Nextcloud version (eg, 20.0.5): 28.3.2
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): 2.4.59
PHP version (eg, 7.4): 8.1.27
I am getting a blank, white screen on the web interface - no source.
Running php ooc in the CLI gives:
PHP Fatal error: Cannot declare class OCA\HassIntegration\AppInfo\Application, because the name is already in use in /var/www/nextcloud/apps/integration_homeassistant/lib/AppInfo/Application.php on line 14
I cannot get into the web admin
'passwordsalt' => SECURED,
'secret' => SECURED,
0 => 'localhost',
1 => 'nc.kaddu.dk',
2 => '192.168.2.25',
'datadirectory' => '/var/www/nextcloud-data',
'version' => '28.0.3.2',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => SECURED,
'instanceid' => 'd664425d1d8cb',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'timeout' => 0.0,```
'theme' => '',
'loglevel' => 0,
'mail_smtpmode' => 'smtp',
'mail_domain' => 'kaddu.dk',
'mail_smtphost' => 'smtp.simply.com',
'mail_smtpport' => '587',
'mail_smtpauth' => 1,
'mail_smtpname' => 'nextcloud@kaddu.dk',
'mail_smtppassword' => 'YTqLwEyumDqo7Z',
'app_install_overwrite' =>
0 => 'occweb',
1 => 'ncdownloader',
'allow_local_remote_servers' => true,
[Mon Apr 22 15:05:51.575136 2024] [php:error] [pid 272] [client 37.96.126.211:2016] PHP Fatal error: Cannot declare class OCA\\HassIntegration\\AppInfo\\Application, because the name is already in use in /var/www/nextcloud/apps/integration_homeassistant/lib/AppInfo/Application.php on line 14
[Mon Apr 22 15:06:00.685747 2024] [php:error] [pid 1006] [client 192.168.2.1:59098] PHP Fatal error: Cannot declare class OCA\\HassIntegration\\AppInfo\\Application, because the name is already in use in /var/www/nextcloud/apps/integration_homeassistant/lib/AppInfo/Application.php on line 14
[Mon Apr 22 15:06:16.370389 2024] [php:error] [pid 1662] [client 192.168.2.209:43946] PHP Fatal error: Cannot declare class OCA\\HassIntegration\\AppInfo\\Application, because the name is already in use in /var/www/nextcloud/apps/integration_homeassistant/lib/AppInfo/Application.php on line 14
[Mon Apr 22 15:06:25.154996 2024] [php:error] [pid 275] [client 192.168.2.1:36842] PHP Fatal error: Cannot declare class OCA\\HassIntegration\\AppInfo\\Application, because the name is already in use in /var/www/nextcloud/apps/integration_homeassistant/lib/AppInfo/Application.php on line 14
[Mon Apr 22 15:06:31.166488 2024] [php:error] [pid 272] [client 192.168.2.1:53802] PHP Fatal error: Cannot declare class OCA\\HassIntegration\\AppInfo\\Application, because the name is already in use in /var/www/nextcloud/apps/integration_homeassistant/lib/AppInfo/Application.php on line 14
[Mon Apr 22 15:06:50.551952 2024] [php:error] [pid 644] [client 37.96.126.211:2025] PHP Fatal error: Cannot declare class OCA\\HassIntegration\\AppInfo\\Application, because the name is already in use in /var/www/nextcloud/apps/integration_homeassistant/lib/AppInfo/Application.php on line 14
[Mon Apr 22 15:07:02.144890 2024] [php:error] [pid 275] [client 192.168.2.1:43886] PHP Fatal error: Cannot declare class OCA\\HassIntegration\\AppInfo\\Application, because the name is already in use in /var/www/nextcloud/apps/integration_homeassistant/lib/AppInfo/Application.php on line 14
[Mon Apr 22 15:07:16.034352 2024] [php:error] [pid 272] [client 192.168.2.209:46728] PHP Fatal error: Cannot declare class OCA\\HassIntegration\\AppInfo\\Application, because the name is already in use in /var/www/nextcloud/apps/integration_homeassistant/lib/AppInfo/Application.php on line 14
[Mon Apr 22 15:07:32.149599 2024] [php:error] [pid 1005] [client 192.168.2.1:34366] PHP Fatal error: Cannot declare class OCA\\HassIntegration\\AppInfo\\Application, because the name is already in use in /var/www/nextcloud/apps/integration_homeassistant/lib/AppInfo/Application.php on line 14
It seems to be related to the Home Assistant integration, but if I remember correctly, HA got install well prior to this error.
As I cannot deactivate this integration neither through php occ app:disable nor through the web interface - how can I resolve this situation?
