Hi, i got problem with files that are bigger (over 1gb), im using latest nextcloud and running on Ubuntu20.
I try to transfer to nextcloud with webdav and rclone with this command
rclone copy -P -vv --checkers 1 --transfers 1 --low-level-retries 1 5gb.file remote:/
i get this
2021-02-19 21:24:20 DEBUG : 5gb.file: Need to transfer - File not found at Destination
2021-02-19 21:24:40 ERROR : 5gb.file: Failed to copy:
413 Request Entity Too Large
nginx
the thing is that i edited nginx.config, see the file settings down under
please help me, cant figure out why!
user www-data;
worker_processes auto;
pid /run/nginx.pid;
include /etc/nginx/modules-enabled/*.conf;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# server_names_hash_bucket_size 64;
# server_name_in_redirect off;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
client_max_body_size 50G;
#mail {
# See sample authentication script at:
# http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# auth_http localhost/auth.php;
# pop3_capabilities “TOP” “USER”;
# imap_capabilities “IMAP4rev1” “UIDPLUS”;
server {
listen localhost:110;
protocol pop3;
proxy on;
server {
listen localhost:143;
protocol imap;
proxy on;
