Nextcloud version (eg, 12.0.2): 18.0.3
Operating system and version (eg, Ubuntu 17.04): debian 9
Apache or nginx version (eg, Apache 2.4.25): apache
PHP version (eg, 7.1): 7.3
Error during recycle process. Files are restored not to original location, but to root folder which means total mess.
Is this the first time you’ve seen this error? (Y/N): Yes
Steps to replicate it: .
- Collect files over several years.
- Forget to stop sync folder on moving files.
- Try to recycle those files
- Wonder that folder structure gets messed up
opendir(/data/someUser/files_trashbin/versions/2017.d1586305764): failed to open dir: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#127
Doctrine\DBAL\Exception\DeadlockException: An exception occurred while executing 'DELETE FROM `oc_filecache` WHERE `parent` = ?' with params [308442]: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction
PASTE HERE
PASTE HERE
