borg (even 640 don’t work) but I’m not sure of any side effects
Is this more an issue with docker on OMV? Just thought I’d share
  1. Setup a borgBase account and backup plan for 250Gb
  2. Set the backup location to the repo url
  3. Attempt a 1st backup with expected key error
  4. save the indicated public key in borgbase and set it for full access to the repo
  5. stop the containers and click create backup
  6. backup fils with the error below
  7. /srv//volumes/nextcloud_aio_mastercontainer/_data/data/id_borg permissions set to 600
Backup Log
2026-07-22T13:02:45.603977552Z Remote: @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
2026-07-22T13:02:45.604026144Z Remote: @         WARNING: UNPROTECTED PRIVATE KEY FILE!          @
2026-07-22T13:02:45.604035288Z Remote: @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
2026-07-22T13:02:45.604044009Z Remote: Permissions 0644 for '/nextcloud_aio_volumes/nextcloud_aio_mastercontainer/data/id_borg' are too open.
2026-07-22T13:02:45.604052621Z Remote: It is required that your private key files are NOT accessible by others.
2026-07-22T13:02:45.604061219Z Remote: This private key will be ignored.
2026-07-22T13:02:45.604069563Z Remote: Load key "/nextcloud_aio_volumes/nextcloud_aio_mastercontainer/data/id_borg": bad permissions
2026-07-22T13:02:45.604078455Z Remote: wpneph4t@wpneph4t.repo.borgbase.com: Permission denied (publickey).
2026-07-22T13:02:45.616177266Z Connection closed by remote host. Is borg working on the server?
2026-07-22T13:02:45.704998437Z Could not initialize borg repository.
bash-5.3# ./occ config:list system
        "one-click-instance": true,
        "update_channel": "stable",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "timeout": 3,
            "read_timeout": 10,
            "port": 6379
        "overwritehost": "skeltonnc.ddns.net",
        "overwriteprotocol": "https",
        "serverid": 445,
            "localhost",
        "dbtype": "pgsql",
        "version": "33.0.6.2",
        "overwrite.cli.url": "https:\/\/skeltonnc.ddns.net\/",
        "updatechecker": false,
        "loglevel": 2,
        "log_type": "file",
        "log_type_audit": "file",
        "logfile_audit": "\/var\/www\/html\/data\/audit.log",
        "log_rotate_size": 10485760,
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
            "7": "OC\\Preview\\Krita",
            "24": "OCA\\Eurooffice\\Preview",
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": 30,
        "share_folder": "\/Shared",
        "htaccess.RewriteBase": "\/",
        "dbpersistent": false,
        "eurooffice": {
            "editors_check_interval": 0,
            "jwt_secret": "09bb3a2bdd4d1e2158173c170bfc5f1aaa215a4f0490be98",
            "jwt_header": "AuthorizationJwt"
        "DOMAIN": "skeltonnc.ddns.net",
        "AIO_VERSION": "v13.3.1"
bash-5.3#
bash-5.3# ./occ app:list
  - activity: 6.0.0
  - admin_audit: 1.23.0
  - bruteforcesettings: 6.0.0
  - calendar: 6.5.1
  - circles: 33.0.0
  - cloud_federation_api: 1.17.0
  - comments: 1.23.0
  - contacts: 8.7.4
  - contactsinteraction: 1.14.1
  - dashboard: 7.13.0
  - dav: 1.36.0
  - deck: 1.17.4
  - eurooffice: 11.0.1
  - federatedfilesharing: 1.23.0
  - federation: 1.23.0
  - files: 2.5.0
  - files_downloadlimit: 5.1.0
  - files_pdfviewer: 6.0.0
  - files_reminders: 1.6.0
  - files_sharing: 1.25.2
  - files_trashbin: 1.23.0
  - files_versions: 1.26.0
  - firstrunwizard: 6.0.0
  - logreader: 6.0.0
  - lookup_server_connector: 1.21.0
  - nextcloud-aio: 0.8.0
  - nextcloud_announcements: 5.0.0
  - notes: 6.0.1
  - notifications: 6.0.0
  - notify_push: 1.3.3
  - oauth2: 1.21.0
  - password_policy: 5.0.0
  - passwords: 2026.7.10
  - photos: 6.0.0
  - privacy: 5.0.0
  - profile: 1.2.0
  - provisioning_api: 1.23.0
  - recommendations: 6.0.0
  - related_resources: 4.0.0
  - serverinfo: 5.0.0
  - settings: 1.16.0
  - sharebymail: 1.23.0
  - spreed: 23.0.8
  - support: 5.0.0
  - survey_client: 5.0.0
  - systemtags: 1.23.0
  - tasks: 0.18.1
  - text: 7.0.1
  - theming: 2.8.0
  - twofactor_backupcodes: 1.22.0
  - twofactor_totp: 15.0.0
  - updatenotification: 1.23.0
  - user_status: 1.13.0
  - viewer: 6.0.0
  - weather_status: 1.13.0
  - webhook_listeners: 1.5.0
  - whiteboard: 1.5.9
  - workflowengine: 2.15.0
  - app_api: 33.0.0 (installed 33.0.0)
  - encryption: 2.21.0
  - files_external: 1.25.1
  - suspicious_login: 11.0.0
  - twofactor_nextcloud_notification: 7.0.0
  - user_ldap: 1.24.0
bash-5.3#
Just do
chmod 600 /nextcloud_aio_volumes/nextcloud_aio_mastercontainer/data/id_borg
which will set safer perms for the borg-key.
Is there a special reason why you are not using repokey in borg? I think if you do not have the above file you will be unable to access this repo, so you need to back it up somewhere else.
GOOD LUCK!
